MX integration with Checkpoint cloudguard
aleabrahao
Meraki Community All-Star
Has anyone done or heard of MX integration with Checkpoint cloudguard? I'm planning a solution Basically the MX will be part of the SD-WAN but the security control will be done by Checkpoint cloudguard (SASE Solution).
Is it possible to do this integration?
Thanks.
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
Philip D'Ath
I'm guessing it will be something similar to using Zscaler, which uses the tag based VPN failover system.
https://documentation.meraki.com/MX/Site-to-site_VPN/Tag-Based_IPsec_VPN_Failover
Philip D'Ath
aleabrahao
@Philip D'Ath, I think it is a similar case. I will read and take all the notes.
aleabrahao
Thanks @Philip D'Ath
