Strange Problem
edie
Community Member
Hi ppl
i am facing a strange problem please see the pic attached
i have a 3620 and a 2501 at location A
router a loc B(2501) is connected to rouetr a Loc A (2501). placing two routers at a location makes no sense so i thought to pick 2501 placed at location A. to do this i just configured a serial port s0/5 may be on the same network as is router 2501 at loc B
its strange that only 2501 at loc A communicates with that at Loc B
3620 at loc A cannot communicate with 2501 at Loc B
can somebody gimme advice to get out of this?
Adnan
5 Replies 5
The reason the 2501 in location A can communicate with the 2501 in location B is that they are directly connected. You need to have either a routing protocol or static routes configured in order to provide full connectivity between all routers?
Hope this helps,
i think i could not clarify my question
2501 is connected to 2501
when i connect 2510 of locb to 3620 of loc A through serial port(E1) and bring both the ports on same netwrok i.e 192.1.26.0/24 they should be able to ping each other
rotuing is next step when i nedd to access these machine from any third machine
they both dont speak to each other even when physically connected
edie
Community Member
infact this diagram shows what i want to do
i want to take 2501 at loc A to be taken out and deployed somewhere else
nitinj
Community Member
Did you check the serial interface is OK I mean is it working fine...wht is the interface status when u connect E1 link on 3700 or whtever router to 2501 series route at location B ?? did u connect location B router on different port of 3700 series router..
NK
edie
Community Member
yeh
infact at layer 1 the interfaces are up when i connect. i am infact using v35 to g703 convertors to transport E1s
line protocol actually is intermitenet
goes up and down
