Restrict users to execute command no ip vrf
alihashmi43
Community Member
How can I restrict all users from executing no IP vrf command in cisco 7206 router?. Below are the configurations for the reference:
R1(config-if)#ip vrf jaylink
R1(config-vrf)#no ip vrf jaylink
7 Replies 7
balaji.bandi
you need to create a Role based access with Limited commands, best is use TACACS / Radius ?
do you have one or is the user local ?
BB
Its a local user.
if the local user you need to add manually, what command for the user to give access Look at the example : (this is for IOX XE, simlar command should work for IOS)
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_cfg/configuration/xe-16/sec-usr-cfg-xe-16-book/sec-role-base-cli.html
BB
@balaji.bandi On a side note, the document you linked does not fully work the same on older IOS routers. E.g. the secret password for the parser view cannot be encrypted...
Agreed...It's been a while I use VXR for more than 10 years I guess. (thanks for the heads up, that is the reason mentioned note - similar commands "may work" (missed that on the post) on IOS).
BB
Georg Pauwen
here is a configuration example:
Let's say you want a user with username 'security' to not be able to execute the 'ip vrf' or 'no ip vrf' commands (you can tweak this in whichever way you want). First you have to go into root view and create the new view (also named 'security' for the sake of simplicity:
R1#enable view
Password: enable_secret
R1#conf t
R1(config)#parser view security
R1(config-view)#secret password
R1(config-view)#commands configure include all interface
R1(config-view)#commands configure exclude ip vrf
R1(config-view)#commands configure include all ip
R1(config-view)#commands exec include all configure terminal
The user can now execute all 'configure terminal' and subsequent 'ip' and 'interface' commands (add more depending on what that user needs). All 'ip vrf' commands are blocked.
Here is what the entire configuration would look like:
R1
hostname R1
enable secret 5 $1$wHIN$LLnMPn6NJri7/NIf20eLI1
aaa new-model
aaa authentication login default local
username cisco privilege 15 password 0 cisco
username root privilege 15 view root password 0 cisco
username security view security password 0 cisco
secret 5 $1$jwYr$0UigFzC8bU8EWrhBZcI0M1
line vty 0 4
login authentication default
Hello
You can use privilege level to control users cli or you can use RBCLI if applicable which can be more definitive, given you mention 7206 rtr i am assuming it supports both features and options are numerous.
Two basic examples below:
Basic local AAA
username ROOT privilege 15 algorithm-type scrypt secret xxxxxx
username RBCLIuser algorithm-type scrypt secret xxxxxx
username PRIVuser privilege 5 algorithm-type scrypt secret xxxxxx
password encryption aes
aaa new-model
aaa authorization exec default local if-authenticated
aaa authorization console
RBCLI
parser view RBCLI
secret xxxxxx
commands configure include interface
commands configure include ip
commands configure exclude vrf
commands exec include configure terminal
commands exec include show ip interface brief
commands exec include show version
commands exec include show running-config
commands exec include logout
commands configure include interface GigabitEthernet0/0
commands interface include shutdown
commands interface include ip address
Logon using RBACLIuser enter password then:
enable view RBCLI
<enrer parser view password>
Privilege cli
privilege exec level 15 ssh
privilege exec level 15 telnet
privilege exec level 15 reload
privilege configure level 15 ip
privilege configure level 15 vrf
privilege exec level 5 configure terminal
privilege configure level 5 interface
privilege configure level 5 interface no shutdown
Logon using PRIVuser enter password
(user will then be in its assigned privlege level)
Kind Regards
Paul
