ip nat inside source static & route-map = wrong source address
sepa.spb.ru
Community Member
Hi.
I'm having some problem with source address with NAT of this configuration
lan (192.168.18.0/24) ----- (192.168.18.1) Router (217.x.150.130 /248) ----- inet gw
It's possible to use only 2 ip addresses from 217.x.150.130 /248 network.
I want to nat overload .130 to all lan, use it to connect to router and map some ports from it to lan hosts.
Map full ip .131 to host 192.168.18.4.
I'm using IPSec VPN to other lans too, so here is route-map
interface FastEthernet0/0
description INET
ip address 217.x.150.130 255.255.255.248
ip nat outside
crypto map CISCO
interface FastEthernet0/1
description LAN
ip address 192.168.18.1 255.255.255.0
ip nat inside
ip nat inside source list 175 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.18.3 3389 217.x.150.130 3389 route-map POLICY-NAT extendable
ip nat inside source static 192.168.18.4 217.x.150.131 route-map POLICY-NAT
access-list 175 deny   ip 192.168.18.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 175 deny   ip 192.168.18.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 175 permit ip 192.168.18.0 0.0.0.255 any
route-map POLICY-NAT permit 10
match ip address 175
Ok, i'm get outgoing connection from lan's hosts from public ip .130, and have incoming connections to public .131 going to .18.4. But outgoing connections from .18.4 are going from .130, not from .131. Why?
rk2811#sh ip nat translations | include 18.4
udp 217.x.150.130:123    192.168.18.4:123       85.21.78.91:123       85.21.78.91:123
--- 217.x.150.131        192.168.18.4           ---                   ---
When i'm edit nat mapping of .131 to
(remove policy-map) then i get outgoing ip address .131 like it should be, but host .18.4 becomes unavialable from another end of IPSec VPN (because its answers go to NAT instead of IPSec tunnel)
So here is the question - how to get right outgoung ip addess when  using ip nat inside source static & route-map?
Thanks. (c2800nm-adventerprisek9-mz.124-21)
kert dezcom
Frequent Visitor
Frequent Visitor
It's cause different NAT operational order - look here http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
try
access-list 175 deny   ip host 192.168.18.4 any
and use simple static NAT without route map
kert dezcom
Frequent Visitor
Frequent Visitor
try
Sorry for late answer.
Great thanks for your reply. I've test your code and have no traffic from 192.168.18.4 to other end of IPSec tunnel and back. But i've got you idea and for quick fix make this:
ip nat inside source static 192.168.18.4 217.x.150.131 route-map POLICY2-NAT
access-list 176 deny   ip 192.168.18.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 176 deny   ip 192.168.18.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 176 permit ip host 192.168.18.4 any
route-map POLICY2-NAT permit 10
match ip address 176
Now all seems to working right, outgoing address is .131 for .18.4 and IPSec connection work two-way.
