Process for small system changes - Hostname
bradleyordner
Level 5
Level 5
When in vManage mode, what is the best way to change the hostname of a vEdge or ASR router? It can't be modified in device template so do you have to move the device to CLI, update and then reattach?
what version are you on ?
did you go to configuration > Devices > Change Values > then you should be able to change
6 Replies 6
svemulap@cisco.com
If the device is in vMange Mode means, there is a template attached to it. Should be able to edit the template and push the (appropriate) change to this specific device. It should work.
The hostname doesn't seem to be a variable I can change when
selecting change device values?
sasig
most likely your system feature template does not have device specific for the hostname, i would check that first. see the screenshotScreen Shot 2021-01-06 at 9.39.00 AM.png
hi i have enabled this but still i cant find host-name change option when i want to change the hostname from tamplate
I found the variable further down, thanks.
Brad
