simple wan setup
jetlen123071
Community Member
good day, i am a newbie with regards to cisco. just wanted to ask for help. the scenario is i was able to connect to bldg (A and B) by using 1600 and 1700 series routers thru a lease line. The internet on Bldg A is connected thru ADSL (cisco 837. How can i access the internet from bldg B?is this an issue of routing or access list on the ADSL modem? i am confuse, here is the config of the ADSL modem (cisco 837). thank you
Current configuration : 1640 bytes
version 12.4
no service pad
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
resource policy
clock timezone Magadan 11
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool pool-dhcp
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 202.x.x.5 202.80.32.7
lease infinite
ip cef
ip domain name xxxxxxxxx
interface Ethernet0
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname xxxxxxxx
ppp chap password 0 xxxxxxx
ppp pap sent-username xxxxxx password 0 xxxxxxx
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 2 remark SDM_ACL Category=1
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
8 Replies 8
paolo bevilacqua
Please don't call the 837 a modem because it is an almost fully featured router.
Now for your problem, on the 837 add in access-list 1 all the networks that you want to allow to access the internet.
Then on all the routers configure:
router rip
network z.z.z.z <- place all your networks in there using multiple network statements
redistribute static subnets
version 2
That should do it. It is not the most optimized configuration, but good to begin with. Once you have it working, you can come back with more questions.
Hope this helps,please rate post if it does!
hello,
firstly my apologies with regards to the cisco 837. sir, i followed your instruction, and when i tested it i still cannot access the internet. from bldg B(router) my ping can only reach up to the bldg A(router). sir the 837 cisco is on bldg A. here is the config of the two routers.
BLDG B ROUTER
ip subnet-zero
ip name-server xxxxxxxxxx
interface Ethernet0
description line
ip address 192.168.2.200 255.255.255.0
no ip directed-broadcast
interface Serial0
ip address 10.0.0.1 255.255.255.0
router rip
network 10.0.0.0
network 192.168.2.0
ip nat inside source list 10 interface FastEthernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.2
ip route 192.168.2.0 255.255.255.0 10.0.0.2
access-list 10 permit 10.10.10.0 255.255.255.0
line con 0
line 1
line vty 0 4
____________________________
BLDG A ROUTER
ip subnet-zero
ip address 10.10.10.2 255.255.255.0
speed auto
interface Serial0
ip address 10.0.0.2 255.255.255.0
interface Serial1
no ip address
shutdown
router rip
network 10.0.0.0
network 192.168.2.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip route 192.168.2.0 255.255.255.0 10.0.0.1
no ip http server
access-list 10 permit 192.168.2.0 255.255.255.0
line con 0
line aux 0
line vty 0 4
end
Your help is highly appreciated. again my apologies being a newbie.
You have configured access list 10 with subnet mask instead of wildcard mask. Static route should point to dialer interface. Apply the following config and try.
BLDG A ROUTER:
no ip route 0.0.0.0 0.0.0.0 10.10.10.1
no access-list 10
access-list 10 permit 10.10.10.0 0.0.0.255
access-list 10 permit 192.168.2.0 0.0.0.255
BLDG B ROUTER:
no ip nat inside source list 10 interface FastEthernet0 overload
no ip route 192.168.2.0 255.255.255.0 10.0.0.2
Sundar
hello sir,
i've followed your instruction, the only thing that cannot be done is the "ip route 0.0.0.0 0.0.0.0 Dialer1" error is invalid input. please correct me if i'm wrong, it is because i don't have any dialer configured in router A. the dialer1 is configured in the 837 router. here is the ping test that i did.
from the 837 console.
-ping Ethernet port (router A) fine
-ping serial port (router A) no reply
-ping Ethernet port (router B) no reply
-ping serial port (router B) fine
from the router A console
no problem
from the router B console
-ping is fine up to the ethernet port of router A (10.10.10.2)
-ping to the cisco 837 (10.10.10.1) no reply
Sir here is the 837 config
dns-server xxxxxxxxxxxxx
lease infinite
ip cef
ip domain name xxxxxxxxx!
interface Ethernet0
ip nat inside
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
pvc 8/35
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname xxxxxxxxxxx
ppp pap sent-username xxxxxxxx password 0 xxxxxxxx
ip route 10.10.10.0 255.255.255.0 10.0.0.2
ip http server
ip http server
access-list 1 permit 0.0.0.0 255.255.255.0
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
thank you for being so patient with me.
under "router rip", in all routers including 837, please configure
version 2
redistribute static connected
You can then eliminate the 10.x.x.x static routes.
thank you so much guys, really appreciate your help.. by the way, i notice that it is running only on 10mbps, how can i set it up to run on 100? if my question in not appropriate, i'm very sorry.
Hi, try
speed 100
duplex full
On the interfaces that you know can support that speed.
Hello Jetlen,
My remark was made in jokeful way, you don't have to apologize for anything, now if you apply Sundar's good advice you will have this working in no time, good luck and please feel free to come back with more questions if you have.
