QUIC Protocol Disable methods
Is there a way we can disable QUIC protocol on the Guest client browsers (Captive portal via Cisco ISE) to ensure Content filtering works as expected on the MX/Firewall ?
6 Replies 6
Brash
Meraki Community All-Star
BlakeRichardson
This premise of QUIC is good but it creates all sorts of issues with content filtering and SSL inspection.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
aleabrahao
Block UDP/443 on MX for Guest VLAN. This is the simplest and most effective method.
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
Tell me whether blocking on the Zscaler DNS will prevent the QUIC protocol issues?
Blocking only via Zscaler DNS may reduce some QUIC‑related issues, but it will not reliably prevent QUIC. For consistent results, you need to block QUIC at the network/HTTP proxy level, not just DNS.
