NAT command
sridhar ch
Level 4
Level 4
I want to NAT my LAN (10.0.0.0/8) to a single public IP other than the WAN IP, what would be the NAT command. I can use NAT overload if I have to use WAN IP. But want to go with other IP  due to dependency on the IP.
Sridhar
5 Replies 5
Georg Pauwen
use a pool. In the example below, 1.1.1.1/30 is the public IP address, replace that with whatever address you have:
ip nat pool PUBLIC_IP 1.1.1.1 1.1.1.1 netmask 255.255.255.252
ip nat inside source list 1 pool PUBLIC_IP overload
access-list 1 permit 10.0.0.0 0.255.255.255
thx for your reply. can u confirm if the subnet mask is 255.255.255.255 but not 255.255.255.252.
also can i have a loopback with 1.1.1.1 and go with NAT overload. if so, do i need to define "ip nat outside" on the loop back or on the WAN interface? think loop back, correct me if i am wrong.
1.1.1.1 is just an example. if you have a /32 mask, you can change the pool netmask to that:
ip nat pool PUBLIC_IP 1.1.1.1 1.1.1.1 netmask 255.255.255.255
The public IP address used in the pool can be any address, it doesn't matter what IP address you have configured on the NAT outside interface. The NAT outside interface is the WAN interface, not any loopback.
Here is an example, putting it all together.
interface GigabitEthernet0/0
description ISP Link
ip address 100.100.100.1 255.255.255.252
ip nat outside
interface GigabitEthernet0/1
description LAN
ip address 10.0.0.1 255.0.0.0
ip nat inside
balaji.bandi
as per the example  /30 that subnet is correct. if the subnet /32 - then you need to go with 255.255.255.255
you can change what ever subnet you are using in your environement, test and advise.
BB
Hello
The only way you can do this  if that "other ip"  is reachable on the public network.
Kind Regards
Paul
