Memory Usage more
smartboy2255
Level 3
Level 3
HI all,
  I am getting more memory usage in my Cisco router.
show processes memory sorted
Processor Pool Total:  145530560 Used:   91726552 Free:   53804008
      I/O Pool Total:   38796800 Used:   18544224 Free:   20252576
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0   74591920   25592076   42485676          0          0 *Init*
  93   0  115447044    8272732   40966572     759972          0 IP Input
  33   0   14754792        924   13662816     246596          0 Net Background
   1   0   38387880   34542292    4634288          0          0 Chunk Manager
Wat can be the possible reasons for Ip input process holding more memory.My CPU is normal.
Aah.. The memory usage is more due to MallocLite function. This masks who the real culprit of the memory usage is.
You can review this for more info on malloc-lite -
      http://www.cisco.com/en/US/docs/ios/12_3t/fun/command/reference/cfrgt_05.html#wp1084941
Plz post the o/ps of 'show ver | in IOS' and ' show process mem 93'
Meanwhile, also check how many nat translations are present. A 'show ip nat stat' will give that info
-Karthic
6 Replies 6
IP input as you know is the process associated with process switching of packets. I dont expect to see many bugs with this process. Is the 'IP Input' memory utilization remaining stable throughout (or) does it decrease during off-hours? How long you have been facing this. To start with can you post
- show mem stat
- show mem alloc totals (Top 10 functions should be good enough)
- show ver | in IOS
- Karthic
Thanks Karthic for response.While rebooting the router will solve the issue .Memory usage will increase by 2 months.
sh memory statistics
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   65036140   145530560    91718784    53811776    53331068    53515904
      I/O   2DB00000    38796800    18544224    20252576    20078960    20118240
show memory allocating-process totals
Processor   65036140   145530560    91716504    53814056    53331068    53515904
Allocator PC Summary for: Processor
    PC          Total   Count  Name
0x60017580   55064184     821  MallocLite
0x6002E1B8    4628956     144  ipnat entry
0x61ED52B8    3881892       1  Init
0x60487E50    3005576    3561  *Packet Header*
0x60ADFC68    2402836     269  Process Stack
0x61EBFF24    1271552      88  Init
0x60192A8C    1048620       1  Init
0x620C54B8    1029088       8  pak subblock chunk
0x60EE6F3C     843820       1  CCAAL2_CT
0x604AF6A8     558100      27  GigabitEthernet0/0
0x60253C94     491556       1  Init
0x60E39518     483080       7  BGP (0) update
0x60FF4BDC     454656     256  CCSIP_SPI_CONTROL
0x620C4764     450096      36  TW Buckets
0x600174FC     442980       6  MallocLite
0x60E38B74     393480       6  BGP IPv4 path-chunk
0x60E66AD0     393480       6  BGP IPv4 net-chunk(8)
0x628ED21C     369908       1  sfnt flow list
0x604AF730     318536     116  Normal
0x61ED9324     317456      34  Init
0x61D16470     312364       1  RTPSPI
0x60BAB980     286168       2  SWMTPMSP SESSION chunk
0x61009630     282496      32  CCSIP_SPI_CONTROL
0x62990200     268600       8  Init
0x613C4BA8     262320       4  IP Flow cache
0x624F68B4     208136       1  epa crypto blk
0x6053BBF0     199104       6  DSM EVENT pool
0x620B30C0     171948     267  Process
0x60F33FEC     168140       1  CCFRF11_CT
0x610002D8     163884       1  CCSIP_TCP_SOCKET
0x62975FBC     142352       4  ipnat localtree
0x613795F4     133192       4  CEF: 16 path chunk pool
0x625906E8     131900       1  SDEE message buffer
0x600DF3C4     131760       2  XCMSP SESSION chunk
0x6065BDC8     131160       2  IPC Message He
0x613899F4     131116       1  Init
0x604B8CF0     123336       1  IDB List Element Chunks
    PC          Total   Count  Name
0x61F64E50     120044       1  MPLS Event log
0x625D1BA8     119384       4  Init
0x60E393A4     118480       4  BGP (0) attr
0x612B4310     112852       1  DSS Chunk
0x61ED265C     112000    1000  Init
0x61ED25F0     112000    1000  Init
0x621C7128      98436       3  L2TP Hash Table
0x614ACAE0      98348       1  Init
0x61FDBD0C      97248      17
0x62975F04      94452      14  IPv6 CEF fib tables
0x60CFE0F8      90284       1  Init
0x60191160      90156       1  Init
0x6012CF1C      88416       8  dsp channel
0x61EF709C      77244       1  Spanning Tree Opt Port Block
0x610056C8      73772       1  CCSIP_UDP_SOCKET
0x6235AB20      72268       2  XTagATM VC chunk
0x6172D720      72268       2  NAT Port Range Chunks
0x600C6630      69164       1  Init
0x6295D428      68352      64  IP Input
0x6174A05C      67900       2  ipnat node
0x6174A0A4      66844       2  ipnat entry
0x6172D784      66708       2  ip port range array
0x60C63D84      66460       2  CEF: Adjacency chunk
0x6138A3AC      66396       2  CEF: loadinfo chunk
0x6053BB88      66368       2  DSM EVENT pool chunk
0x625A1BAC      66320       2  FW sis
0x600B8208      65964       2  IP mtrie node
0x61D16518      65960       2  RTP SPI chunk
0x60F10844      65844       2  CCAPI Event pool chunk
0x60BB1EB8      65844       2  VTSP EVENT pool chunk
0x60F106F0      65836       2  CC_CALL_ENTRY chunk
0x6172D7EC      65776       2  ip port lists
0x62102D6C      65580       1  eddri_self_event
0x604AF54C      65580       1  Clones
0x611AFA34      65580       1  Parseinfo Blocks
0x6065C8E8      65580       1  IPC Message Header Cache
0x6125CFDC      65580       1  ddb counters struct
0x600BE870      65580       1  DFS stream buffer
0x60864978      65580       1  Mat Addr Tbl Chunk
0x620C3E58      65580       1  Event Manager Event Elements
0x621AE49C      65580       1  VPDN msg chunks
0x621B276C      65580       1  VPDN mgr call chunk
    PC          Total   Count  Name
0x621B279C      65580       1  VPDN mgr mgd timer chunk
0x621ADA4C      65580       1  VPDN call req chunk
0x621AA1C8      65580       1  VPDN user info chunks
0x621E3648      65580       1  l2tun session hdl chunk
0x621E3B10      65580       1  l2tun_session_db entries
0x621D915C      65580       1  L2TP: l2tp_tunneltype chunk
0x621D91D4      65580       1  L2TP mgd timer chunk
0x61790DE0      65580       1  IP RDB Chunk
0x61791B84      65580       1  IP single NDB entry
0x61791BB0      65580       1  IP subnet NDB entry
0x617B7E20      65580       1  IP Static Route Chunk
0x621BB4D8      65580       1  L2F: l2f_tunneltype chunk
0x621BB510      65580       1  L2F: l2f_sessiontype chunk
0x60C79500      65580       1  IVR applDialPeer_t Object Chunk
0x61AFE764      65580       1  OER Prefix Chunk
0x61AFE794      65580       1  OER Policy Ref Chunk
0x61AFE7C4      65580       1  OER Prefix Exit Ref Chunk
0x61AFE7F4      65580       1  OER List Element Chunk
0x61AFE854      65580       1  OER Prefix Active History Chunk
0x625024A8      65580       1  Crypto IKMP kekm
0x62540FF4      65580       1  Crypto Delete Manager
0x621E8A98      65580       1  PPTP mgd timer chunk
0x621E8AD0      65580       1  PPTP: pptp_tunneltype chunk
0x621EA2F0      65580       1  PPTP: pptp_sessiontype chunk
0x61A55794      65580       1  NATMIB Node Chunks
0x620D9D24      65580       1  .1Q[Tree Nodes]
0x60E39574      65580       1  BGP battr chunk
0x61142984      65580       1  AAA DB Chunk
0x60C703BC      62604       1  ivr: appLeg_t
0x600C6644      58412       1  Init
0x60191014      57388       1  Init
0x60192BB4      57388       1  Init
0x620BA3A8      57232      28  Reg Function 1
0x6048FF40      57072      12  *Hardware IDB*
0x6045A820      56044       1  Init
0x60191DBC      55340       1  Init
0x6293036C      54044       1  Init
0x62977A30      52432      28  CCVPM_HTSP
0x611B4908      52380     760  Parser Linkage
0x620B9F50      51100      25  Reg Function 1
0x620B5878      50756     268  Process Events
0x61FDBE48      50240       9  TclAllocateFreeObjects
    PC          Total   Count  Name
0x614B608C      49196       1  CCH323_CT
0x611E82F4      49196       1  SSH Process
0x60C6F9AC      48524       1  ivr: appEvQItem_t
0x600338C4      44224      12  Pool Cache
0x6034525C      43564       1  cd2430 stb
0x629744D0      41216      29  Init
0x61A87C3C      41004       1  Init
0x61A89EB8      39244       1  Init
0x61F03108      38412      99  Syslog History
0x615E5960      37104     205  IP cache
0x61ED9604      36280     201  Init
0x61ECF358      35884       1  Interface AD structure
0x620AC5A4      35512      23  List Elements
0x61C0D4BC      33836       1  QOS_MODULE_MAIN
