10-05-2017 07:40 PM
Hi Guys,
Good Day!
I got an opportunity to present Cisco Meraki Security on one of our Partner's End User.
There are some inquiries about Meraki's Security Solution:
They are also familiar with Meraki's AP.
But they have 1 question in mind and it has to do with MAC ADDRESS Binding per SSID.
Is it possible to have a MAC ADDRESS bonded to an SSID that has Traffic shaping? (e.g. MAC addresses of a certain group can only connect to a specific SSID, if they connect to a different SSID they won't have internet access).
I know this is a long post but I really appreciate any feedback from you guys.
Thanks in advance!
Solved! Go to Solution.
10-05-2017 09:21 PM
Yes.
No.
There is a content category called "Web Advertisements", I've never used it, but I expect it would block what it says.
Discount programs come and go. You should not enter into a 10 year transaction with any expectations. Seriously though - would you really want a security appliance using 10 year old technology. I would suggest shorter licences, like 5 years, and replace the device more regularly.
10-05-2017 09:21 PM
Yes.
No.
