Route-map wrong!
qumarce-habibzadeh
Hello together
I am testing route-map in GNS3 but my trace does not go whereby R3: 16.16.16.2.
What should I change?
Thanks in advance
R1#
interface FastEthernet0/0
 duplex half
interface FastEthernet2/0
 ip address 15.15.15.1 255.255.255.252
interface FastEthernet3/0
 ip address 16.16.16.1 255.255.255.252
 ip policy route-map pbr
router eigrp 1
 network 15.15.15.0 0.0.0.3
 network 16.16.16.0 0.0.0.3
 network 192.168.1.0
 no auto-summary
 eigrp router-id 1.1.1.1
 neighbor 15.15.15.2 FastEthernet2/0
 neighbor 16.16.16.2 FastEthernet3/0
ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 101 permit ip host 192.168.1.11 host 8.8.8.8
route-map pbr permit 20
 match ip address 101
 set ip next-hop 16.16.16.2
PC1> trace 8.8.8.8
trace to 8.8.8.8, 8 hops max, press Ctrl+C to stop
 1   192.168.1.1   14.411 ms  15.883 ms  13.341 ms
 2   15.15.15.2   48.863 ms  43.685 ms  46.043 ms
 3   *13.13.13.2   76.037 ms (ICMP type:3, code:3, Destination port unreachable)
Hi @qumarce-habibzadeh ,
The route-map is fine, but it is applied to the wrong interface. Remove the "ip policy route-map pbr" from fa3/0 and put it on the interface facing the PC (fa0/0).
Hi Harold!
Thanks a lot for your tip. It is going perfect on!
PC1> trace 8.8.8.8
1 192.168.1.1 44.025 ms 30.353 ms 17.088 ms
2 16.16.16.2 45.774 ms 44.807 ms 45.397 ms
3 *12.12.12.2 78.242 ms (ICMP type:3, code:3, Destination port unreachable)
You are very welcome @qumarce-habibzadeh and thanks for the feedback.