0x617918C4      33260       1  IP: Control Block
0x620B52A8      33220       5  Watched Queue
0x612A3A28      33204       2  DNS queries
0x604AF744      33200     110  Normal
0x613BA724      32856       2  IP Sub-Flow chunk
0x611FE488      32816       1  Init
0x611AFAB8      32812       1  Parse Nodes
0x600BE780      32812       1  PCMCIAFS LFN Node
0x600BE8C0      32812       1  PFS inode table
0x621ABD10      32812       1  VPDN subblock chunks
0x621D9194      32812       1  L2TP: l2tp_sessiontype chunk
0x61B87A98      32812       1  PPP Context Chunks
0x6296EB78      32812       1  Radix trie mask chunks
0x61A0C77C      32812       1  MPC LEC msg backup chunks
0x61AFE824      32812       1  OER TTC Prefix Chunk
0x61C0D5EC      32812       1  QOS_MODULE_MAIN
0x602EB360      32740       3  Init
0x60E38F04      32620       1  Init
0x60E38E64      32620       1  Init
0x620C0F84      32484      11  Keepalive
0x6018A1F4      30900       1  Init
0x61191F64      30660       7  TTY data
0x6270268C      30136       1  CEF arp throttle chunk
0x62107DB4      29064       6  CC-API_VCM
0x601911D0      28716       1  Init
0x61E0EE1C      27648       1  Init
0x615A3A10      27584      87  Init
0x623EFF50      27548       3  Crypto Engine Object Table
    PC          Total   Count  Name
0x60982508      27376       1  Init
0x6095E98C      27244       1  VNM DSPRM MAIN
0x62107DE0      26944       2  99405978
0x611AC994      26444       1  PM Event Pool
0x611B4DDC      25608     255  Parser Mode
0x61EA0DDC      24592     198  Init
0x6299084C      23688     261  *Init*
0x628E9678      23596       1  Init
0x60CFE14C      23084       1  Init
0x627AEA44      22400       2  Redundancy Event Chunks
0x627AE228      22400       2  Redundancy Eve
0x6259724C      21684       2  IP VFR frag state chunk
0x61397B30      21428       2  CEF: IPv4 Unicast RPF subblock
0x616CAFD4      21092       1  Init
0x626FC9DC      20732       2  ipv6 fib fibtypes
0x625A1C0C      20656       2  FW host entry
0x625A1BDC      20580       2  FW pre-gen sis
0x62400A24      20424       1  Init
0x62698E4C      20424       1  Init
0x62698E74      20424       1  Init
0x623EE5B0      20424       1  Init
0x61BA2EE0      20136       1  PPPoE BKG Chunk
0x60C40BBC      20044       1  Acct Req chunk
0x6002DE4C      20044       1  Managed Chunk Queue Elements
0x60C59B90      20044       1  AC context chunks
0x60C59BBC      20044       1  AC Mgr mgd timer chunk
0x621E3778      20044       1  l2tun session msg chunks
0x61791BDC      20044       1  NET REDIST
0x6086B41C      20044       1  Init
0x60C79ACC      20044       1  IVR applGtd_t Object Chunk
0x6267A144      20044       1  Crypto conntable Chunk
0x6267A170      20044       1  Crypto DHtable Chunk
0x6009EE24      20044       1  DSMP
0x626C1194      20044       1  IPv6 route
0x61146C04      20044       1  AAA Acct DB chunk
0x620B7B74      19868       1  Watched Bitfield
0x60ABA3F8      19244       1  TSP cdb initial
0x601E7000      19040     268  Init
0x60CC1110      18804       1  ais appinst
0x61FA04A4      18612      99  Init
0x6065C96C      18000     100  IPC Message
0x61E2EFA0      17816     203  Init
    PC          Total   Count  Name
0x611B4E4C      17564     255  Parser Mode Q1
0x611B4E70      17444     255  Parser Mode Q2
0x6297EF7C      17152      16  Index Table Block
0x6048FF5C      17136      12  *Software IDB*
0x600B4818      16428       1  Init
0x60190F58      16428       1  Init
0x60E392AC      16428       1  Init
0x60E39204      16428       1  Init
0x60E3923C      16428       1  Init
0x60E39290      16428       1  Init
0x613C4A7C      16428       1  IP Flow cache hash table
0x601AD6B8      16176       1  Init
0x6044E6F0      15600     150  Init
0x60E391E8      15316       1  Init
0x60E38E44      15316       1  Init
0x620B5014      15132       3  Watcher Info
0x627B63EC      14848     128  Init
0x624CA7F0      14848     128  Init
0x62696538      14380       1  Init
0x6138A37C      14136       1  CEF: arp throttle chunk
0x620EEC10      13644       1  FLEX DSPRM MAIN
0x61ED9910      12976     132  Init
0x6219BBE8      12848       1  CCSIP_SPI_CONTROL
0x612372D8      12828       1  DHCPD Message Workspace
0x60E3915C      12516       1  Init
0x60E391CC      12516       1  Init
0x60E38E04      12516       1  Init
0x620C5528      12468       2  pak subblock chunk
0x6242FDA4      12420       3  SSH2 Buffer
0x60E3900C      12404       1  Init
0x61CF6164      12336       1  RSVP DB Handle Bin
0x614FF29C      12332       1  Init
0x616E525C      12044       1  Init
0x61ED23E0      11428     101  Init
0x61ED2460      11280     100  Init
0x61134020      11244       1  AAA attr list handle IDs
0x626FF2C8      10804       2  ipv6 fib path lists
0x626FD608      10680       2  ipv6 fib paths
0x625A1C3C      10680       2  FW SID
0x606529C0      10536       1  IPC port info
0x61749F00      10336       2  NAT String Chunks
0x620D9D5C      10304       1  .1Q[Tree Headers]
    PC          Total   Count  Name
0x620D9D94      10304       1  .1Q[Array Headers]
0x6174D9F0      10304       1  NAT Address Chunks
0x60D8C994      10284       1  ATMSIG-SHOW
0x60E39468      10080       1  BGP gwcache-chunk
0x626C11C4      10080       1  IPv6 adj
0x620B7B1C      10044       1  Watched Queue
0x620B7B48      10044       1  Watched Boolean
0x624C4368      10044       1  CPF Message Desc
0x6155253C      10044       1  Pathents for parsing
0x600BE7D0      10044       1  DFS Sector
0x608649A4      10044       1  Mat Addr Entry Chunk
0x60C59DC4      10044       1  AC msg chunks
0x61BA2E80      10044       1  PPPoE SB Chunk
0x61BA2EAC      10044       1  PPPoE ETH SB Chunk
0x613CECBC      10044       1  NetFlow Template Chunks
0x61E2F168      10044       1  SNMP SMALL CHUNK
0x61E2F1B4      10044       1  SNMP MEDIUM CHUNK
0x6205FE58      10044       1  Time Range Entry Chunks
0x62246358      10044       1  VACCESS info block chunk
0x626963CC      10044       1  SADB SA Header List Chunk
0x62696428      10044       1  SADB RootChunk
0x61173F58      10044       1  Init
0x60A5ED04      10044       1  DDP UDP tx  Chunk
0x61148C68      10044       1  AAA Acct Rec chunk
0x615A3A1C       9844      87  Init
0x61809FF8       9760       8  TCP CB
0x60C3BF70       9644       1  NET ACCT LISTS
0x60C3BFB8       9644       1  SYS ACCT LISTS
0x62978244       9376      56  CCVPM_HDSPRM
0x61E28280       9216     134  SNMP Trap
0x613718B4       9092       1  EM Applet Director
0x60C336F0       8844       1  PPP ACC LISTS
0x61983BF4       8840     130  ivr: ms_event_t
0x60CCD4B8       8684       1  asnl: appEventInfo_t
0x61DEB190       8280       2  Network Services Timer Wheel
0x60BA7A48       8240       1  L2TP Session ID Table
0x600B4A8C       8236       1  FileSys Scratch
0x60129CA0       8236       1  Init
0x621AEDF4       8236       1  VPDN MGR hash table
0x621D95FC       8236       1  l2tp tnl table
0x6150D780       8236       1  Init
0x6172B318       8236       1  Init
    PC          Total   Count  Name
0x6172B32C       8236       1  Init
0x61791C4C       8092       1  IP PDB
0x617B7F3C       8092       1  IP PDB
0x60E39338       8092       1  BGP fcache-chunk
0x60E398C0       8092       1  Init
0x60C33738       8044       1  NET AUTHOR LISTS
0x622463DC       7980       1  VTEMPLATE request info
0x60033328       7820      23  Pool Info
0x622463B0       7304       1  VTEMPLATE current process info
0x61ED26F8       7304      65  Init
0x611A3218       7212       1  Init
0x60191458       7212       1  Init
0x61ED2778       7168      64  Init
0x60490CB0       7140       5  *Software IDB*
0x612EFC04       7080      37  Entity MIB API
0x61283960       6720      50  DialControlMib Element
0x601B2EDC       6560       1  Init
0x61223530       6276       3  Init
0x61223574       6276       3  Init
0x612235AC       6276       3  Init
0x61877254       6112       8  ivr: tclScript_t
0x620A59A4       6096       1  Alignment Data
0x611A3118       6088       2  keepalive sb chunk
0x6119CE54       6056       1  TTY timers array
0x61BCC234       6056       1  Init
0x62576EA0       5980      13  Init
0x60E39300       5956       1  BGP rcache-chunk
0x626CFE74       5936       4  IPv6 PDB
0x6176A490       5804       2  ip nat wlan address
0x612038D8       5788       5  AAA Interface Struct
0x6269652C       5752       1  IPSEC debug rate limit array Chunk
0x60E38BB4       5728       6  Init
0x60A89FE0       5708       1  VLAN Manager
0x61F3C094       5648       1  Init
