Input errors ----- ignored on interface router
OMAR CANDARAVE
Hi all, I am having a issue about input errors (ignored😞
- r1-lnshubcen-I#sh int fa0/0 | in CRC|carrier|counter
  Last clearing of "show interface" counters 20:54:56
     1118 input errors, 0 CRC, 0 frame, 0 overrun, 1118 ignored   <-------------
     0 lost carrier, 0 no carrier
Somebody knows why this kind of errros?
-Also I am seeing high cpu usaged:
r1-lnshubcen-I#sh processes cpu
CPU utilization for five seconds: 79%/48%; one minute: 62%; five minutes: 53%
r1-lnshubcen-I#sh proc cpu | in IP Input
123  3041824160   176252108        991 33.94% 28.01% 19.94%   0 IP Input   <----- this is the process with more proccess
-Show Interface Switching:
r1-lnshubcen-I#sh interfaces switching
FastEthernet0/0 To Office Ethernet
          Throttle count          0
                   Drops         RP          0         SP          0
             SPD Flushes       Fast          0        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs     838680      Drops          0
    Protocol  IP
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
                 Process    2140892  343514039  413392516 3797912625
            Cache misses          0          -          -          -
                    Fast  330142896  864041550    4882833 2831039054
               Auton/SSE          0          0          0          0
    Protocol  DEC MOP
                 Process          0          0       2458     189266
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process     838679   50320740     130199    7811940
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process          0          0      24768    9213696
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process          0          0     148584    8915040
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    NOTE: all counts are cumulative and reset only after a reload.
If more information needed pls let me know.
9 Replies 9
paolo bevilacqua
The number is negligible over the total count, and can be ignored.
However, it may indicate a performance problem and the need to upgrade to a faster router.,
Please post the output of
show proc cpu sorted | ex 0.00
show interfaces
show run
show version
See if you find any logs in show log that could help isolate the problem (Routing protocol neighbor flaps, etc)
It looks like a lot of traffic is being process switched. which is causing the CPU spike.
Leo Laohoo
Omar,
Post the complete output to the command "sh interface Fast 0/0".
Here you go:
r1#sh proc cpu | ex 0.00
CPU utilization for five seconds: 38%/35%; one minute: 35%; five minutes: 19%
PID Runtime(uS)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  45  2316368000     1605730       1442  0.23%  0.22%  0.23%   0 Per-Second Jobs
119   381524000    49678690          7  0.23%  0.21%  0.19%   0 IPAM Manager
123  2167971680   194868665       1002  33.75%  15.22%  23.78%   0 IP Input
154   145596000     8182104         17  0.07%  0.08%  0.07%   0 TCP Timer
interface FastEthernet0/0
description To Office Ethernet
ip address 63.111.142.97 255.255.255.240
ip flow ingress
ip flow egress
duplex full
speed 100
end
r1#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 15.0(1)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sun 18-Jul-10 02:23 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
r1 uptime is 2 weeks, 4 days, 12 hours, 37 minutes
System restarted at 06:59:22 CDT Sat Sep 14 2013
System image file is "flash:c2800nm-advsecurityk9-mz.150-1.M3.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FTX0952C3YE
2 FastEthernet interfaces
6 Serial interfaces
6 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125184K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2811             FTX0952C3YE
FastEthernet0/0 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0016.4651.1c68 (bia 0016.4651.1c68)
  Description: To Office Ethernet
  Internet address is 63.111.142.97/28
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:06:59
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 146000 bits/sec, 75 packets/sec
  5 minute output rate 374000 bits/sec, 84 packets/sec
     37467 packets input, 7137354 bytes
     Received 198 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored        I just clear the counters again...
     0 watchdog
     46754 packets output, 32511142 bytes, 0 underruns
     0 unknown protocol drops
show proc cpu history:
698989888997645566644566667978888987666366264666468888887888656366125421
    514533379360482255142369668489563644775734215282840011439223563764769333
100    *      *                      *
90  * * * ****                * *** *
80  **********               *********               **********
70 ************    **    *****************       *   ***********   *
60 *****#*#*****   ***   *****#**#***#**** ** * *** **######****** **  *
50 **#########********  *****#########**** ** *******#########**** **  *
40 **#########***************#########******* *******#########*******  **
30 *###########**************##########****** *******##########****** ***
20 *###########***********#**###########*************##########***********
10 ##################################################################*####*
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
                  * = maximum CPU%   # = average CPU%
Thank you
Line errors, particularly CRC, can be caused by autonegotiation of speed and duplex being disabled.
The configuration of your interface is showing you hard coded the speed and duplex.  Take these two lines away and observe.
Hi Leo thanks, I tried that but no luck,  and just to clarify the errors are not CRC, they are "ignored errors"
Thank you
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
I believe ignored errors are when a packet is received, but the router doesn't have a buffer to save it in, so it "ignores" it.
This can be caused by the router being unable to keep up with the ingress rate (such as a burst).
As yours appears to be a 2811, a 2811 cannot really sustain wire-rate on its FE interfaces.
Additionally, on your 2811, its average CPU is somewhat busy and your stats show a large percentage of CPU  process switching.  This could be one of the contributors why the 2811 ignores some received packets.  It might be worthwhile to troubleshoot that.
However, as Paolo already noted, your ignored count is such a low percentage, its probably not worthwhile being concerned with.
Vishesh Verma
Level 6
Level 6
Please check the output of following -
show interface stats
show cef not-cef-switched
r1#sh interfaces Fa0/0 stats
FastEthernet0/0
               Processor     987269  126803071  114091142 4083257277
             Route cache   89712848 2569249918    1355427 1978110182
                   Total   90700117 2696052989  115446569 6061367459
r1#sh cef not-cef-switched
% Command accepted but obsolete, see 'show (ip|ipv6) cef switching statistics [feature]'
IPv4 CEF Packets passed on to next switching layer
Slot  No_adj No_encap Unsupp'ted Redirect  Receive  Options   Access     Frag
RP         0       0       16283        0   732103        0        0        0
