ip route with exit interface problems
keesepema
Level 2
Level 2
I learned from Cisco CCNA that a directly connected static route specified with an exit-interface has an administrative distance of 0. That seems very promising, because next-hop routes have an AD of 1.
I tried to work with these kind of routes in PacketTracer, but in all occasions packets are dropped at the exit interface.
Inspection of PDU's at the exit-if showed me that the route was found,but on the datalink layer packets were dropped.
I use 1911 routers on both ends and tried to implement a
quad zero route (ip route 0.0.0.0 0.0.0.0 g0/0/0)
and more detailed routes as
ip route 212.10.251.1 255.255.255.252 g0/0/0)
So I wonder in which occasions I should apply such a route?
3 Accepted Solutions
Hi @keesepema ,
This should work, but you need to make sure
ip proxy-arp
is enable on the interface of the router connected to gi0/0/0.
You can do a
show ip int <interface name>
for the interface connected to gi0/0/0 on the facing router to check whether the
proxy arp
functionality is enabled.
This is usually not recommended to configure such a route, as it could could cause the arp cache to grow really big, especially if you configure a default route to the Internet for instance.
keesepema
Level 2
Level 2
Thanks, ip
proxy-arp
is the solution!
Still wondering on which occasion such a route would be best practice......
Hello @keesepema ,
the use of the exit interface in defining a static route was a good alternative for WAN serial links that are point to point and do not create issues with ARP.
But now days most of internet handoffs are provided as ethernet so as noted by @Harold Ritter  the default static route should specify the IP address of the ISP router to avoid excessive ARP entries and to rely on IP proxy ARP enabled on the ISP router interface.
Hope to help
Giuseppe
6 Replies 6
I dont know what issue here, can you share all config ?
Sure!
Here is the config of R1
R1#sh ip route static
S* 0.0.0.0/0 is directly connected, GigabitEthernet0/0/1
R1#sh run
Building configuration...
Current configuration : 719 bytes
version 16.6.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
ip cef
no ipv6 cef
spanning-tree mode pvst
interface GigabitEthernet0/0/0
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/0/1
ip address 10.100.100.1 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/1
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
And here is my R2 config:
R2#sh run
Current configuration : 718 bytes
version 16.6.4
hostname R2
ip cef
no ipv6 cef
ip address 10.100.100.2 255.255.255.252
duplex auto
speed auto
ip address 172.22.22.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
line con 0
line aux 0
line vty 0 4
login
end
R2#
R2#
R2#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
R2(config)#
R2(config)#
R2(config)#end
R2#
%SYS-5-CONFIG_I: Configured from console by console
R2#sh ip route sta
R2#sh ip route static
S* 0.0.0.0/0 is directly connected, GigabitEthernet0/0/0
R2#sh run
version 16.6.4
hostname R2
ip cef
no ipv6 cef
duplex auto
speed auto
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
I also included a png file with the topology regarding this issue.
Hi @keesepema ,
ip proxy-arp
You can do a
proxy arp
keesepema
Level 2
Level 2
Thanks, ip
proxy-arp
is the solution!
That for the feedback @keesepema .
As I mentioned, even though the functionality is there, it is generally recommended to specify the next hop ip address when you configure a static route. I have seen too many cases in the past where people would configure a default static route to the Internet with no
next hop ip address
and you should have seen the size of the arp cache on some of these devices. This could lead to some really bad outages in real life scenarios.
Hello @keesepema ,
Hope to help
Giuseppe