0x61791AF8       5644       1  IP: Cblk-table
0x613895FC       5644       1  CEF: Root-table
0x6138961C       5644       1  CEF: Cblk-table
0x61392428       5644       1  Init
0x61391EBC       5644       1  CEF: HWIDB MAP TABLE
0x61C48DB8       5644       1  Init
0x617CE038       5644       1  Init
0x60163E54       5644       1  mxt5100
    PC          Total   Count  Name
0x62980350       5600      62  Init
0x62961708       5580      31  ENTMIB entPhysicalTable RBTree
0x625708D8       5544       1  EzVPN Client Process
0x6289CCC8       5536       2  Srtp stream chunk
0x60E86BA8       5532       1  Init
0x610C8068       5532       1  Init
0x602EBAD0       5488       4  FLEX DSPRM MAIN
0x612A3A04       5428       2  DNSquery structs
0x60BBFE5C       5424       4  FLEX DSPRM MAIN
0x6109E2C0       5412       1  CLNS Static PDB
0x6109E374       5412       1  CLNS ESIS PDB
0x610C0488       5412       1  BGP's CLNS Neighbors PDB
0x610C063C       5412       1  BGP's CLNS routes PDB
0x615A12C8       5380       5  Init
0x62597328       5340       5  IP VFR frag table
0x626C10C4       5292       1  IPv6 Static
0x6242FE08       5252       3  SSH2 Buffer
0x6289CD28       5216       2
0x61C0D530       5164       1  QOS_MODULE_MAIN
0x626F15C4       5164       1  Init
0x6242FFA0       5164       1  SSH2 Buffer
0x60CFE124       5084       1  Init
0x620AD82C       5044       1  List Headers
0x620B7BCC       5044       1  Watcher Info
0x6154CAB4       5044       1  File Descriptors
0x600BE820       5044       1  Super Dir entry
0x6064A908       5044       1  FEC XDR chunk
0x60C3F744       5044       1  AAA chunk
0x613A70A0       5044       1  CEF: up event subblock chunk
0x6272E78C       5044       1  RIPv6 routes
0x615E8FAC       5044       1  IP cache bitfield chunk
0x615271AC       5044       1  HTTP_SMALL_CHUNK
0x61A0C738       5044       1  MPC LEC msg chunks
0x615C14DC       5044       1  ip localpool
0x62696378       5044       1  SADB SA Info Chunk
0x626963F8       5044       1  SADB Peering Chunk
0x62696458       5044       1  IPSEC Ident list Chunk
0x626964AC       5044       1  IPSEC TED Chunk
0x62696500       5044       1  IPSEC SA sibling Chunk
0x6267A19C       5044       1  Crypto flowtable Chunk
0x61D68760       5044       1  SAA Hash Element Chunk
0x61067C38       4992      32  Init
    PC          Total   Count  Name
0x61392118       4960       8  CEF: FIBHWIDB
0x60E39400       4944       1  BGP attrlist-chunk
0x6173EA1C       4708       1  IPNat Skinny appl data
0x60C3F93C       4684       1  AAA Acct AVLnode chunk
0x617E9704       4448       8  DHCPD Receive
0x6118EB80       4380       1  TTY data
0x62245A58       4380       1  VTEMPLATE TTY
0x609AECB8       4368       1  Init
0x6297ECC0       4320       4  Minmax8u
0x62084198       4300      25  RIF Cache
0x60E39074       4244       1  Init
0x62400A48       4208       1  Init
0x623EE5D4       4208       1  Init
0x609D4FB0       4184       2  Init
0x60E3949C       4180       1  BGP NLRI-chunk
0x62427794       4152       1  SSH memory
0x62428948       4152       1  SSH memory
0x62540E40       4144       1  Crypto Delete Manager
0x62540E54       4144       1  Crypto Delete Manager
0x62540E70       4144       1  Crypto Delete Manager
0x62540E84       4144       1  Crypto Delete Manager
0x62540EA0       4144       1  Crypto Delete Manager
0x62540EB4       4144       1  Crypto Delete Manager
0x600C6618       4140       1  Init
0x6018A220       4140       1  Init
0x6018A22C       4140       1  Init
0x6018A238       4140       1  Init
0x6018A244       4140       1  Init
0x60192A40       4140       1  Init
0x625A1B2C       4140       1  FW hash tbl
0x6152717C       4140       1  HTTP
0x628E94A4       4140       1  Init
0x61C0D648       4140       1  QOS_MODULE_MAIN
0x61ED6234       4140       1  Init
0x60E38F84       4132       1  Init
0x60E38FA4       4128       1  Init
0x60E390DC       4128       1  Init
0x60E38F44       4124       1  Init
0x60E38F64       4124       1  Init
0x60E38FD4       4124       1  Init
0x60E38FF0       4124       1  Init
0x60E390A4       4124       1  Init
    PC          Total   Count  Name
0x60E390C0       4124       1  Init
0x60E39124       4124       1  Init
0x60E39140       4124       1  Init
0x60E38E24       4116       1  Init
0x60E39054       4116       1  Init
0x611956E4       4088       2  TTY Input Buf
0x611D8EA0       4080       3  Graphit Client
0x623FB710       4048       1  Init
0x6289CDB4       4048       1  Init
0x6048D224       4044       1  Packet Elements
0x624B53A8       4032       1  AUTH-PROXY hash pointer
0x60AB9F28       4012       1  tsp_init_input_queue
0x60F34320       4004       1  Init
0x62978220       3900      56  CCVPM_HDSPRM
0x604CB4D8       3876      57  Init
0x60E01C30       3820       1  Init
0x611B73B4       3816       8  Chain Cache No
0x617FEB1C       3696      12  IP SNMP
0x625D1600       3672      54  Init
0x6035FBA8       3648      48  CDAPI-RtgTbl
0x6267A05C       3628       1  Init
0x6267A078       3628       1  Init
0x6267A098       3628       1  Init
0x6009FFE0       3552       2  DSMP EVENT chunk
0x61E0C804       3444      39  Init
0x60F3A4F8       3428       1  CCH323_CT
0x60975EF0       3408       4  FLEX DSPRM MAIN
0x613912E8       3320      42  CEF: IDB namestring
0x6174A19C       3260       2  NAT door Chunks
0x60F0D52C       3240      10  FLEX DSPRM MAIN
0x60BAB9F0       3240       2  SWMTPMSP APPS chunk
0x606200BC       3236       1  logical-tab-phy-ports
0x6051642C       3220       2  dot11 auth client chunk
0x61511F38       3200      35  HTTP
0x62977A44       3132      28  CCVPM_HTSP
0x60CEBAA4       3084       3  Init
0x626FC06C       3080       7  IPv6 CEF not-sw cnt
0x620C11D4       3044       1  CCA CLA chunks
0x620B7C50       3044       1  Read/Write Locks
0x620C06B4       3044       1  CCA CCB chunks
0x60CCD1BC       3044       1  ARP Entry
0x600BE730       3044       1  FDNODE
    PC          Total   Count  Name
0x60C63DB0       3044       1  CEF: Protocol adjacency chunk
0x6157DCF4       3044       1  IP Addresses
0x61E8D6DC       3044       1  SSS Test client timer chunk
0x621DDD78       3044       1  L2X Xconnect VC
0x621F6CF8       3044       1  L2X socket chunk
0x615862A8       3044       1  IPAD DIT chunks
0x61393DE4       3044       1  FIB: traceback nodes
0x613A7074       3044       1  CEF: up event chunk
0x6205FE84       3044       1  Time Range Item Chunks
0x613AADD0       3044       1  CEF: Adj Event Chunk
0x62549BF4       3044       1  Crypto ACL Commands
0x626963A0       3044       1  IPSEC transient spi Chunk
0x62678CB0       3044       1  Crypto Dropped Packets Chunk
0x62113634       3044       1  vurimib chunk
0x61391154       3024      13  CEF: FIBIDB
0x61ED5A9C       3008      24  Init
0x625D3990       2940      38  Init
0x6012CCB8       2924       1  dsp
0x6065DA4C       2916       8  IPC Thread Slot
0x61E28094       2896       1  SNMP trapObjectSyntax Pool
0x625D1668       2856      42  Init
0x60319750       2800      20  CCVPM_HDSPRM
0x625C60A8       2728      40  Init
0x61AFE270       2680       2  MC MSG
0x6296A5FC       2664      37  Init
0x6296A5D8       2628      37  Init
0x6296A5C0       2624      37  Init
0x6139B290       2604       1  FIB: event log data
0x61999ED4       2604       1  ivr: msw_genericStream_t
0x61067C08       2560      32  Init
0x62554D4C       2544       1  IPSEC key engine
0x62554D08       2544       1  IPSEC key engine
0x61274298       2536       1  dialer_ckt_swt_pool
0x609D4D3C       2488       2  Init
0x6148FF34       2488       1  CCH323_CT
0x61544CBC       2484      23  IfMib Element
0x61EE5DBC       2484      27  Init
0x611B74A8       2480       5  Chain Cache No
0x611B4834       2480      36  Init
0x60CCD948       2444       1  asnl: asnlRegEvent_t
0x60F30718       2440       1  Init
0x61D72744       2440       2  Init
    PC          Total   Count  Name
0x60656084       2436       3  IPC Port
0x60E01BB4       2412       1  Init
0x61544C10       2392      23  SNMP IDB
0x61511B70       2380      35  HTTP
0x60F6F648       2348       1  CCH323_CT
0x6289CCFC       2344       2
0x61733020       2320       2  NAT Fragment0 Chunks
0x61ED1D6C       2268      29  Init
0x62961684       2240      28  Init
0x615A1460       2240      28  Init
0x615483DC       2200      23  Init
0x6065C9BC       2176      32  IPC Fragment
0x625C6068       2176      32  Init
0x6033E9BC       2156       1  Init
0x620B1814       2152       2  Process Array
