Netflow flow v5
kpavansharma
Community Member
Hi All,
Could you please tell me what if I enable "ip flow ingress", "ip route-cache flow" both commands on single interface?
I will be geeting netflow output or not.
Raju Sekharan
You will get netflow output
Effective with Cisco IOS Releases 12.4(2)T and 12.2(18)SXD, the ip route-cache flowcommand is replaced by the
ip flow ingresscommand
When you enter the ip route-cache flow command to enable NetFlow (ingress) accounting on an interface in a  router that is running Cisco IOS Release 12.2(25)S or later, or Cisco  IOS Release 12.2(18)SXD or later, the command is automatically remapped  to the ip flow-ingress command before it is added to the in the running configuration
http://www.cisco.com/en/US/docs/ios/netflow/command/reference/nf_01.html#wp1049320
Raju
Thanks Raju for replying,
Please check below config and let me know do I need to change anything, because am not getting any data from my Netflow collector for the interfaces Fa0/1 and Tunnel116 even "ip flow ingress" & "ip route-cache flow" is set on the both interface. And IOS is flash:c3745-ipvoice-mz.123-23.bin
interface FastEthernet0/1
bandwidth 15000
ip address x.x.x.x
ip access-group CT_MPLS in
ip access-group CT_MPLS out
ip accounting output-packets
ip flow ingress
ip route-cache flow
load-interval 30
duplex auto
speed auto
interface Tunnel116
bandwidth 15000
ip address x.x.x.x
no ip redirects
ip mtu 1416
ip flow ingress
ip nhrp authentication x.x.x.x
ip nhrp map multicast dynamic
ip nhrp map multicast x.x.x.x
ip nhrp map x.x.x.x
ip nhrp network-id 116
ip nhrp holdtime 300
ip nhrp nhs x.x.x.x
ip route-cache flow
ip tcp adjust-mss 1350
delay 10
qos pre-classify
keepalive 10 3
tunnel source FastEthernet0/1
tunnel mode gre multipoint
tunnel key 116
hold-queue 1000 in
hold-queue 1000 out
you need to add ip flow-export destination x.x.x.x and ip flow-export version 5  in global config
Regards.
Alain
