ICMP problem
senpay524
Community Member
I have this debug error on my router
Mar  7 10:58:26.296: ICMP: dst (81.21.95.206) administratively prohibited unreachable sent to 79.164.27.174
81.21.95.206 is my outside interface
ip access-list extended NAT
permit ip host 10.0.22.2 any
permit ip host 10.0.21.2 any
permit ip host 10.0.50.10 any
permit ip 10.0.42.0 0.0.0.255 any
permit ip 10.0.10.0 0.0.0.255 any
permit ip host 10.0.31.2 any
permit ip host 10.0.31.3 any
permit ip host 10.0.31.4 any
permit ip host 10.0.31.5 any
permit ip host 10.0.31.6 any
permit ip host 10.0.31.7 any
permit ip host 10.0.31.8 any
permit ip host 10.0.31.9 any
permit icmp any any
permit ip host 10.0.32.253 any
ip access-list extended outside
permit udp any eq domain any gt 1023
permit tcp any any established
permit tcp any host x.x.x.x eq smtp
interface FastEthernet0/0
description Internet
ip address 81.21.95.206 255.255.255.252
ip access-group outside in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
this is some config from router
pings from router an through router not passing
what can be the problem?
2 Accepted Solutions
John Blakley
I'm assuming that you're trying to ping from the lan and you're not getting the return icmp response. If that's the case, add "permit icmp any any echo-reply" and you should be good....
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Try adding:
permit icmp any any unreachable
permit icmp any any time-exceeded
HTH,
John
John Blakley
HTH,
John
Thank John,
it helps with ping.
bu what can i do with traceroute? it doesnt pass.
Try adding:
HTH,
John
Thanks John,
it's okey now
