failed to process device request - error type application error tag operation-failed error info
yatiraj.panchal1
Community Member
Hi All,
I'm getting below error while try to generate CSR for vManage, vBond or vSmart in vManage GUI portal.
SD-WAN
Version: 18.4.4
Thanks in advance!!
bvalencia1
Community Member
I have this problem too, anyone find a fix?
ekhabaro
Do you have connectivity to controllers? Are you trying to connect them via VPN 0 and forgot to allow netconf protocol via implicit ACL?
b77karan
Community Member
Hi I am facing the following error when trying to download the CSR file Could you please help me
version :viptela-vmanage-19.3.0-genericx86-64
mailid: [email protected]
This error can happen if NETCONF isn’t allowed in VPN 0 or if there’s a control connection issue with the device. Also, check that the system time is synced correctly CSR generation can fail if the NTP settings are off.
