IOS Command Defaults
chrisayres
Level 4
Level 4
Is there an easy way to find out whether commands are on or off by default in various versions of IOS
andrew.prince
Level 11
Level 11
Chris
I would suggest you read the specific command reference guide pertaining to the level of IOS and see what the defaults are.
HTH>
