problem with gns3
palaiologosbyz
Community Member
Hi guys,
I am writing because I have a big problem with gns3.
1)    I downloaded and decompressed the ios image file named “c1700-advipservicesk9-mz.124-15.T11” with winrar. I did not use cisco image upacker ( is this wrong?)
2)    I chose the project directory and the image directory for gns3. To make it more simple I used the same folder for gns3 projects and images.
3)    I configured dynamips. I Enabled the options “ghost ios feature’’,  ’’mmap support’’ and I checked that dynamips was working perfectly.
4)    Then from gns3 I chose the decompressed image named “C1700-AD ‘’
FIRST TROUBLE
I saw a message stating that  “The path you have selected should contain only ascii (English) characters.
Dynamips does not support Unicode on Windows”
In spite of this message the image ios was loaded.
5)    I left the base config option as “baseconfig.txt” (should I change it?)
6)    I chose the platform and the model (I am sure about the platform but I am not sure about the exact model…On step 7 I checked all the models but no one was working. Of course the image file is not false I have checked it)
7)    I saved the image  and then dragged the router image of the platform in order to design my network.Everything worked perfect till then.
SECOND TROUBLE
I saw a message stating209-UNABLE TO START VM INSTANCE-R1’’
Of course my router cannot boot up and I don’t know what I do wrong.Of course I tried it many times with lots of images but every time happened the same thing.
I would appreciate if someone of you helped guys! Thank you in advance! I am waiting for suggestions because I need gns3 in order to practice for ccnp routing!
23 Replies 23
In hypervisor I don't see anything in right panel, click on save  and what about the IOS image Tab
And in Dynamips: put the absolute  path to the executable
Regards.
what exactly do you mean?
Date: Tue, 1 Feb 2011 02:09:18 -0700
To: d.karanatsios@hotmail.com
Subject: New message: "problem with gns3"
jim karan,
A new message was posted in the Discussion thread "problem with gns3":
https://supportforums.cisco.com/message/3282738#3282738
Author : cadetalain
Profile : https://supportforums.cisco.com/people/cadetalain
Message:
in the hypervisors.jpg Idon't see anything in right panel and I should but to do so
you must click on save button at the bottom and do the same for the IOS image tab next to hypervisor tab
Regards.
the same result!
Date: Tue, 1 Feb 2011 02:42:46 -0700
jim karan,
https://supportforums.cisco.com/message/3282796#3282796
Author : cadetalain
Message:
The IOS you are using works only for 1760 with min 160/32
Regards.
really? hat do you mean min 160/32.how can i configure that?.......where can i find a catalogue with the image ios and the exact models?
Date: Tue, 1 Feb 2011 03:48:33 -0700
jim karan,
https://supportforums.cisco.com/message/3282828#3282828
Author : cadetalain
Message:
160 is dram and 32 is flash.
Regards.
how can i configure these things in gns3?
Date: Tue, 1 Feb 2011 04:32:19 -0700
jim karan,
https://supportforums.cisco.com/message/3282869#3282869
Author : cadetalain
Message:
Don't you think you should read a little bit the GNS3 documentation you would know where to configure these.
By the way for first error with ascii chars it is because your path contains greek chars which are unicode and not ascii.
see there: http://www.gns3.net/phpBB/topic232.html?sid=ec481a1d72e2d8c6c08f92f717c7ac54
Regards.
Alain.
