OBFL MSG bootdisk process
fouad.jabri
Visitor
Hi everyone,
Our Cisco 7600 router is showing a very high CPU on module 9, the process responsible for that is OBFL MSG bootdis, remote command on the module show the following:
CPU utilization for five seconds: 100%/0%; one minute: 99%; five minutes: 99%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
221 1866316032 433962585 4300 86.54% 89.61% 89.43% 0 OBFL MSG bootdis
160 2148562956 30396648 70684 9.36% 4.50% 4.29% 0 CFIB LC STATS Ta
177 1092895520 34388426 31781 2.35% 1.92% 1.90% 0 x40g TCAM Mgr Ta
18 319749644 7038311 45430 1.17% 0.58% 0.56% 0 TYFIB Table Mana
157 103780944 37453298 2770 0.07% 0.01% 0.00% 0 CFIB LC Main Tas
131 19733180 48750569 404 0.07% 0.01% 0.00% 0 NP STATS Task
36 27853412 11147713 2498 0.07% 0.06% 0.06% 0 ENVM Background
161 4848912 380901714 12 0.07% 0.00% 0.00% 0 x40g_metropolis_
200 7442352 104925611 70 0.07% 0.00% 0.00% 0 SSM connection m
have you any idea about this process?
Fouad
Vinit Jain
Hello Fouad,
Could you please run the command :
show module 9 logging onboard
Did you enable onboard logging recently on slot 9 or on the device itself. I also would like to know how much space is available on the disk on slot 9.  Please capture the below outputs in a file:
show version | in image
show mod 9
remote command mod 9 show log
remote command mod 9 show process cpu sort | ex 0.0
show file system
Vinit
--Vinit
I would also like to add some more information on OBFL:
The onboard failure logging (OBFL) feature gathers boot, environmental, and critical hardware failure data for field-replaceable units (FRUs), and stores the information in the nonvolatile memory of the FRU. This information is used for troubleshooting, testing, and diagnosis if a failure or other error occurs. Because OBFL is on by default, data is collected and stored as soon as the card is installed. If a problem occurs, the data can provide information about historical environmental conditions, uptime, downtime, errors, and other operating conditions.
Source - http://www.cisco.com/c/en/us/td/docs/routers/7600/install_config/ES40_config_guide/es40_sw_config/es40_chap8.html
Hope this helps
Vinit
PS: Please rate useful posts.
--Vinit
Hi Vinit,
here is the output:
#show logging onboard module 9
This device does not support OBFL
Fouad Jabri
