%SYS-2-GETBUFFFAIL: Middle buffer allocation (208 bytes) failed
alienkidmj12
Level 2
Level 2
Hope some can assist, all my traffic hung on my router, this is a debug all after the hang and during a reload.
bifrost-cisco2951#
Aug 26 19:06:55.378: %OIR-6-INSCARD: Card inserted in slot 1, interfaces administratively shut down
Aug 26 19:06:55.390: %SCHED-7-WATCH: Attempt to set uninitialized watched boolean (address 0). -Process= "<interrupt level>", ipl= 2
-Traceback= 5CE1848z 404F35Cz 449C1B4z 4A1DAFCz 44B1348z 4026134z 40AF280 z 40AF280z 40261F0z 4F801E8z
Aug 26 19:07:50.471: %CELLWAN-2-HEART_BEAT_TIMEOUT: No heart beat signal from Cellular0/3/0
Aug 26 19:07:52.911: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virt ual-Access2, changed state to down
.Aug 26 19:07:52.915: %DIALER-6-UNBIND: Interface Vi2 unbound from profil e Di1
.Aug 26 19:07:52.919: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
bifrost-cisco2951#
bifrost-cisco2951#
bifrost-cisco2951#ping 192.168.0.1
Sending 5, 100-byte ICMP Echos to 192.168.0.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
.Aug 26 19:11:54.997: %VDSL_DAEMON-3-MODEMRESET: VDSL Modem reset. Reloading the modem.
.Aug 26 19:11:54.997: %CONTROLLER-5-UPDOWN: Controller VDSL 0/0/0, changed state to down
.Aug 26 19:11:55.997: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0/0, changed state to down
bifrost-cisco2951#
bifrost-cisco2951#
.Aug 26 19:13:55.056: %VDSL_DAEMON-3-INITFAIL: VDSL Daemon Boot init retries done max times init failed.
bifrost-cisco2951#
bifrost-cisco2951#
bifrost-cisco2951#show interfaces
Embedded-Service-Engine0/0 is administratively down, line protocol is down
Hardware is Embedded Service Engine, address is 0000.0000.0000 (bia 0000.0000.0000)
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive set (10 sec)
Last input never, output never, output hang never
Input queue: 0/64/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 packets output, 0 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier
GigabitEthernet0/0 is down, line protocol is down
Hardware is PQ3_TSEC, address is a44c.11bb.a640 (bia a44c.11bb.a640)
Description: DESKTOP_PC
MTU 9014 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Full Duplex, 1Gbps, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
0 watchdog, 0 multicast, 0 pause input
0 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/1 is up, line protocol is up
Hardware is PQ3_TSEC, address is a44c.11bb.a641 (bia a44c.11bb.a641)
Description: POWERLINE_ADAPTER
output flow-control is unsupported, input flow-control is XON
Last input 00:08:15, output 00:08:15, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2
Output queue: 40/40 (size/max)
1197372 packets input, 204264229 bytes, 0 no buffer
Received 72826 broadcasts (0 IP multicasts)
1617399 packets output, 768866157 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
1 unknown protocol drops
1 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/2 is up, line protocol is up
Hardware is PQ3_TSEC, address is a44c.11bb.a642 (bia a44c.11bb.a642)
Description: TO_ETHERSWITCH
Last input 00:08:14, output 00:08:14, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 7
5 minute input rate 48000 bits/sec, 82 packets/sec
5 minute output rate 2268000 bits/sec, 174 packets/sec
12810500 packets input, 2229892569 bytes, 0 no buffer
Received 220355 broadcasts (0 IP multicasts)
124 input errors, 0 CRC, 0 frame, 124 overrun, 0 ignored
0 watchdog, 5028 multicast, 0 pause input
20084122 packets output, 23361258786 bytes, 0 underruns
12 unknown protocol drops
ATM0/0/0 is administratively down, line protocol is down
Hardware is MPC ATMSAR, address is a44c.11bb.a648 (bia a44c.11bb.a648)
Description: no_longer_used
MTU 1600 bytes, sub MTU 1600, BW 4608 Kbit/sec, DLY 80 usec,
Encapsulation ATM, loopback not set
Keepalive not supported
Encapsulation(s): AAL5
8 maximum active VCs, 1024 VCs per VP, 0 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Queueing strategy: Per VC Queueing
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
Ethernet0/0/0 is up, line protocol is down
Hardware is VDSL_ETHERNET, address is a44c.11bb.a648 (bia a44c.11bb.a648)
Description: VDSL ADSL Interface
MTU 1508 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 5/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Last input 12:49:11, output 00:08:14, output hang never
Output queue: 6/1024 (size/max)
5 minute input rate 2283000 bits/sec, 174 packets/sec
5 minute output rate 55000 bits/sec, 82 packets/sec
19778632 packets input, 24080479386 bytes, 0 no buffer
0 runts, 0 giants, 1 throttles
12307479 packets output, 2306633836 bytes, 0 underruns
Ethernet0/0/0.101 is up, line protocol is down
Encapsulation 802.1Q Virtual LAN, Vlan ID 101.