0x606EDA80       2144       2  HWIC GE AF filter
0x609D4F78       2136       2  Init
0x60C45594       2136       2  AAA mlist ID table
0x606C7D38       2136       2  Init
0x606C7D54       2136       2  Init
0x6139AB1C       2136       2  CEF: Adjacency Epoch Stats
0x614ACBB0       2136       2  CCH323_CT
0x6174CBF0       2136       2  Init
0x6174CC0C       2136       2  Init
0x61E2F954       2092       1  Init
0x602AB0C8       2092       1  Init
0x6018A250       2092       1  Init
0x60191508       2092       1  Init
0x61157D64       2092       1  AAA SG ID table
0x628E939C       2092       1  Init
0x60D53F1C       2092       1  ATM PVC Discovery
0x60C448BC       2092       1  AAA mlist ID table
0x60D0F584       2088       3  Init
0x61A8818C       2064       1  Init
0x600A0010       2052       2  DSMP DSP REQ chunk
0x6206CD34       2048       1  Track object table
0x620B9E80       2044       1  Reg Function 12
0x60299FCC       2044       1  fslib file record pool chunk
0x61E2F208       2044       1  SNMP BIG CHUNK
0x6127899C       2044       1  DIALER FWD Requests
0x61C4CCC0       2044       1  Transmit Queue Entries
0x626C11F4       2044       1  IPv6 backup
    PC          Total   Count  Name
0x60E39434       2044       1  BGP worktype-chunk
0x60E01B38       2028       1  Init
0x628E98C8       1996       1  Init
0x606ECB08       1976       2  Init
0x62421790       1968       6  GENERAL_DB
0x6136EFFC       1908       3  EM Server
0x600AD614       1880       1  Dev: Chip Info
0x60BAB9B4       1880       2  SWMTPMSP SESSION chunk
0x61EE5A14       1836      27  Init
0x6272869C       1836      27  Init
0x61A01B24       1828       1  Init
0x6173305C       1828       2  NAT Fragment Packet Chunks
0x62677200       1776      26  Init
0x60F167BC       1768      17  Init
0x6027F0B4       1748      23  *Init*
0x625BCA0C       1744       2  FW SCCP CALL CTXT
0x6061DCB0       1736       1  ESWILP NMs table
0x629779FC       1728      24  CCVPM_HDSPRM
0x60ADF6E4       1684      10  Process Signals
0x62977A58       1668      24  CCVPM_HDSPRM
0x6210D950       1660       1  Init
0x61D7730C       1648       4  SAA StatsTable
0x61E0FD8C       1612      13  Init
0x61195714       1600       2  TTY Output Buf
0x606C5AA4       1580       1  Init
0x61162D50       1576      13  ACL Header
0x620AD7E8       1544       1  List Elements
0x620B7AC0       1544       1  messages
0x620B7AF0       1544       1  Watched messages
0x600B7110       1544       1  GBIC_SECURITY_UNIQUE
0x620B7BA0       1544       1  Watched Semaphore
0x620B7C24       1544       1  Watcher Message Queue
0x620B9EAC       1544       1  Reg Function iList
0x620B9ED8       1544       1  Reg Function Caselist
0x61190938       1544       1  String-DB entries
0x61190964       1544       1  String-DB owners
0x6065278C       1544       1  IPC Split Init Func Cache
0x606528D8       1544       1  IPC Split Init Func Cache
0x61A89EF0       1544       1  NTP Chunk
0x621F6D48       1544       1  L2X socket mgd timer chunk
0x6205FEB0       1544       1  Time Range User Chunks
0x6272E760       1544       1  RIPv6 paths
    PC          Total   Count  Name
0x623F0180       1544       1  Crypto requests
0x615772D0       1544       1  Syslogd Messages chunk
0x605D7948       1544       1  DTP messages
0x6174A440       1544       1  IPnat ESP chunks
0x617E9648       1504       8  DHCPD Receive
0x6152CA04       1472      12  HTTP
0x6116B874       1428       1  Connection
0x6267CD5C       1416       1  Crypto Background Requests
0x615525B4       1412       1  Init
0x614BD3D4       1392      12  Init
0x6176A460       1380       2  ip nat mac address
0x620C3314       1368       3  uBT ATM VC
0x6154B780       1344      16  Init
0x61790744       1344      12  IDB: IP Routing
0x6296EB88       1332       9  Init
0x620C3F8C       1328       4  Event Manager Table
0x61DA4F10       1296      12  IfMib Element
0x60CF8B28       1284       3  Init
0x6154B74C       1280      16  Init
0x6068C0D4       1244       1  FLEX DSPRM MAIN
0x61BEECCC       1232       4  CLASSMAP_MODULE
0x61BF029C       1232       4  Runtime matchparams
0x617EBB44       1224       6  HTTP CORE
0x611C3954       1216      16  Parser Alias
0x629563AC       1216      16  Init
0x612F9818       1200       4  Init
0x6138924C       1196       1  CEF: Control Block
0x613896A4       1196       1  CEF: rdb
0x61BEF700       1184       8  CLASSMAP_MODULE
0x604CB968       1184       8  Init
0x60DF8164       1164      17  *Init*
0x61ED3C4C       1160       2  Init
0x62434770       1120       2  SSH2 memory
0x612389B8       1112       2  DHCPD Radix Information Nodes
0x617EB928       1112       2  FLEX DSPRM MAIN
0x62956398       1092      16  Init
0x611C397C       1088      16  *Init*
0x61C4CCEC       1084       1  In Queue Entries
0x61242268       1072       1  DHCPD Database Workspace
0x611909A8       1068       1  String DB Hash Table
0x600B4894       1068       1  Init
0x600B4910       1068       1  Init
    PC          Total   Count  Name
0x60192A0C       1068       1  Init
0x61158004       1068       1  AAA SG ID table
0x60C5A624       1068       1  AC HANDLE IDs
0x60C63DC0       1068       1  Init
0x61E8C230       1068       1  SSS HANDLE IDs
0x600DF944       1068       1  SSS Switch Handle
0x61E951F8       1068       1  SSF cfg circ handle table
0x621C90B4       1068       1  L2TP Reverse Tunnel Lookup Hash Table
0x62702660       1068       1  Init
0x61B6189C       1068       1  PPP HANDLE IDs
0x610C1BB8       1068       1  CLNS adjacency database
0x6138A34C       1068       1  Init
0x6112BB70       1068       1  Init
0x60DBA558       1068       1  ATMSIG-VCD-ALLOC
0x625C5F80       1068       1  Init
0x61A07238       1068       1  Data Train
0x61978BA0       1068       1  Init
0x6298F0D4       1068       1  Init
0x61134A8C       1068       1  AAA attr list handle IDs
0x60D25768       1068       1  vc hashtbl
0x60E39220       1068       1  Init
0x60E39258       1068       1  Init
0x60E39274       1068       1  Init
0x60E392C8       1068       1  Init
0x61ED61A4       1068       1  Init
0x617330E0       1064       1  Init
0x61733118       1064       1  Init
0x61E38F74       1040       4  SWIDB_SB: SRB Info
0x61162D64       1032      12  Init
0x617E9738       1032       6  HTTP CORE
0x6018CFF8       1028       1  Init
0x60D53F4C       1028       1  ATM PVC Discovery
0x620C0EA4       1012      11  CCA Component
0x60CC2418       1000      10  aisAppRecord
0x627A998C        992       8  *Init*
0x61545CD4        988      12  Init
0x620B7BF8        972       1  Watched Message Queue
0x60118B78        972       9  DTP Protocol
0x61545D5C        968      12  Init
0x61A5F730        960       6  SWIDB_SB: NETBIOS Info
0x611D4A30        952      14  Cond Debug definition
0x60E7A478        948       1  Init
    PC          Total   Count  Name
0x60E86B94        948       1  Init
0x610C8054        948       1  Init
0x60E848B4        948       1  Init
0x626F2A94        948       1  Init
0x626F1018        948       1  Init
0x61134AA8        948       2  Copy lists
0x61545D88        940      12  Init
0x62930250        932       1  Init
0x60C54F1C        924      13  Init
0x61DA4F28        924      12  IfMib Elem Data
0x60D46AFC        920      10  Init
0x60C3C004        908       1  EXEC ACCT LISTS
0x624C58CC        900       5  Init
0x620D54E0        900       3
0x60D562B4        892       1  ATMSIG-SDB
0x629652CC        884       4  Init
0x621A1FA4        884       1  VOIP_RTCP
0x60CC2444        872      10  aisApp url
0x60ED86F8        868      10  ivr: ccapAppEntry_t descr
0x61D6EBA4        868      12  SAA Scheduler saaComponentLink_t
0x61525634        868       1  HTTP
0x6012CE94        864       8  dsp voice channel
0x6012D2D4        864       8  dsp sig channel
0x604F3EFC        860       1  CSM data
0x60BD69B8        860       1  Init
0x620C0F14        856      11  CCA Notification Flags
0x62245D34        848       1  Vitual Template Info Table
0x61190990        844       1  String-DB handles
0x6060E8E4        844       1  ESWILP_OIDB
0x608649D0        844       1  Mat Port List Chunk
0x621F6D24        844       1  L2X socket mgd timer chunk
0x61E2F2FC        844       1  SNMP VB CHUNK
0x60AB5868        844       1  CRM call update events chunk
0x61C53730        844       1  Translation rule chunk
0x615E9418        844       1  IP Cache Info Chunk
0x613969F0        844       1  CEF: RemoveReceiveHash Entries
0x62246408        844       1  VTEMPLATE propagate chunk
