Encapsulation + EBGP
sultan-shaikh
Level 5
Level 5
Hi All,
Kindly clarify the following please...
Consider a setup...
PE - CE - C
where PE is Provider Edge router, CE is Customer Edge managed by us and C is the Customer Premises router, multiple of those can connect to the CE router
Now, I have configured EBGP peering between PE and CE...
The questions are...
1. Can I Trunk these interfaces on which EBGP peering is established ?
2. Is it advisable to use Vlan interfaces or subinterfaces for segregating customer traffic.
My CE is a Cisco 3745 with one of the onboard ports connecting to the PE.
I would have tried it out in my Lab but have limited resources, can anyone help out please...
Thanks..
~sultan
aravindhs
Level 5
Level 5
Hi there
Could you elaborate on your setup in terms of the configuration ? That would enable you to get many options/answers, one or more of which might be suitable to you.
Cheers
Arav
Actually I want to verify of the follwing which solution will work...
PE - CE - C
between PE and CE I am running eBGP, I am running VRF Lite on my CE to segregate between different customers... i.e. C routers...
I want to know which of these options will work...and the options I am playing with are...
1. creating sub interfaces on CE say sub interface fastethernet 0/1.700 on port directly connected to the PE and giving `encapsulation dot1q 700` command to associate it with Vlan 700, which is associated with one of my customer... subinterface 701 and 702... so on... while eBGP will run on Main interface fasthethernet 0/1
OR
2. creating SVIs or Vlan interfaces on fastethernet 0/1... Interface Vlan 700... 701.. 702 so on... for each customer with individual IPs addresses, Trunking the Main interface fastethernet 0/1... while eBGP will be running on it...
I have not been able to test this out in the Lab and have to deploy it soon...
Hope I have clarified a bit... for further clarifications kindly let me know...
~sultan