GigabitEthernet2/0 is administratively down, line protocol is down
Hardware is PSE2, address is a44c.11bb.a680 (bia a44c.11bb.a680)
Description: <== CONNECTION_TO_BACKPLANE - MUST_BE_ENABLED_TO_PROVIDE_POWER_TO_IP_PHONES - CONNECTED_TO_GigabitEthernet0/18 ==>
Internet address is 1.0.0.1/24
Full Duplex, 1Gbps, media type is internal
output flow-control is XON, input flow-control is XON
Last input 00:08:15, output 00:08:43, output hang never
490715 packets input, 74345734 bytes, 0 no buffer
Received 155516 broadcasts (0 IP multicasts)
1 packets output, 60 bytes, 0 underruns
17889 unknown protocol drops
0 lost carrier, 0 no carrier, 42225 pause output
GigabitEthernet2/0.1 is administratively down, line protocol is down
GigabitEthernet2/0.10 is administratively down, line protocol is down
Encapsulation 802.1Q Virtual LAN, Vlan ID 10.
GigabitEthernet2/0.20 is administratively down, line protocol is down
Encapsulation 802.1Q Virtual LAN, Vlan ID 20.
GigabitEthernet2/0.30 is administratively down, line protocol is down
Encapsulation 802.1Q Virtual LAN, Vlan ID 30.
GigabitEthernet2/1 is administratively down, line protocol is down
Hardware is EE Internal Service Module, address is 0000.0000.000a (bia 0000.0000.000a)
Description: <== CONNECTION_TO_BACKPLANE - MUST_BE_ENABLED_TO_PROVIDE_POWER_TO_IP_PHONES - CONNECTED_TO_GigabitEthernet0/17 ==>
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Auto-duplex, Auto-speed
Received 0 broadcasts (0 multicasts)
BVI1 is up, line protocol is up
Hardware is BVI, address is a44c.11bb.a640 (bia 0000.0000.0000)
Description: Lan Virtual interface (bridge wired + wireless)
Internet address is 192.168.0.100/24
MTU 9014 bytes, BW 1000000 Kbit/sec, DLY 5000 usec,
Input queue: 0/75/95/0 (size/max/drops/flushes); Total output drops: 0
Output queue: 0/0 (size/max)
5 minute input rate 47000 bits/sec, 80 packets/sec
5 minute output rate 2225000 bits/sec, 171 packets/sec
12254832 packets input, 2160096914 bytes, 0 no buffer
Received 0 broadcasts (52196 IP multicasts)
19719334 packets output, 23840277670 bytes, 0 underruns
BVI10 is down, line protocol is down
Hardware is BVI, address is a44c.11bb.a680 (bia 0000.0000.0000)
Internet address is 192.168.1.100/24
5 packets output, 300 bytes, 0 underruns
BVI20 is down, line protocol is down
Hardware is BVI, address is 0000.0c7e.b82c (bia 0000.0000.0000)
Internet address is 192.168.2.100/24
bifrost-cisco2951#debug all