0x61A01B7C        844       1  Init
0x62502500        844       1  Crypto IKMP spi seq
0x60163E88        844       1  mxt5100
0x6174A47C        844       1  IPnat ESP spi-match chunks
0x617C89EC        840       2  Init
    PC          Total   Count  Name
0x60C33774        836       1  LOGIN ACC LISTS
0x620C472C        820      12  TW Wheels
0x62480580        816       2  Crypto CA
0x6061FD44        812       1  ESWILP VLAN MAC addr table
0x602E243C        796       1  CBWFQ Module
0x601298D8        792       2  Init
0x61E0C7F0        792      11  Init
0x62972388        764      10  Init
0x60C337B0        764       1  SHELL AUTHOR LISTS
0x61A83AA0        764       1  Init
0x60ED8694        760      10  ivr: ccapAppEntry_t
0x604CB660        748      11  Init
0x61A5C43C        744       6  SWIDB_SB: NETBIOS Info
0x60E38BD0        740       6  Init
0x60E5F8D8        724       1  Init
0x6069AAA4        720       4  Init
0x618772B0        720       8  ivr: tclScript_t description
0x626CFEC8        708       4  Init
0x6065DA34        704       8  IPC Thread
0x61088360        704       6  CDP sw subblock
0x60D53F7C        696       1  ATM PVC Discovery
0x60D46B3C        684      10  Init
0x60DBFB30        684       1  ATMSIG-SCP
0x625A1EB8        684       1  FW SIP call info
0x623D0664        680       2  Init
0x60D56F98        680       2  ATMSIG-SVC
0x60CC2430        680      10  aisApp app name
0x60ED86B4        680      10  ivr: ccapAppEntry_t name
0x600C668C        660       3  Init
0x6106F254        656       2  atm vcd info
0x612B893C        652       6  DSS-SB
0x60F0D21C        648       2  lib_off_app
0x620D5274        648       2  DOT1Q HW subblock
0x6083D30C        644       1  Init
0x6012CE58        640       8  Init
0x62977058        640       8  Init
0x61398BF0        636       5  CEF: FIBSWSB control
0x61520AC8        620       1  HTTP
0x61A01AD8        616       1  Init
0x61C9154C        616       6  Init
0x61132E74        612       7  AAA MI SG NAME
0x60C54E18        608       8  Init
    PC          Total   Count  Name
0x60AA3FE4        604       1  TGRM Trunk Groups Head
0x62556EC4        600       1  Init
0x60A8AD40        600       5  VLAN Manager
0x60E8B4E0        596       1  Init
0x60E58FCC        596       1  Init
0x61A8A7FC        592       1  Init
0x620CAC30        592       4  DOT1Q SW subblock
0x6138A3D8        588       2  CEF: walker chunk
0x612A3A54        588       2  DNS packet construction
0x61749EC0        588       2  IP NAT alias wait
0x6174A15C        588       2  NAT Route Chunks
0x625972D0        584       5  IP VFR swsb
0x626DFAC4        580       1  Init
0x6117E640        580       2  AAA Attr String
0x6172892C        580       2  IPnat DNS delta info
0x6049E078        564       8  Init
0x613BB10C        564       1  IP Sub-Flow hash flags
0x60C754B0        560       4  ivr: appManager_t
0x61548A10        556       6  IFINDEX hw subblock
0x61187AA8        556       1  Init
0x600B498C        556       1  Init
0x621C4FDC        556       1  L2X tunnel handle IDs
0x624C1344        556       1  AUTH-PROXY wlist hash
0x624F40D8        556       1  DFP Agent CB
0x61A800A4        556       1  Init
0x613BB1B8        556       1  IP Sub-Flow chunk pointers
0x61A7E91C        552       1  Init
0x611A0AA8        544       5  MAC ADDR subblock
0x60652808        544       1  IPC Split Init level
0x60652944        544       1  IPC Split Init level
0x625C6098        544       8  Init
0x62553BD4        544       1  cryptoflow
0x62696484        544       1  IPSEC If MAP Chunk
0x626964D4        544       1  IPv6 IPsec ACE struct chunk
0x61545468        544       8  Init
0x61545480        544       8  Init
0x604CB97C        544       8  Init
0x623383FC        544       8  Init
0x61877298        544       8  ivr: tclScript_t name
0x61A7E930        544       1  Init
0x6179F140        536       2  BGP Router
0x623E80A8        536       1  crypto sw pk proc
    PC          Total   Count  Name
0x60530D20        528       2  VTSP
0x6206CD10        524       2  Track object
0x6196C260        524       1  LLC CB
0x611B42BC        524       1  Init
0x61198DF0        524       1  SSH Process
0x61094C64        520       5  Init
0x606EDC68        516       6  HWIC GE AF entry
0x60C2C6EC        516       1  Acct system ustruct
0x61223548        516       3  Init
0x6174A2F4        508       1  IPnat special port info chunks
0x626E6810        504       2  Init
0x600DBCF8        496       4  Init
0x606F33CC        496       2  Init
0x60DE0F24        496       4  Init
0x60DE1298        496       4  Init
0x620EDADC        496       4  FLEX DSPRM MAIN
0x613ACFE8        484       4  CEF: NAT subblock
0x611AFA8C        476       1  Chain Cache Nodes
0x606525DC        476       1  IPC Global Info
0x60652600        476       1  IPC Global Cache Info
0x61C59238        476       1  Translation profile queue chunk
0x62246384        476       1  VTEMPLATE swidb queue chunk
0x61634894        476       1  Multicast VIF - BindQ
0x604CBB94        476       7  Init
0x60E394D0        476       1  BGP SNPA-chunk
0x6174A2B8        476       1  IPnat PPTP info chunks
0x620C3E84        464       4  Event Manager Queue
0x611916DC        464       1  SDB Owner info
0x61157B7C        464       4  Init
0x61D776A4        456       2  SAA LatestStats
0x604904F0        448       5  Init
0x6065C930        444       1  IPC Msg Cache
0x6155A75C        444       1  Init
0x61E945E8        444       1  SSS Relay Context Handle Table
0x61FA041C        444       1  Init
0x6068C0C0        444       1  FLEX DSPRM MAIN
0x61A8CC9C        440       5  Clock buffer
0x6028D0A8        436       5  Init
0x6028791C        432       4  HW Timer Structure
0x6154D620        432       6  Init
0x620D4B04        432       3  Init
0x61736C1C        428       2  IPnat DNS RR p
    PC          Total   Count  Name
0x6030BD70        428       1  CCVPM_R2
0x6119F440        424       2  Per VC Queue
0x61989DD4        420       1  ivr: mediaContent
0x60E66A7C        420       6  Init
0x6174A3CC        420       2  NAT IPSec Cookie Chunks
0x611E6AC8        416       2  Init
0x611E6AE8        416       2  Init
0x611E6B08        416       2  Init
0x6115D474        412       1  AAA Server handle
0x60E66AA8        412       6  Init
0x60C44C98        408       3  AAA MLIST
0x611AFA60        408       1  tokenQ node
0x6009EB50        408       6  Init
0x61DD76C8        408       3  SDP Library
0x62338280        408       6  Init
0x60E38AF0        408       6  Init
0x6174A384        408       1  IPnat RAS appl info chunks
0x61A83AAC        404       1  Init
0x6128361C        400       3  DialControlMib Element
0x606F33FC        400       2  Init
0x60490534        396       5  Init
0x60D58C3C        392       2  ATMSIG-PRTY
0x60C637A4        388       1  CEF: NULL adjacency
0x60C6383C        388       1  CEF: NULL (drop) adjacency
0x60C638E0        388       1  CEF: PUNT adjacency
0x60C6396C        388       1  CEF: DROP adjacency
0x60C639F8        388       1  CEF: Glean adjacency
0x60C63A84        388       1  CEF: Discard adjacency
0x60C63B10        388       1  DoS Punt adjacency
0x60C63BAC        388       1  CEF: Default route adjacency
0x60DE1034        388       4  Init
0x61F029AC        388       1  Syslog History
0x6069C5C0        384       4  Init
0x601261F0        384       4  Init
0x625D36A0        384       4  Init
0x61132694        384       2  AAA SG HEAD
0x6109DE18        380       1  CLNS cache inval
0x617288D8        380       2  IPnat DNS RR ptrs
0x617EB81C        376       2  FLEX DSPRM MAIN
0x61BEF780        376       2  Runtime classmap
0x600AD5F4        372       1  Dev: Cons Info
0x61C59BC8        372       1  SED chunk
    PC          Total   Count  Name
0x60F0CEC4        372       1  CC-API_VCM
0x6116EF34        368       1  Init
0x6028D498        364       5  Init
0x606504B8        364       1  IPC Seat Manager
0x606504C8        364       1  IPC Seat Manager
0x61EF704C        364       1  Spanning Tree Opt Tree Block
0x621E4E94        364       1  VPDN User Failure ID Hash Table
0x621E4F00        364       1  VPN User Failure Name Hash Table
0x6025B8D0        360       2  Init
0x60126524        360       1  Init
0x61BEF814        360       2  CLASSMAP_MODULE
0x626A87E4        360       5  ipsmRing
0x6174CF7C        360       2  Init
0x609AF118        356       1  VLAN Manager
0x626CFE88        356       4  Init
