Explain Please
admin_2
Level 7
Level 7
Dear All!
What is the basis concept of enabling
IP CEF
command if I m using pbr in my 2821.
waiting ur favable reply.
spremkumar
Level 11
Level 11
As per the supporting doc the optimal way to do Policy Based Routing with better performance you need to enable CEF in your box.
Its otherwise called as CEF-Switched PBR
Before CEF was introduced the PBR was done on the path derived using Fast-Switching which is otherwise called as Fast-Switched PBR..
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a008075fae6.html#wp1005373
regds