This may severely impact network performance. Continue? (yes/[no]): yes
.Aug 26 19:15:38.782: TRACE 116 - Debug flag set 0xF
.Aug 26 19:15:38.782: XOS Debug Flags Update - updating debug flags failed
.Aug 26 19:15:38.786: XOS Debug Flags Update - updating debug flags failed
.Aug 26 19:15:38.786: ipc VDSL 0/0/0: vdsl_ipc_send, IPC Send: msg_type = 2, opcode=67, seq = 0, len=16, tx buf @0x1DE46F20, rx buf @0x1DE46F20
.Aug 26 19:15:38.786: mbx VDSL 0/0/0: vdsl_msg_send, type= 2, tx_len= 16 @0x1DE46F20, rx_len = 16 @0x1DE46F20
.Aug 26 19:15:38.786: mbx VDSL 0/0/0: vdsl_mbx_find_free_buf, Used Start 0028, Used End 0028
.Aug 26 19:15:38.786: mbx VDSL 0/0/0: vdsl_mbx_find_free_buf, Free len 1480, Addr 00000028, Max size 2960 00x 02x 67x 01x 00x 00x 00x 00x 00x 00x 00x 00x 00x 00x 00x 00x
.Aug 26 19:15:38.786: mbx VDSL 0/0/0: vdsl_mbx_send_direct, Writing to msg descriptor: 0000: hdr= E382,
total len= 16, msg len= 16, @28
.Aug 26 19:15:38.786: TX: Msg for opcode(67)...waiting for Response from Mailbox!
.Aug 26 19:15:38.786: MSIF Master Msg Handler - 2-RF_MSIF_MASTER_SYNC
.Aug 26 19:15:38.786: DB sync - my_state=13 peer_state=1 prog_state=1 active_from_boot=1 sync#=22
.Aug 26 19:15:38.786: VDSL 0/0/0: Interrupt: BOOT_INIT_READY
.Aug 26 19:15:38.786: ipc VDSL 0/0/0: vdsl_mbx_interrupt_handler, Interrupt: KEEP_ALIVE
.Aug 26 19:15:38.786: %OIR-6-REMCARD: Card removed from slot 1, interfaces disabled
.Aug 26 19:15:38.794: VDSL 0/0/0: SM_BOOT_INIT boolean event
.Aug 26 19:15:38.794: vdsl_daemon_sm VDSL 0/0/0: during state start, got event 2(boot_init_rdy)
.Aug 26 19:15:38.802: %SYS-2-GETBUFFFAIL: Middle buffer allocation (208 bytes) failed from 0x40A5748 -Process= "<interrupt level>", ipl= 2, pid= 125
-Traceback= 5CE1848z 40AA3F8z 40A7938z 40A574Cz 4FB1DECz 4FB3860z 40BA6C8z 40BD4C8z 4026134z 40AF280z 40AF280z 40261F0z 40AED7Cz 5CEA970z 5CDFE80z 5CE6060zPTM RX Ethertype : 0x8100PTM RX Ethepe : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM Rthertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x810M RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype :8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethere : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RXhertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100 RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype : 0x8100PTM RX Ethertype :
.Aug 26 19:15:38.806: scp-rx: SA:02/01 DA:0F/01 Op:0012 Sq:2737 Ln:0004 I:01
.Aug 26 19:15:38.806: 000: 00 00 00 00 ....
