explicitly allow inter vlan routing
sandman2036
Frequent Visitor
Frequent Visitor
I’m looking for a way to explicitly allow certain VLANS to be routable.  In this example I would like VLAN 25&35 to talk but 25 cannot communicate with another vlans.  I would like to apply the rule to VLAN 35 that way I don’t have to remember to do add the ACL if I create a new VLAN.  I have been trying to use the BLOCK_ALL-25.  When I apply this to the other VLANS I get the expected behavior but if I use it on VLAN 35 nothing matches the permit statement, and everything gets denied.
interface GigabitEthernet0/0
 no ip address
 duplex full
 speed 1000
 media-type sfp
 negotiation auto
interface GigabitEthernet0/0.25
 encapsulation dot1Q 25
 ip address 10.10.25.254 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
interface GigabitEthernet0/0.35
 encapsulation dot1Q 35
 ip address 10.10.35.30 255.255.255.224
interface GigabitEthernet0/0.45
 encapsulation dot1Q 45
 ip address 10.10.45.254 255.255.255.0
 ip access-group BLOCK_ALL-25 out
interface GigabitEthernet0/0.65
 encapsulation dot1Q 65
 ip address 10.10.65.254 255.255.255.0
interface GigabitEthernet0/0.666
 encapsulation dot1Q 666
 ip address dhcp
 ip nat outside
ip nat inside source list 1 interface GigabitEthernet0/0.666 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.254
ip access-list extended BLOCK_ALL-25
 permit ip 10.10.25.0 0.0.0.31 any
 deny   ip any any
access-list 2 permit 10.10.25.0 0.0.0.31
access-list 2 deny   any
NOTE: Full config is available on my google drive.  “working_config_CORE-R1_15NOV19_2328--REDACTED--.ios”
https://drive.google.com/drive/folders/1EdrAaIFYK1KN4rsMbuVMJ6S1G-mKq_Zu
in that case, use the access list below and apply it to the subinterface for Vlan 25:
access-list 101 deny 10.10.25.0 0.0.0.255 10.10.45.0 0.0.0.255
access-list 101 deny 10.10.45.0 0.0.0.255 10.10.25.0 0.0.0.255
access-list 101 deny 10.10.25.0 0.0.0.255 10.10.65.0 0.0.0.255
access-list 101 deny 10.10.65.0 0.0.0.255 10.10.25.0 0.0.0.255
access-list 101 permit ip any any
ip access-gtoup 101 in
ip nat inside
11 Replies 11
Georg Pauwen
you can use the VACL below:
access-list 101 permit 10.10.25.0 0.0.0.255 10.10.45.0 0.0.0.255
access-list 101 permit 10.10.45.0 0.0.0.255 10.10.25.0 0.0.0.255
access-list 101 permit 10.10.25.0 0.0.0.255 10.10.65.0 0.0.0.255
access-list 101 permit 10.10.65.0 0.0.0.255 10.10.25.0 0.0.0.255
vlan access-map BLOCK_45_65 10
match ip address 101
action drop
vlan access-map BLOCK_45_65 20
action forward
vlan filter BLOCK_45_65 vlan-list 25
I’m guessing that I cannot do this with a single statement and I would have to update the access map with the addition of additional VLANS.  Currently I am attempting to do this on a 3845 trunked to a 2960s L2 switch.  I cant seem to locate the VLAN ACCESS-MAP command.  Form a cursory search I believe that this is a NP or IE level topic.  I’m working on my CCNA but I will attempt to follow the logic.
#These two lines will permit traffic 25>45 & 25<45
#same as above but for 25&65
#This declares the access name of the access map
#I believe this would be the if statement
# I believe this would be the then statement
action drop
#I don’t quite follow what’s happing here
action forward
--> vlan access-map BLOCK_45_65 20
action forward
This just allows everything else that is not matched by the first statement. You need that to allow Vlan 25 to access anything (including the Internet) except for Vlans 45 and 65.
The 'vlan access-map' should be on your 3850:
3850#conf t
3850(config)#vlan access-map
This is on a 3845 ISR.  I do have a 3945 on the way as well as a L3 module to go with it.  But for the moment and the current challenge I’m trying to do everything in the router.  I fully understand that there is a significant performance hit by doing this.   My in current topology I have the ISR trunked to a 2960-S trunked again to a 3750.  The only reason Im using the 3750 is because of POE as im using a pile of AP1231’s for testing.  With some simple config changes and a 32 port async card they make the perfect hosts for testing.  When I get all the parts for the new ISR I will be migrating to it and can simplify the physical implimitation.
ip nat inside
This is what I dropped on the router after cleaning up all the other acl mess I had.  I did make a mistake in my initial post. VLAN 35 is supposed to be routable only to 25 but nowhere else. I applied that correction to the last suggestion and I can still ping to and from 35&65.  is there a global option that I’m missing?
conf t
access-list 101 deny ip 10.10.35.0 0.0.0.255 10.10.45.0 0.0.0.255
access-list 101 deny ip 10.10.45.0 0.0.0.255 10.10.35.0 0.0.0.255
access-list 101 deny ip 10.10.35.0 0.0.0.255 10.10.65.0 0.0.0.255
access-list 101 deny ip 10.10.65.0 0.0.0.255 10.10.35.0 0.0.0.255
ip access-group 101 in
exit
exit
so you want Vlan 35 only be able to talk to Vlan 25 ?
Can you post your current running configuration (sh run) ?
I believe I found the error.  The ACL is in the incorrect order.  As I am still learning what would the easiest way of fixing this.  the complete config is on my google drive.
access-list 1 permit 10.10.25.0 0.0.0.255
interface Loopback0
 ip address 10.254.254.254 255.255.255.0
 no ip address
 duplex full
 speed 1000
 media-type sfp
 negotiation auto
 ip nat inside
I didn't see that Vlan 35 is not a /24, but a /27 network. Change the access list to:
access-list 101 deny ip 10.10.35.0 0.0.0.31 10.10.45.0 0.0.0.255
access-list 101 deny ip 10.10.45.0 0.0.0.255 10.10.35.0 0.0.0.31
access-list 101 deny ip 10.10.35.0 0.0.0.31 10.10.65.0 0.0.0.255
access-list 101 deny ip 10.10.65.0 0.0.0.255 10.10.35.0 0.0.0.31
Thank you for your help.  I did correct the error with the wildcard masks.  Would having those miss configured wildcards have any effect on efficacy of the ALC rules, since in this case I’m not using any of the other subnets of 10.10.35.x.  Also I still don’t understand why the following rule wouldn’t work.
Access-l ist 101 permit ip 10.10.25.0 0.0.0.255 10.10.35.0 0.0.0.31
Access-l ist 101 deny ip any any
Doing something along these lines seem to be a more secure and scalable than having to revise the ALC list every time there is a change to the network.
Hello
You wont be able to apply an acl just on vlan 35 to deny other traffic on vlan 25 unless you also apply one on vlan 25, however you can just apply one access-list on vlan 25 tp accomodate your request.
access-list 100 deny ip 10.10.45.0 0.0.0.255 any
access-list 100 deny ip 10.10.65.0 0.0.0.255 any
access-list 100 permit ip any any
interface fa0/0.25
ip access-group 100 OUT
Kind Regards
Paul
