InterVlan problem using 3750
chamakura.kiran
Community Member
Hi Experts
I have 3750 Series swicth and 2950.
Problem: My Problenm is that i could communicate between same VLAN and even with diffrent Vlans after doing the following configuration.i have attached my configuration.
3750 Configuration:
1. I had configured the 3750 with VLAN 2,3,4,5,6 i have configured VLAN 6 is my Management Vlan.
2. I have enable the routing in 3750.
3. I have made enable the switch trunk encapsulate dot1q.
Switch 2950:
1. I have assigned diffrent port with diffrent Vlans.
16 Replies 16
Hi ,
On which switch PC A and PC B are connected...
Cheers 🙂 MSK
Leo Laohoo
1. Ok ... Where are the following lines:
"vlan 2-5"
You've created the VLAN interface but you haven't created the VLAN.
2. According to your configuration, "PC (192.168.2.251 ) - Int f1/0/6(3750)" is connected to VLAN 1 (default). What is this PC's default gateway when VLAN 1 doesn't have an IP Address?
