INTER VLAN & MULTICAST ?
Didier1966
Level 5
Level 5
I know that the reason for making VLAN's is to create different networks and BROADCAST DOMAINS but .....
At one of our customers some IT guy has put everithing that go over wire CAT 5 cable on VLAN 1 and everithing on Wireless is on VLAN 10.
LAN = VLAN1 = 192.168.1.x/24
WLAN = VLAN10 = 192.168.10.x/24
I can ping from and to both networks , but our customer would like to be able to stream some music from his handheld device (DLNA or AirPlay)  to a device that is connected by cable.
I do not think this will be possible.
Sorry for asking this maybe stupid question but I do not have my CCNA yet , I am still learning
If their any way to create some ACCESS-LIST that will make a MULTICAST possible over both networks ?
At the moment the only thing that the IT guy told me was that he has only 2 ACCESS-LIST :
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip nat inside
ip virtual-reassembly
no cdp enable
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
ip nat inside
no cdp enable
ip nat inside source list 101 interface FastEthernet0/0 overload
ip nat inside source list 110 interface FastEthernet0/0 overload
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 110 permit ip 192.168.10.0 0.0.0.255 any
PS: Just to prove that our streaming SW was working I have put a simple AP point on one of the CAT 5 cables and everithing work fine , but I can not leave this like that.
Any Help is welcome
Thank You in advance.
Best Regards,
Didier
6 Replies 6
gaurav bhardwaj
Level 3
Level 3
beacuse any type of network is permit on these VLAN.
John Blakley
Airplay uses mdns for communication which uses 239.0.0.251 for an address. 239.0.0.251 is a local multicast address and will not leave the subnet/vlan due to its scope. The only way that you'll be able to get Airplay to work is when it's on the same subnet as the device that needs to access it. As far as dlna, I don't have any experience with these appliances/devices, so you *might* be able to get them to work across the subnet, but from what I've read they support UPnP which enterprise Cisco devices do not support.
HTH,
John
HTH, John *** Please rate all useful posts ***
Thank You for your prompt reply , and sorry for my late response
If I understand it correctly their is no way to fake and make it work ?!?
Can VPN be a option ?
Any idea is welcome , it can not be so that nobody has done this before ?!?
Thank You in advance for your help.
Best Regards,
Didier
Is this imposible ?
Didier1966
Level 5
Level 5
Maybe some others have the same question.
I just found a really well made document from CISCO , that explain what to do.
It is in PDF found via GOOGLE so I have attached the link to this post : http://www.google.be/url?sa=t&rct=j&q=airplay%20over%202%20vlan&source=web&cd=5&ved=0CEEQFjAE&url=http%3A%2F%2Flistserv.educause.edu%2Fcgi-bin%2Fwa.exe%3FA3%3Dind1202%26L%3DWIRELESS-LAN%26E%3Dbase64%26P%3D1954676%26B%3D--%253D__Part0C2208FA.0__%253D%...
Best Regards,
Didier
