negative buffer size
bberry
Level 8
Level 8
I am not sure if this question belongs here or in the WAAS catagory as I am running the router with WAAS express. I am figuring here since it revolves around the status of the buffers on the router.
I have a 2911 running WAAS Express connected to my AVPN network via a full T1 link. The location is always reporting slow response and I will admit there are times when the link is running close to the full T1 speed. But today I noticed that the size on the input queue is reporting a negative number. Could this be pointing toward an underlying issue that is creating this slowness? I have never noticed this before and I do not have it on other locations running the same platform. Any thoughts?? My interface config is listed at the bottom.
Serial0/0/0 is up, line protocol is up
  Hardware is GT96K with integrated T1 CSU/DSU
  Description: AT&T AVPN CKT#DHEC457563 T1 port
  Internet address is 10.1.4.105/30
  MTU 1500 bytes, BW 1544 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 19/255, rxload 207/255
  Encapsulation PPP, LCP Open
  Stopped: CDPCP
  Open: IPCP, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:13:22
Input queue: -130107/75/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1257000 bits/sec, 134 packets/sec
  5 minute output rate 121000 bits/sec, 86 packets/sec
     118464 packets input, 129851700 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     81978 packets output, 15226393 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
interface Serial0/0/0
description AT&T AVPN CKT#DHEC457563 T1 port
bandwidth 1544
ip address 10.1.4.105 255.255.255.252
ip access-group 155 out
ip flow ingress
ip flow egress
ip virtual-reassembly in
ip virtual-reassembly out
encapsulation ppp
logging event subif-link-status
no peer neighbor-route
no fair-queue
service-module t1 timeslots 1-24
service-module t1 remote-alarm-enable
service-module t1 fdl both
waas enable interface Serial0/0/0
bandwidth 1544
ip flow ingress
ip flow egress
encapsulation ppp
no fair-queue
waas enable
5 Replies 5
Raju Sekharan
Defintely hitting a bug
What is the code you are running ?
I am only seeing this at the one location. I have half a dozen or so other locations that are running the same version and on the ones I have checked so far are not displaying this issue.
hart_r uptime is 16 weeks, 2 days, 3 hours, 9 minutes
System restarted at 10:15:46 CDT Tue Jun 19 2012
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M1.bin"
Last reload type: Normal Reload
Look at this bug
CSCtl87463    -ve input queue size of interface on running traffic
Symptoms: Queue length becomes negative.
Conditions: The symptom is observed when Cisco IOS-WAAS is configured on the
interface.
Workaround: There is no workaround.
Your code doesn't have fix for this
15.1(4)M3 has fix for this
Raju
**rate useful osts***
rajs2,
Could this possibly affect overall through put in the router? I am running WAAS but like I said this is the only one that is displaying the negative numbers. It is also the one that has the highest utilization most of the time. All locations are usually running at the maximum 250 TCP connections.
Brent
This will not have any impact on your traffic. it just shows wrong counters.
Raju
***please rate useful posts****