0x604AF380        352       4  MTU RANGE SUBBLOCK
0x6115C814        352       2  AAA Public Server Group
0x60D58CA0        352       2  ATMSIG-CPB
0x626A8810        352       5  Init
0x6085D0B8        348       1  TDM Clock Information
0x60699D28        344       1  Init
0x606EC154        344       2  Init
0x606F39AC        344       2  Init
0x60D58CCC        344       2  ATMSIG_PORTLIST
0x61B405D4        344       1  X25PAD PACKET
0x622D49C0        344       1  X.25 packet descr
0x617EB95C        344       2  FLEX DSPRM MAIN
0x61D7E1E8        344       2  SAA echo et
0x6065E360        340       5  IPC Name String
0x625C5FDC        340       5  Init
0x611D8E80        336       3  GraphIt Data
0x60D56810        336       3  ATMSIG-QOS
0x60DE1040        336       4  Init
0x60DE138C        336       4  Init
0x60DE1398        336       4  Init
0x61725280        328       2  Init
0x60191C5C        324       1  Init
0x628EDB08        324       1  Init
0x61088410        320       4  CDP hw subblock
0x6128598C        320       4  Init
0x611BD000        316       1  SSH Process
0x60129AC8        316       1  Init
    PC          Total   Count  Name
0x62567994        316       1  Crypto Dynamic Template ACL entry
0x60D571A8        312       2  ATMSIG-TERMINFO
0x61D723C0        312       2  SAA Oper saaOperTreeLink_t
0x6117E5DC        312       2  AAA Request Data
0x613896FC        308       1  Init
0x6138970C        308       1  Init
0x6138971C        308       1  Init
0x6138972C        308       1  Init
0x61084DBC        304       1  Init
0x6097FED0        304       4  FLEX DSPRM MAIN
0x602ECF18        304       4  FLEX DSPRM MAIN
0x602ECF28        304       4  FLEX DSPRM MAIN
0x620EDB48        304       4  FLEX DSPRM MAIN
0x620EDB54        304       4  FLEX DSPRM MAIN
0x620BDDC8        300       1  Init
0x620D3AC0        300       2  Init
0x617B7E8C        300       1  Init
0x617B7EA4        300       1  Init
0x6151AE50        300       3  HTTP
0x61D72340        300       1  SAA LatestSetError
0x61A8C890        300       1  Init
0x61086528        300       1  CDP Protocol
0x60DE0640        300       3  Init
0x60DE0654        300       3  Init
0x61574F74        300       2  Init
0x617C97C8        300       4  Init
0x60E395AC        300       1  BGP vpnv4 soo
0x6172AB58        300       1  Init
0x6172AB78        300       1  Init
0x61167FF4        296       2  Init
0x61ECB170        296       1  Init
0x60BD6988        292       1  Init
0x60C449CC        288       2  AAA MLIST
0x60D5AC74        288       4  ATMSIG-ADDR
0x61328CA4        288       1  Init
0x601AFBC8        284       1  Init
0x61287B30        284       1  Init
0x611B44CC        284       1  Init
0x61167FE8        276       2  Init
0x61167FDC        276       2  Init
0x620DA77C        276       4  Init
0x60CE5790        276       3  Init
    PC          Total   Count  Name
0x60CE57B0        276       3  Init
0x60CE57D0        276       3  Init
0x60AE03A4        272       1  *Init*
0x6116E83C        272       2  Init
0x60FB4720        272       1  MPPE ID bits
0x61157B4C        272       4  Init
0x61157BE8        272       4  Init
0x623384AC        272       1  Init
0x6097FEB8        272       4  FLEX DSPRM MAIN
0x60BBFFAC        272       4  FLEX DSPRM MAIN
0x601918F8        268       1  Init
0x60CE78D4        264       3  ATM ckt_id_type
0x60CE9ED8        264       3  Init
0x60D57350        256       2  ATMSIG-TOS
0x62676E18        256       1  Init
0x62728098        256       1  Init
0x612F85B4        252       3  Init
0x62107D94        252       3  Init
0x623CFB68        244       3  crypto_handle_table
0x60D562E0        244       1  ATMSIG-STATS
0x60D25208        240       3  Init
0x60490960        240       3  Init
0x61E1C0B4        240       3  Init
0x61513C48        240       3  HTTP
0x6186DD40        240       3  ivr: Language_t
0x60CEBE98        240       3  Init
0x61E24F34        236       3  Init
0x61080074        236       1  CDP Protocol
0x60D58C80        232       2  ATMSIG_CCB
0x600C66B0        228       3  Init
0x617C8858        228       2  Init
0x604941D8        228       3  CCSIP_UDP_SOCKET
0x61ECB6AC        224       3  Init
0x60D57398        224       2  ATMSIG-QOS
0x60D573AC        224       2  ATMSIG-QOS
0x623F3E34        224       3  Init
0x615E8FC0        220       1  Init
0x615E8FD0        220       1  Init
0x617CDD54        220       1  Init
0x611D8EB0        212       3  Init
0x60192DA4        212       1  Init
0x6271126C        212       1  IPv6 FIB subblock
    PC          Total   Count  Name
0x611F1C04        208       1  Init
0x611F1C28        208       1  Init
0x611F1C4C        208       1  Init
0x61ECB6C8        208       3  Init
0x6210B7C8        208       2
0x6049177C        204       3  Init
0x604917F8        204       3  Init
0x620C1108        204       3  CCA UserType
0x6065609C        204       3  IPC Name
0x61571E7C        204       3  Init
0x61571EB0        204       3  Init
0x612F858C        204       3  Init
0x61E1C0C8        204       3  Init
0x61E1C1A4        204       3  Init
0x6210B934        204       2  99405978
0x61132308        204       3  AAA Secrettype
0x61132344        204       3  AAA Secrettype encrypt
0x6186DD68        204       3  ivr: Language_t name
0x6186DD88        204       3  ivr: Language_t url
0x61223518        204       3  Init
0x61E1C524        204       2  Init
0x61A8DFF8        204       1  Init
0x600AD5DC        200       1  Device Info
0x60A834AC        200       2  VLAN Manager
0x61BF0208        200       2  Runtime classmap filter array
0x605ED2E4        196       1  ESWILP NMs table
0x6180E638        196       2  PPTP Mgmt
0x61132890        196       1  AAA SG HQ
0x6174C9E0        196       2  Init
0x61063D78        192       2  Init
0x60957764        188       1  dspFarm Information
0x6073EC20        188       1  L2MM
0x61ECB194        188       1  Init
0x6117DCEC        188       2  Init
0x60948828        184       1  Init
0x61CA7B30        184       2  Resource Monitor
0x61EEABD0        184       2  Init
0x6127F218        180       1  Init
0x60126054        180       1  Init
0x61389688        180       1  CEF: ndb
0x61733078        180       1  Init
0x600DF8FC        176       1  SSS Switch Information
    PC          Total   Count  Name
0x620D3B2C        176       2  Init
0x61A87FF4        176       1  Init
0x60C743A4        176       1  ivr: appProcess_t
0x60287388        172       1  Resouce Pool Info
0x6026EB0C        172       1  *Init*
0x6026EB50        172       1  *Init*
0x6065C988        172       1  IPC Frag Cache
0x60D3F094        172       1  ILMI-DB
0x61A88008        172       1  Init
0x61A8801C        172       1  Init
0x61A88030        172       1  Init
0x617330A8        172       1  Init
0x62336E04        168       2  Init
0x60AF38F0        168       2  Init
0x6119112C        168       2  SDB String
0x617EF130        168       2  CCSIP_UDP_SOCKET
0x61E1C538        168       2  Init
0x606C65EC        164       1  Init
0x623D09C0        164       1  Init
0x6117C900        164       1  Ion New Block
0x61A83AB8        164       1  Init
0x61167F8C        160       2  Init
0x613896DC        160       1  Init
0x613896EC        160       1  Init
0x61ED3C9C        160       2  Init
0x61BF4E34        160       2  Runtime actiongroup
0x61BF2644        160       2  POLICYMAP_MODULE
0x60E39108        160       1  Init
0x611A683C        156       1  *Init*
0x60191A94        156       1  Init
0x60C44F78        152       1  AAA MLIST
0x6197FCB0        152       1  LW VLAN Range
0x62436348        152       1  SSH2 Channel
0x61097D38        148       1  chat script
0x61134D1C        148       2  AAA Attr Binary/String
0x607390E0        148       1  L2MM
0x617C8878        148       2  Init
0x6119D008        148       1  TTYBKG Timer
0x615555DC        144       2  Init
0x609577A0        144       1  dspfarm strings
0x62337A88        144       2  Init
0x6115C850        144       2  AAA Public Server Group wrapper
    PC          Total   Count  Name
0x61EEAB58        144       2  Init
0x61BEF948        140       2  CLASSMAP_MODULE
0x609E6238        140       1  Init
0x6073B574        140       1  L2MM
0x61F04BA4        140       1  TAC lp
0x61ED59E8        140       1  Init
0x613795D4        136       2  CEF process
0x6127F1EC        136       1  Init
0x62336E2C        136       2  Init
0x62336E8C        136       2  Init
0x62336F14        136       2  Init
0x6116E580        136       1  Init
