Not on common subnet error, while using EIGRP routing protocol.
noob_route
Frequent Visitor
Frequent Visitor
Requirements: HUB-ACTIVE, HUB-STANDBY, SPOKE2 must communicate through DMVPN, using EIGRP routing protocol.
But when i advertise the network connected to the routers (hub-active, hub-standby, spoke2), it showing the error on all three routers:
 *Dec 5 09:37:01.611: EIGRP-IPv4(1): Neighbor 1.1.1.1 not on common subnet for FastEthernet1/1
NOTE: PoC is attached below.
Configuration :
HUB-ACTIVE
redundancy
ip tcp synwait-time 5
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp policy 2
encr 3des
hash md5
group 2
crypto isakmp key FORISP1 address 1.1.1.4
crypto isakmp key FORISP2 address 2.2.2.4
crypto ipsec transform-set ISP1SET esp-3des esp-md5-hmac
crypto ipsec transform-set ISP2SET esp-3des esp-md5-hmac
crypto map ISP1MAP 1 ipsec-isakmp
set peer 1.1.1.4
set transform-set ISP1SET
match address 100
crypto map ISP2MAP 2 ipsec-isakmp
set peer 2.2.2.4
set transform-set ISP2SET
match address 100
interface Tunnel1
description ***ACTIVE-PATH-1-****
ip address 172.16.10.1 255.255.255.0
no ip redirects
ip nhrp map multicast dynamic
ip nhrp network-id 1
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 1111
interface Tunnel2
description ***ACTIVE-PATH-2-****
ip address 90.90.90.1 255.255.255.0
no ip redirects
ip nhrp network-id 2
delay 6000
tunnel source FastEthernet1/1
tunnel key 2222
interface FastEthernet0/0
description ***ISP-1-PRIMARY***
ip address 1.1.1.2 255.255.255.0
duplex auto
speed auto
standby 2 ip 1.1.1.5
standby 2 priority 110
standby 2 preempt
standby 2 name wlanisp1
crypto map ISP1MAP
interface FastEthernet0/1
description ***LAN-INTERFACE***
ip address 192.168.10.2 255.255.255.0
--More--
*Dec 5 09:34:06.915: EIGRP-IPv4(1): Neighbor 2.2.2.1 not on common subnet for FastEthernet0/0
duplex auto
speed auto
standby 1 ip 192.168.10.5
standby 1 priority 110
standby 1 preempt
standby 1 name inlan
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/1
description ***ISP-2-SECONDARY***
ip address 2.2.2.2 255.255.255.0
duplex auto
speed auto
standby 3 ip 2.2.2.5
standby 3 priority 110
standby 3 preempt
standby 3 name wanisp2
crypto map ISP2MAP
router eigrp 1
network 1.1.1.0 0.0.0.255
network 2.2.2.0 0.0.0.255
network 90.90.90.0 0.0.0.255
network 172.16.10.0 0.0.0.255
network 192.168.10.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.30.0 255.255.255.0 1.1.1.4
ip route 192.168.30.0 255.255.255.0 2.2.2.4 10
ip route 192.168.50.0 255.255.255.0 192.168.10.4
access-list 100 permit ip 192.168.50.0 0.0.0.255 192.168.30.0 0.0.0.255
nls resp-timeout 1
cpd cr-id 1
no cdp log mismatch duplex
control-plane
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
gatekeeper
shutdown
HUB-STANDBY
redundancy
encr 3des
hash md5
encr 3des
hash md5
group 2
set peer 1.1.1.4
match address 100
set peer 2.2.2.4
match address 100
interface Tunnel3
description ***STANDBY-PATH-1-***
ip address 200.200.200.1 255.255.255.0
no ip redirects
ip nhrp network-id 3
delay 7000
tunnel key 3333
interface Tunnel4
description ***STANDBY-PATH-2-***
ip address 50.50.50.1 255.255.255.0
no ip redirects
ip nhrp network-id 4
delay 8000
tunnel key 4444
ip address 1.1.1.1 255.255.255.0
duplex auto
speed auto
standby 2 preempt
standby 2 name wanisp1
crypto map ISP1MAP
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
standby 1 preempt
no ip address
shutdown
duplex auto
speed auto
ip address 2.2.2.1 255.255.255.0
duplex auto
speed auto
standby 3 preempt
crypto map ISP2MAP
router eigrp 1
network 50.50.50.0 0.0.0.255
network 200.200.200.0
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
SPOKE2
redundancy
interface Tunnel1
ip address 172.16.10.2 255.255.255.0
no ip redirects
ip nhrp map multicast 1.1.1.2
ip nhrp map 172.16.10.1 1.1.1.2
ip nhrp nhs 172.16.10.1
tunnel key 1111
interface Tunnel2
ip address 90.90.90.2 255.255.255.0
no ip redirects
ip nhrp map multicast 2.2.2.2
ip nhrp map 90.90.90.1 2.2.2.2
ip nhrp nhs 90.90.90.1
delay 6000
tunnel key 2222
interface Tunnel3
ip address 200.200.200.2 255.255.255.0
no ip redirects
ip nhrp map multicast 1.1.1.1
ip nhrp map 200.200.200.1 1.1.1.1
ip nhrp nhs 200.200.200.1
delay 7000
tunnel key 3333
interface Tunnel4
ip address 50.50.50.2 255.255.255.0
no ip redirects
ip nhrp map multicast 2.2.2.1
ip nhrp map 50.50.50.1 2.2.2.1
ip nhrp nhs 50.50.50.1
delay 8000
tunnel key 4444
ip address 1.1.1.3 255.255.255.0
duplex auto
speed auto
ip address 192.168.20.1 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip address 2.2.2.3 255.255.255.0
duplex auto
speed auto
router eigrp 1
network 192.168.20.0
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
14 Replies 14
Georg Pauwen
add the physical interfaces to your topology diagram, so we can see what the physical connections look like.
configuration has attached below.
just try one thing,
Hub have two tunnel to same Spoke, just remove one tunnel and see result.