.Aug 26 19:15:38.810: Updating SCP ARP table for addr 0x2, mac addr 34bd.c81f.3492
.Aug 26 19:15:38.810: scp-rx: SA:02/01 DA:0F/01 Op:0012 Sq:2738 Ln:0004 I:01
.Aug 26 19:15:38.810: 000: 00 00 00 00
.Aug 26 19:15:38.810: %SM-4-BADEVENT: Event 'boot_init_rdy' is invalid for the current state 'start': vdsl_daemon_sm VDSL 0/0/0
-Traceback= 5CE1848z 77C9948z 4C1B6ACz 4C179B0z 4C18A4Cz 4F95B60z 4F7CA80z
.Aug 26 19:15:38.818: scp-tx: SA:0F/01 DA:02/01 Op:0014 Sq:2742 Ln:0000 I:00
.Aug 26 19:15:38.818: Using mac addr 34bd.c81f.3492 for dest_addr 0x2
.Aug 26 19:15:38.818: scp-tx: SA:0F/01 DA:02/01 Op:0014 Sq:2743 Ln:0000 I:00
.Aug 26 19:15:38.818: scp-tx: SA:0F/01 DA:02/01 Op:0014 Sq:2744 Ln:0000 I:00
.Aug 26 19:15:38.818: scp-tx: SA:0F/01 DA:02/01 Op:0014 Sq:2745 Ln:0000 I:00
.Aug 26 19:15:38.822: ARP DB: ARP entry of key 192.168.0.91 found
.Aug 26 19:15:38.822: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/3 is DOWN
.Aug 26 19:15:38.822: IP ARP: rcvd req src 192.168.0.92 7cdd.9073.8014, dst 192.168.0.100 BVI1
.Aug 26 19:15:38.822: ARP DB: ARP entry of key 192.168.0.92 found
.Aug 26 19:15:38.822: ARP TABLE: modifying entry 192.168.0.92/7cdd.9073.8014 on BV1 for Dynamic
.Aug 26 19:15:38.822: ARP TMR: entry 192.168.0.92 on BVI1 stopped from outter wheel
.Aug 26 19:15:38.822: ARP TMR: start timer of 14280000 msec on 192.168.0.92 on BVI1, with jitter (total delay of 14496573 msec)
.Aug 26 19:15:38.822: ARP TMR: entry 192.168.0.92 on BVI1 with delay 14496573 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.822: ARP DB: ARP entry of key 192.168.0.100 found
.Aug 26 19:15:38.822: IP ARP: sent rep src 192.168.0.100 a44c.11bb.a640,
dst 192.168.0.92 7cdd.9073.8014 BVI1
.Aug 26 19:15:38.822: ARP TMR: start timer of 14280000 msec on 192.168.0.92 on BVI1, with jitter (total delay of 15397191 msec)
.Aug 26 19:15:38.822: ARP TMR: entry 192.168.0.92 on BVI1 with delay 15397191 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:15:38.822: IP ARP: rcvd req src 192.168.0.82 00bb.3ae6.5b0b, dst 192.168.0.100 BVI1
.Aug 26 19:15:38.822: ARP DB: ARP entry of key 192.168.0.82 found
.Aug 26 19:15:38.822: ARP TABLE: modifying entry 192.168.0.82/00bb.3ae6.5b0b on BV1 for Dynamic
.Aug 26 19:15:38.822: ARP TMR: entry 192.168.0.82 on BVI1 stopped from outter wheel
.Aug 26 19:15:38.822: ARP TMR: start timer of 14280000 msec on 192.168.0.82 on BVI1, with jitter (total delay of 14861692 msec)
.Aug 26 19:15:38.822: ARP TMR: entry 192.168.0.82 on BVI1 with delay 14861692 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
dst 192.168.0.82 00bb.3ae6.5b0b BVI1
.Aug 26 19:15:38.822: ARP TMR: start timer of 14280000 msec on 192.168.0.92 on BVI1, with jitter (total delay of 15244844 msec)
.Aug 26 19:15:38.822: ARP TMR: entry 192.168.0.92 on BVI1 with delay 15244844 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:15:38.822: ARP TMR: start timer of 14280000 msec on 192.168.0.82 on BVI1, with jitter (total delay of 15005965 msec)
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.82 on BVI1 with delay 15005965 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.834: ARP DB: ARP entry of key 192.168.0.100 found
.Aug 26 19:15:38.834: IP ARP: sent rep src 192.168.0.100 a44c.11bb.a640,
.Aug 26 19:15:38.834: IP ARP: rcvd req src 192.168.0.82 00bb.3ae6.5b0b, dst 192.168.0.100 BVI1
.Aug 26 19:15:38.834: ARP DB: ARP entry of key 192.168.0.82 found
.Aug 26 19:15:38.834: ARP TABLE: modifying entry 192.168.0.82/00bb.3ae6.5b0b on BV1 for Dynamic
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.82 on BVI1 stopped from outter wheel
.Aug 26 19:15:38.834: ARP TMR: start timer of 14280000 msec on 192.168.0.82 on BVI1, with jitter (total delay of 15903895 msec)
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.82 on BVI1 with delay 15903895 msec plus 1007616 msec of inner wheel cnt inserted to outer wh