0x606EC35C        136       2  Init
0x61BEF834        136       2  CLASSMAP_MODULE
0x627C64B4        136       1  Init
0x61E2FC90        136       2  Init
0x62956250        136       2  Init
0x611323B8        136       2  AAA_Secrettype pw
0x611326D4        136       2  AAA SG NAME
0x6115C7E0        136       2  AAA nvgend sg elt
0x6115C914        136       2  AAA pub SG wrap name
0x6115C958        136       2  AAA pub SG name
0x61081198        136       1  Init
0x60F3434C        136       1  Init
0x626A86E0        136       2  Init
0x6117DCC4        136       2  Init
0x617BA48C        136       2  Init
0x61D909C0        136       2  SAA hourlyStats startTime
0x62337A9C        136       2  Init
0x600B47EC        132       1  FileSys Info
0x602C9BB4        132       1  ISDN-t-callmib
0x61BF4DB0        132       1  Runtime policymap
0x60662050        128       1  IPC Zone
0x60E38E84        128       1  Init
0x60E38EA4        128       1  Init
0x60E38EC4        128       1  Init
0x60E38EE4        128       1  Init
0x60E39178        128       1  Init
0x60E39194        128       1  Init
0x60E391B0        128       1  Init
0x61E0FD10        124       1  Init
0x61999F34        124       1  ivr: msw_rtsp_stream_t
    PC          Total   Count  Name
0x61999F64        124       1  ivr: msw_mrcp_stream_t
0x60DE0E10        124       1  Init
0x60DE1194        124       1  Init
0x61BF710C        124       1  POLICYMAP_MODULE
0x61BF7688        124       1  POLICYMAP_MODULE
0x61ED58AC        124       1  Init
0x61ED5944        124       1  Init
0x60476C50        116       1  Init
0x621E4F74        112       1  VPN User Failure History Table
0x6296ED28        112       1  Init
0x604CBB08        112       1  Init
0x61BEE3C0        112       1  Qos hw subblock
0x615111B0        108       1  HTTP
0x61510678        108       1  HTTP
0x6166CFF8        108       1  Init
0x60476C18        108       1  Init
0x60476C34        108       1  Init
0x60476C6C        108       1  Init
0x60476C88        108       1  Init
0x60476CC0        108       1  Init
0x60476CDC        108       1  Init
0x6065AA98        104       1  IPC Seat
0x600B470C        104       1  FileSys Callback
0x601884A4        104       1  Init
0x606920B0        104       1  FLEX DSPRM MAIN
0x61BFF1E8        104       1  QOS policymap name
0x610D0E28        100       1  Init
0x61BEE42C        100       1  Qos sw subblock
0x60E55CA4        100       1  Init
0x62151870         96       1  Init
0x600B5080         96       1  Init
0x611A4FA8         92       1  Init
0x611A31E0         92       1  Init
0x61DA1398         92       1  SAA APM OPER LIST
0x6116845C         92       1  Init
0x626CFEA4         92       1  Init
0x61F59E34         88       1  MPLS Label Region ParamRec
0x6119CEAC         88       1  TTY timer block
0x618FF084         88       1  Init
0x61168324         84       1  Init
0x6128060C         84       1  CLID Group
0x62066638         84       1  TPLUS socket
    PC          Total   Count  Name
0x6083D3C8         84       1  Init
0x6083D448         84       1  Init
0x6083D4B8         84       1  Init
0x6083D51C         84       1  Init
0x6083D578         84       1  Init
0x6083D5D4         84       1  Init
0x6083D630         84       1  Init
0x6083D690         84       1  Init
0x6083D6FC         84       1  Init
0x6083D760         84       1  Init
0x6083D7BC         84       1  Init
0x6083D818         84       1  Init
0x6083D874         84       1  Init
0x6083D8CC         84       1  Init
0x6083D938         84       1  Init
0x6083D99C         84       1  Init
0x6083D9F8         84       1  Init
0x6083DA54         84       1  Init
0x6083DAB0         84       1  Init
0x6083DB08         84       1  Init
0x6083DB78         84       1  Init
0x6083DBDC         84       1  Init
0x6083DC38         84       1  Init
0x6083DC94         84       1  Init
0x6083DCF0         84       1  Init
0x6083DD48         84       1  Init
0x6083DDB8         84       1  Init
0x6083DE1C         84       1  Init
0x6083DE78         84       1  Init
0x6083DED4         84       1  Init
0x6083DF30         84       1  Init
0x6083DF8C         84       1  Init
0x6083E00C         84       1  Init
0x6083E074         84       1  Init
0x6083E0D4         84       1  Init
0x6083E134         84       1  Init
0x6083E194         84       1  Init
0x6083E204         84       1  Init
0x6083E27C         84       1  Init
0x6083E2E4         84       1  Init
0x6083E344         84       1  Init
0x6083E3A4         84       1  Init
    PC          Total   Count  Name
0x6083E404         84       1  Init
0x6083E460         84       1  Init
0x6083E4D4         84       1  Init
0x6083E53C         84       1  Init
0x6083E59C         84       1  Init
0x6083E5FC         84       1  Init
0x6083E65C         84       1  Init
0x6083E6BC         84       1  Init
0x6083E718         84       1  Init
0x6083E78C         84       1  Init
0x6083E7F4         84       1  Init
0x6083E854         84       1  Init
0x6083E8B4         84       1  Init
0x6083E914         84       1  Init
0x6083E974         84       1  Init
0x6083E9E8         84       1  Init
0x6083EA50         84       1  Init
0x6083EAB0         84       1  Init
0x6083EB10         84       1  Init
0x6083EB70         84       1  Init
0x6083EBD0         84       1  Init
0x6083EC44         84       1  Init
0x6083ECBC         84       1  Init
0x6083ED3C         84       1  Init
0x6083EDA4         84       1  Init
0x6083EE04         84       1  Init
0x6083EE64         84       1  Init
0x6083EEC4         84       1  Init
0x6083EF24         84       1  Init
0x6083EF98         84       1  Init
0x6083F000         84       1  Init
0x6083F078         84       1  Init
0x6083F0DC         84       1  Init
0x6083F144         84       1  Init
0x6083F1B8         84       1  Init
0x6083F22C         84       1  Init
0x6018A20C         84       1  Init
0x6116E530         84       1  Init
0x6117CD08         84       1  Ion Password
0x611FAFCC         84       1  Init
0x615D1D0C         84       1  Init
0x614BD490         84       1  Init
    PC          Total   Count  Name
0x611B45E8         84       1  Init
0x61F59E1C         84       1  MPLS Label Region AllocRec
0x61E03318         84       1  Init
0x61A8F494         84       1  NTP refclock vectors
0x615A16C4         84       1  Init
0x61168368         80       1  Init
0x61280658         80       1  CLID Entry
0x60D56300         80       1  ATMSIG-CUG-WAVL
0x61FCB28C         80       1  Init
0x62433C10         80       1  SSH2 Session-id
0x60D25748         80       1  vc hashtbl ptr
0x60D25354         80       1  Init
0x6172E3B8         80       1  Init
0x61BC9C88         76       1  Init
0x60862144         76       1  shadow tsi str control
0x608621BC         76       1  shadow tsi str control
0x60129C60         76       1  Init
0x60129C70         76       1  Init
0x6115C1B4         76       1  Init
0x61448168         76       1  FR Diag Parent Timer
0x6146A2A4         76       1  Init
0x6117D868         76       1  Init
0x61405B10         76       1  FR LMI Root Timer
0x61405B2C         76       1  FR LMI Error Timer
0x61405B48         76       1  FR LMI IDB Timer
0x61405B64         76       1  FR LMI Route Timer
0x6140EE34         76       1  FR Arp Init Timer
0x61415C94         76       1  FR ELMI Version Timer
0x61415CB0         76       1  FR LMI QOS Timer
0x61415CCC         76       1  FR LMI PVC Timer
0x6141C5E8         76       1  FR Fragmentation timer
0x61453E74         76       1  FR Tunnel Master Timer
0x617D5728         76       1  Init
0x616CF628         76       1  Init
0x6267F72C         76       1  CE info table
0x626E64AC         76       1  Init
0x624289A8         76       1  SSH memory
0x617B272C         76       1  Init
0x6197EE40         76       1  LW_VLAN hardware IDB subblock
0x62430394         76       1  SSH2 String
0x61575BCC         76       1  Init
0x61BF4EC4         76       1  Runtime action map
    PC          Total   Count  Name
0x61BF7908         76       1  POLICYMAP_MODULE
0x6012CC44         72       1  Init
0x617918DC         72       1  Init
0x613892C4         72       1  Init
0x613C4B0C         72       1  IP Flow block array
0x616E5208         72       1  Init
0x61C0D934         72       1  Init
0x615BC270         72       1  ippeerinfo
0x61009390         72       1  CCSIP_SPI_CONTROL
0x610093A0         72       1  CCSIP_SPI_CONTROL
0x610093B0         72       1  CCSIP_SPI_CONTROL
