07-21-2019 04:31 PM
Dear All,
I would like to know as i am using MX65 for small client and it has 2 PoE+ ports. I just wanted to know incase if i need just 2 or 3 more extra PoE port. I do not want to go and buy a PoE switch for the customer as it would be expensive for them, but i would like to know if i will connect the PoE unmanaged switch of HP. Will it work ?
Solved! Go to Solution.
07-22-2019 02:34 AM
This will work, yes.
07-21-2019 04:35 PM
@Sumit1565 Yes that will work.
07-21-2019 09:22 PM
Most PoE devices also allow power cubes - which are usually even cheaper.
07-21-2019 09:26 PM
sorry i did not understand what do you mean by power cubes
pls share me the URL link so that i can understand this.
sorry for this.
07-22-2019 02:35 AM
07-21-2019 09:28 PM
you mean something like this.
https://www.tp-link.com/au/business-networking/accessory/tl-poe150s/
07-22-2019 02:34 AM
