Load balancing
sumesh_un
Can I have loadbalancing (not loadsharing )configured over two links from the same ISP in both multihomed and single homed architectures?If yes how?
royalblues
Level 11
Level 11
When you are multihomed to 2 different routers, it is not possible to have a perfect loadbalance.
If they are multihomed to single router at both ends, then either you can do a standard CEF loadbalancing or bundle the 2 links into a single logical multilink and do loadbalancing
Narayan