0x610093C0         72       1  CCSIP_SPI_CONTROL
0x623D09E4         68       1  Init
0x6208BFB0         68       1  *Init*
0x6116E334         68       1  Init
0x6116E674         68       1  Init
0x6116E6E0         68       1  Init
0x611682FC         68       1  Init
0x61168340         68       1  Init
0x624277A8         68       1  Init
0x61280634         68       1  CG:Name
0x6128067C         68       1  CE:Num
0x615480DC         68       1  Init
0x6083D168         68       1  Init
0x6083D184         68       1  Init
0x6083D1A0         68       1  Init
0x6083D1BC         68       1  Init
0x6083D1D8         68       1  Init
0x6083D1F4         68       1  Init
0x6083D210         68       1  Init
0x6083D22C         68       1  Init
0x6083D248         68       1  Init
0x6083D264         68       1  Init
0x6083D280         68       1  Init
0x6083D29C         68       1  Init
0x6083D2B8         68       1  Init
0x6083D2D4         68       1  Init
0x6083D2F0         68       1  Init
0x6083D3A4         68       1  Init
0x6083D430         68       1  Init
0x6083D4A0         68       1  Init
0x6083D500         68       1  Init
    PC          Total   Count  Name
0x6083D55C         68       1  Init
0x6083D5B8         68       1  Init
0x6083D614         68       1  Init
0x6083D670         68       1  Init
0x6083D6E4         68       1  Init
0x6083D744         68       1  Init
0x6083D7A0         68       1  Init
0x6083D7FC         68       1  Init
0x6083D858         68       1  Init
0x6083D8B4         68       1  Init
0x6083D920         68       1  Init
0x6083D980         68       1  Init
0x6083D9DC         68       1  Init
0x6083DA38         68       1  Init
0x6083DA94         68       1  Init
0x6083DAF0         68       1  Init
0x6083DB60         68       1  Init
0x6083DBC0         68       1  Init
0x6083DC1C         68       1  Init
0x6083DC78         68       1  Init
0x6083DCD4         68       1  Init
0x6083DD30         68       1  Init
0x6083DDA0         68       1  Init
0x6083DE00         68       1  Init
0x6083DE5C         68       1  Init
0x6083DEB8         68       1  Init
0x6083DF14         68       1  Init
0x6083DF70         68       1  Init
0x6083DFEC         68       1  Init
0x6083E054         68       1  Init
0x6083E0B4         68       1  Init
0x6083E114         68       1  Init
0x6083E174         68       1  Init
0x6083E1DC         68       1  Init
0x6083E260         68       1  Init
0x6083E2C4         68       1  Init
0x6083E324         68       1  Init
0x6083E384         68       1  Init
0x6083E3E4         68       1  Init
0x6083E444         68       1  Init
0x6083E4B8         68       1  Init
0x6083E51C         68       1  Init
    PC          Total   Count  Name
0x6083E57C         68       1  Init
0x6083E5DC         68       1  Init
0x6083E63C         68       1  Init
0x6083E69C         68       1  Init
0x6083E6FC         68       1  Init
0x6083E770         68       1  Init
0x6083E7D4         68       1  Init
0x6083E834         68       1  Init
0x6083E894         68       1  Init
0x6083E8F4         68       1  Init
0x6083E954         68       1  Init
0x6083E9CC         68       1  Init
0x6083EA30         68       1  Init
0x6083EA90         68       1  Init
0x6083EAF0         68       1  Init
0x6083EB50         68       1  Init
0x6083EBB0         68       1  Init
0x6083EC28         68       1  Init
0x6083ECA0         68       1  Init
0x6083ED20         68       1  Init
0x6083ED84         68       1  Init
0x6083EDE4         68       1  Init
0x6083EE44         68       1  Init
0x6083EEA4         68       1  Init
0x6083EF04         68       1  Init
0x6083EF7C         68       1  Init
0x6083EFE0         68       1  Init
0x6083F040         68       1  Init
0x6083F0C0         68       1  Init
0x6083F11C         68       1  Init
0x6083F190         68       1  Init
0x6083F204         68       1  Init
0x6094885C         68       1  Init
0x60262110         68       1  Init
0x60B4D8A4         68       1  Init
0x60129C7C         68       1  Init
0x60129C88         68       1  Init
0x6116E4B0         68       1  Init
0x60C337F4         68       1  AAA PROMPT P1
0x60C33810         68       1  AAA PROMPT U1
0x6156DA44         68       1  Init
0x6109D9CC         68       1  Init
    PC          Total   Count  Name
0x6139B268         68       1  FIB: event log block
0x6116E454         68       1  Init
0x61E0DAEC         68       1  Init
0x61093EA4         68       1  Init
0x61093F70         68       1  Init
0x61E032F0         68       1  Init
0x61A07158         68       1  Data Train
0x6115C894         68       1  AAA pub SG servers
0x61C59200         68       1  Init
0x610C9250         68       1  Init
0x615E8198         68       1  Init
0x6289CDF8         68       1  Srtp crypto engine status
0x61ED4DDC         68       1  Init
0x623FB89C         68       1  Software engine status
0x60F0E2EC         68       1  Init
0x60F0EBD4         68       1  Init
0x6116FAB0         68       1  Init
0x61BF784C         68       1  POLICYMAP_MODULE
0x61BF76A8         68       1  POLICYMAP_MODULE
0x61ED52FC         68       1  Init
0x60B53D7C         68       1  Init
0x61989E44         68       1  ivr: mediaContent name
0x612FF438         68       1  EM EVENT HANDLER
0x60CCD674         68       1  asnl:asnlAppReg_t
0x62146E68         68       1  voip aaa: asnl url
0x60CCFB14         68       1  Init
0x6269EEC0         68       1  Init
0x6269EEFC         68       1  CryptoSS:RegisteredApps
0x62564610         68       1  Init
0x62564620         68       1  Init
0x62976F98         68       1  Init
0x62976FA8         68       1  Init
0x61284748         68       1  Init
0x6128476C         68       1  Init
0x61C91CA4         68       1  Init
0x61C92D9C         68       1  Init
0x6209A014         68       1  Init
0x60DE0EA0         68       1  Init
0x60DE0EAC         68       1  Init
0x60DE11FC         68       1  Init
0x60DE1208         68       1  Init
0x60476CA4         68       1  Init
    PC          Total   Count  Name
0x60476CF8         68       1  Init
0x610EDCB8         68       1  Init
0x6117E66C         68       1  AAA Attr String
0x609AEDE4         68       1  VLAN Manager
0x609B6DEC         68       1  VLAN Manager
0x61DF75EC         68       1  State Machine Instance
0x610093D0         68       1  CCSIP_SPI_CONTROL
0x610093E0         68       1  CCSIP_SPI_CONTROL
0x6117E314         68       1  AAA_Secrettype pw
0x62337A78         68       1  Init
0x62337AA8         68       1  Init
0x610C06BC         68       1  Init
0x61ED1DDC         68       1  Init
0x6115AA6C         68       1  Init
0x61ED15F8         68       1  Init
0x61BF4E0C         68       1  Runtime policymap actiongroup array
0x60E38F24         68       1  Init
Allocator PC Summary for: I/O
    PC          Total   Count  Name
0x604AF6A8    9318976       9  Normal
0x604AF744    7216000     110  Normal
0x60487E90    1775040    2641  *Packet Data*
0x60192D6C      57408       1  RS8234_RSM_STAUSQS
0x60191D98      55360       1  RS8234_RBDS
0x601918A4      28736       1  RS8234_SEG_STAUSQS
0x628EE988      21568       1  sfnt udm
0x602AAED4      16448       1  C5510 DSP
0x609D4F54       8320       2  Init
0x609D4F94       8320       2  Init
0x606C7D0C       8320       2  Init
0x602AB090       8256       1  C5510 DSP
0x628F6FAC       6688       6  name
0x609825CC       4160       1  HDLC32_TX
0x628F69BC       2624       1  sfnt udm
0x6098261C       1088       1  HDLC32_RX
0x6035E858        896       1  Init
0x606F33A4        512       2  Init
0x60191ABC        192       1  RS8234_TXQ_RD_UPDATE
0x60191CAC        192       1  RS8234_FBQ_RD_UPDATE
    PC          Total   Count  Name
-Karthic
hi Karthic,
  I am getting lots misses in Natting.
------------------ show ip nat statistics ------------------
Total active translations: 901 (1 static, 900 dynamic; 901 extended)
Outside interfaces:
  GigabitEthernet0/0.253, GigabitEthernet0/2/0, ATM1/0.3
Inside interfaces:
  GigabitEthernet0/1
Hits: 1287938736  Misses: 15388435
CEF Translated packets: 157790732, CEF Punted packets: 1608741319
Expired translations: 18949388
Dynamic mappings:
-- Inside Source
[Id: 1] route-map two-nat interface GigabitEthernet0/3/0 refcount 432
[Id: 2] route-map one interface GigabitEthernet0/0.2703 refcount 472
Queued Packets: 0
The number of NAT entries are pretty low and should not cause high memory usage. If you could get the o/ps, I shd be able to check where the memory usage is going to
- Karthic