Not able to start training log generation
IP SLAs TWAMP debugging for all connection trace events is on
IP SLAs TWAMP debugging for all connection error events is on
IP SLAs TWAMP debugging for all control trace events is on
IP SLAs TWAMP debugging for all control error events is on
All possible debugging has been turned on
bifrost-cisco2951#eel, bin 176 (current bin 167)
.Aug 26 19:15:38.834: IP ARP: rcvd req src 192.168.0.92 7cdd.9073.8014, dst 192.168.0.42 BVI1
.Aug 26 19:15:38.834: ARP DB: ARP entry of key 192.168.0.92 found
.Aug 26 19:15:38.834: ARP TABLE: modifying entry 192.168.0.92/7cdd.9073.8014 on BV1 for Dynamic
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.92 on BVI1 stopped from outter wheel
.Aug 26 19:15:38.834: ARP TMR: start timer of 14280000 msec on 192.168.0.92 on BVI1, with jitter (total delay of 15710655 msec)
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.92 on BVI1 with delay 15710655 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:15:38.834: ARP DB: ARP entry of key 192.168.0.42 found
.Aug 26 19:15:38.834: ARP TMR: start timer of 14280000 msec on 192.168.0.82 on BVI1, with jitter (total delay of 15348301 msec)
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.82 on BVI1 with delay 15348301 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:15:38.834: ARP TMR: start timer of 14280000 msec on 192.168.0.92 on BVI1, with jitter (total delay of 14489302 msec)
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.92 on BVI1 with delay 14489302 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.834: ARP TMR: start timer of 14280000 msec on 192.168.0.82 on BVI1, with jitter (total delay of 15816189 msec)
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.82 on BVI1 with delay 15816189 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:15:38.834: ARP TMR: start timer of 14280000 msec on 192.168.0.92 on BVI1, with jitter (total delay of 14626214 msec)
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.92 on BVI1 with delay 14626214 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.834: ARP TMR: start timer of 14280000 msec on 192.168.0.82 on BVI1, with jitter (total delay of 14557960 msec)
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.82 on BVI1 with delay 14557960 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.834: IP ARP: rcvd req src 192.168.0.92 7cdd.9073.8014, dst 192.168.0.100 BVI1
.Aug 26 19:15:38.834: ARP TMR: start timer of 14280000 msec on 192.168.0.92 on BVI1, with jitter (total delay of 14807378 msec)
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.92 on BVI1 with delay 14807378 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.834: ARP TMR: start timer of 14280000 msec on 192.168.0.92 on BVI1, with jitter (total delay of 14591393 msec)
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.92 on BVI1 with delay 14591393 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.834: ARP TMR: start timer of 14280000 msec on 192.168.0.92 on BVI1, with jitter (total delay of 15419001 msec)
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.92 on BVI1 with delay 15419001 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:15:38.834: IP ARP: rcvd req src 192.168.0.91 7cdd.9071.0c88, dst 192.168.0.100 BVI1
.Aug 26 19:15:38.834: ARP DB: ARP entry of key 192.168.0.91 found
.Aug 26 19:15:38.834: ARP TABLE: modifying entry 192.168.0.91/7cdd.9071.0c88 on BV1 for Dynamic
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.91 on BVI1 stopped from outter wheel
.Aug 26 19:15:38.834: ARP TMR: start timer of 14280000 msec on 192.168.0.91 on BVI1, with jitter (total delay of 15277830 msec)
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.91 on BVI1 with delay 15277830 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
dst 192.168.0.91 7cdd.9071.0c88 BVI1
