HSRP problem
sandy3006
Community Member
Hi experts,
can anybody tell me whether HSRP works on 2600 series if yes then can we have two different series router eg.2611 and 2620 plz reply imm..
5 Replies 5
Edison Ortiz
Yes, it works on 2600 Series router and you can have two different series. You can actually share a HSRP group with a Layer3 switch.
hi edi,
is it possible on 2611 and 2620 coz the thing is dat i am not having L3 device
Yes, it is possible. They are both L3 devices.
Hi Sandy,
Yes you can have HSRP configured betwen 2611 and 2620 routers. As you mentioned you are not having L3 device is not very clear as both of them are routers and routers are L3.
Are you saing you don't have l3 switch? You can very well configure HSRP between your 2611 and 2620 routers.
Ankur
*Pls rate all helpfull post
Hi ankur,
ya i meant L3 switch and thanks
