NAT Problem..
hyukin.kwon
Level 3
Level 3
Hi all
We have two 2600 series routers and there is a weird thing.
Diagram is
PC --- Router#1 ------Router#2
Router#1 is doing an NAT translation
configuratios is
Router#1
interface fas0/0
ip address 10.10.10.1 255.255.255.0
ip nat inside
interface fas0/1
ip address 10.10.20.1 255.255.255.0
ip nat outside
ip nat inside source-list route-map test interface fas0/1 overload
access-list 100 permit ip 10.10.10.0 0.0.0.255 any
route-map test
match access-list 100
Router#2
interface fas0/0
ip add 10.10.20.2 255.255.255.0
Problem is..
Normaly this configuration works well, but Unconditionally I added
some static nat policy, that was..
"ip nat inside source static 1.1.1.1 int fas0/1"
of course, 1.1.1.1 is not real interface's ip address.
Router#1# sh run
interface fas0/0
ip nat inside
interface fas0/1
ip nat outside
route-map test
then tested the ping from Router#1
Router#1#ping 10.10.20.2
Suddenly, I couldn't ping from Router#1 to Router#2's interface which is directed connected
The debug result is ...
*Mar 1 00:29:37.003: NAT*: o: icmp (10.10.20.2, 23) -> (10.10.20.1, 23) [10053]
*Mar 1 00:29:37.003: NAT*: s=10.10.20.2, d=10.10.20.1->1.1.1.1 [10053].
*Mar 1 00:29:38.999: NAT*: o: icmp (10.10.20.2, 23) -> (10.10.20.1, 23) [10056]
*Mar 1 00:29:38.999: NAT*: s=10.10.20.2, d=10.10.20.1->1.1.1.1 [10056].
*Mar 1 00:29:40.999: NAT*: o: icmp (10.10.20.2, 23) -> (10.10.20.1, 23) [10060]
*Mar 1 00:29:40.999: NAT*: s=10.10.20.2, d=10.10.20.1->1.1.1.1 [10060].
*Mar 1 00:29:42.999: NAT*: o: icmp (10.10.20.2, 23) -> (10.10.20.1, 23) [10063]
*Mar 1 00:29:42.999: NAT*: s=10.10.20.2, d=10.10.20.1->1.1.1.1 [10063].
*Mar 1 00:29:44.999: NAT*: o: icmp (10.10.20.2, 23) -> (10.10.20.1, 23) [10070]
*Mar 1 00:29:44.999: NAT*: s=10.10.20.2, d=10.10.20.1->1.1.1.1 [10070].
I think the reason of ping fail is the router#1 tried to translate to 1.1.1.1
against the reply of Router#2 that is misconfigured NAT Rule...
Why this is happeing ? this is directed connected interface that means this case
no need to translate....
TIA....
sourabhagarwal
Level 9
Level 9
I can see that you have configured IP on fa0/0 interface on router as 10.10.10.1 which means that you have assigned 10.10.10.0/24 subnet to your LAN and same subnet you are matching in the ACL for NAT.
I'm not sure why you are creating static NAT for 1.1.1.1 IP because it's not part of your LAN subnet 10.10.10.0/24
can you tell where is this IP connected in your network? if you are trying to create s static NAT for a device in your network, then it should have from 10.10.10.0/24 subnet only.
Hi sourabhagarwal,
I see your point. that is totally by accident. I know I cannot use 1.1.1.1.
But I'd like to know the reason.
TIA...
I think this is how it should work . I think ICMP doesnt distinguish directly connected interface or routed . In a ICMP packet with a source as other end ip and destination as router1 ip , and since ur destination ip has a static translation , it gets redirected to that .
Hope this helps
regards
vanesh k
rohit_agarawal
Community Member
ip nat inside source route-map test interface fas0/1 overload
put above nat statement
hope it will work plzz rate ity if its work