IT Showing the same error.
HUB-ACTIVE:  *Dec 5 19:39:43.427: EIGRP-IPv4(1): Neighbor 2.2.2.1 not on common subnet for FastEthernet0/0
                         *Dec 5 19:40:05.819: EIGRP-IPv4(1): Neighbor 2.2.2.1 not on common subnet for FastEthernet0/0
HUB-STANDBY:  *Dec 5 19:39:24.435: EIGRP-IPv4(1): Neighbor 1.1.1.1 not on common subnet for FastEthernet1/1
                            *Dec 5 19:39:44.731: EIGRP-IPv4(1): Neighbor 2.2.2.3 not on common subnet for FastEthernet0/0
SPOKE2:  *Dec 5 19:38:15.123: EIGRP-IPv4(1): Neighbor 2.2.2.1 not on common subnet for FastEthernet0/0
                  *Dec 5 19:38:25.131: EIGRP-IPv4(1): Neighbor 1.1.1.3 not on common subnet for FastEthernet1/1
HUB-STANDBY:
redundancy
encr 3des
hash md5
encr 3des
hash md5
group 2
set peer 1.1.1.4
match address 100
set peer 2.2.2.4
match address 100
interface Tunnel3
no ip redirects
delay 7000
tunnel key 3333
duplex auto
speed auto
standby 2 preempt
crypto map ISP1MAP
duplex auto
speed auto
standby 1 preempt
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
standby 3 preempt
crypto map ISP2MAP
router eigrp 1
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
HUB-ACTIVE:
redundancy
encr 3des
hash md5
encr 3des
hash md5
group 2
set peer 1.1.1.4
match address 100
set peer 2.2.2.4
match address 100
interface Tunnel1
no ip redirects
tunnel key 1111
duplex auto
speed auto
standby 2 preempt
crypto map ISP1MAP
duplex auto
speed auto
standby 1 preempt
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
standby 3 preempt
crypto map ISP2MAP
router eigrp 1
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
SPOKE2:
redundancy
interface Tunnel1
no ip redirects
tunnel key 1111
interface Tunnel3
no ip redirects
delay 7000
tunnel key 3333
duplex auto
speed auto
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
router eigrp 1
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
now showing this error on HUB_STANDBY: *Dec 5 20:03:43.723: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 200.200.200.2 (Tunnel3) is down: retry limit exceeded
can I see the config ?
SPOKE2 cannot find the route for 192.168.50.0/24 using eigrp, now what shoud i do ??
HELP !!
HUB-STANDBY:
no ip domain lookup
no ipv6 cef
redundancy
encr 3des
hash md5
encr 3des
hash md5
group 2
set peer 1.1.1.4
match address 100
set peer 2.2.2.4
match address 100
interface Tunnel3
no ip redirects
delay 7000
tunnel key 3333
duplex auto
speed auto
standby 2 preempt
crypto map ISP1MAP
duplex auto
speed auto
standby 1 preempt
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
standby 3 preempt
crypto map ISP2MAP
router eigrp 1
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
HUB-ACTIVE:
redundancy
encr 3des
hash md5
encr 3des
hash md5
group 2
set peer 1.1.1.4
match address 100
set peer 2.2.2.4
match address 100
interface Tunnel1
no ip redirects
tunnel key 1111
duplex auto
speed auto
standby 2 preempt
crypto map ISP1MAP
duplex auto
speed auto
standby 1 preempt
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
standby 3 preempt
crypto map ISP2MAP
router eigrp 1
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
SPOKE2:
redundancy
interface Tunnel1
no ip redirects
tunnel key 1111
interface Tunnel2
no ip address
interface Tunnel3
no ip redirects
delay 7000
tunnel key 3333
duplex auto
speed auto
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
router eigrp 1
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
this is my Note about the DMVPN,
I see the topology you share before you config SW between Hubs and Spokes, instead the internet cloud will represent Router that connect to all hub and spoke.
let assume this Internet cloud as Rcloud, and all Hub and Spoke can talk to each other before config the tunnel.
after they reachable then we can config the tunnel and specify the source and NHS ip address.
for HSRP, the HSRP in other side of Hub not the side that connect to Internet but the side that serve LAN.
NOTE:- one same tunnel key for each DMVPN cloud "by the way the DMVPN cloud is the subnet of the tunnel you config."
add the physical interfaces and IP addresses used on these interfaces to your topology drawing...
I use this topology as general whatever the ip address of ISP.
thanks a lot for your note.
what interfaces are directly connected to the interfaces marked in bold:
HUB-ACTIVE:
1.1.1.0/24 is directly connected, FastEthernet0/0
2.2.2.0/24 is directly connected, FastEthernet1/1
192.168.10.0/24 is directly connected, FastEthernet0/1
172.16.10.0/24 is directly connected, Tunnel1
90.90.90.0/24 is directly connected, Tunnel2
HUB-STANDBY:
200.200.200.0/24 is directly connected, Tunnel3
50.50.50.0/24 is directly connected, Tunnel4
SPOKE2:
192.168.20.0/24 is directly connected, FastEthernet0/1
Hi friend any news about your issue? do you complete the lab or not?