.Aug 26 19:15:38.834: ARP TMR: start timer of 14280000 msec on 192.168.0.82 on BVI1, with jitter (total delay of 16056380 msec)
.Aug 26 19:15:38.834: ARP TMR: entry 192.168.0.82 on BVI1 with delay 16056380 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:15:38.838: ARP DB: ARP entry of key 192.168.0.100 found
.Aug 26 19:15:38.838: IP ARP: sent rep src 192.168.0.100 a44c.11bb.a640,
.Aug 26 19:15:38.838: IP ARP: rcvd req src 192.168.0.91 7cdd.9071.0c88, dst 192.168.0.100 BVI1
.Aug 26 19:15:38.838: ARP DB: ARP entry of key 192.168.0.91 found
.Aug 26 19:15:38.838: ARP TABLE: modifying entry 192.168.0.91/7cdd.9071.0c88 on BV1 for Dynamic
.Aug 26 19:15:38.838: ARP TMR: entry 192.168.0.91 on BVI1 stopped from outter wheel
.Aug 26 19:15:38.838: ARP TMR: start timer of 14280000 msec on 192.168.0.91 on BVI1, with jitter (total delay of 14584933 msec)
.Aug 26 19:15:38.838: ARP TMR: entry 192.168.0.91 on BVI1 with delay 14584933 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.838: IP ARP: rcvd req src 192.168.0.82 00bb.3ae6.5b0b, dst 192.168.0.100 BVI1
.Aug 26 19:15:38.838: ARP DB: ARP entry of key 192.168.0.82 found
.Aug 26 19:15:38.838: ARP TABLE: modifying entry 192.168.0.82/00bb.3ae6.5b0b on BV1 for Dynamic
.Aug 26 19:15:38.838: ARP TMR: entry 192.168.0.82 on BVI1 stopped from outter wheel
.Aug 26 19:15:38.838: ARP TMR: start timer of 14280000 msec on 192.168.0.82 on BVI1, with jitter (total delay of 14849089 msec)
.Aug 26 19:15:38.838: ARP TMR: entry 192.168.0.82 on BVI1 with delay 14849089 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.838: ARP TMR: start timer of 14280000 msec on 192.168.0.91 on BVI1, with jitter (total delay of 16061571 msec)
.Aug 26 19:15:38.838: ARP TMR: entry 192.168.0.91 on BVI1 with delay 16061571 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:15:38.838: ARP TMR: start timer of 14280000 msec on 192.168.0.82 on BVI1, with jitter (total delay of 15395442 msec)
.Aug 26 19:15:38.838: ARP TMR: entry 192.168.0.82 on BVI1 with delay 15395442 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:15:38.838: ARP TMR: start timer of 14280000 msec on 192.168.0.91 on BVI1, with jitter (total delay of 15640711 msec)
.Aug 26 19:15:38.838: ARP TMR: entry 192.168.0.91 on BVI1 with delay 15640711 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:15:38.838: ARP TMR: start timer of 14280000 msec on 192.168.0.82 on BVI1, with jitter (total delay of 15152482 msec)
.Aug 26 19:15:38.838: ARP TMR: entry 192.168.0.82 on BVI1 with delay 15152482 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.838: ARP TMR: start timer of 14280000 msec on 192.168.0.91 on BVI1, with jitter (total delay of 14780346 msec)
.Aug 26 19:15:38.838: ARP TMR: entry 192.168.0.91 on BVI1 with delay 14780346 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.838: ARP TMR: start timer of 14280000 msec on 192.168.0.82 on BVI1, with jitter (total delay of 14501007 msec)
.Aug 26 19:15:38.838: ARP TMR: entry 192.168.0.82 on BVI1 with delay 14501007 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.838: ARP TMR: start timer of 14280000 msec on 192.168.0.91 on BVI1, with jitter (total delay of 14407646 msec)
.Aug 26 19:15:38.838: ARP TMR: entry 192.168.0.91 on BVI1 with delay 14407646 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.838: ARP TMR: start timer of 14280000 msec on 192.168.0.82 on BVI1, with jitter (total delay of 15028878 msec)
.Aug 26 19:15:38.838: ARP TMR: entry 192.168.0.82 on BVI1 with delay 15028878 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.838: IP ARP: rcvd req src 192.168.0.92 7cdd.9073.8014, dst 192.168.0.100 BVI1
.Aug 26 19:15:38.838: ARP DB: ARP entry of key 192.168.0.92 found
.Aug 26 19:15:38.838: ARP TABLE: modifying entry 192.168.0.92/7cdd.9073.8014 on BV1 for Dynamic
.Aug 26 19:15:38.838: ARP TMR: entry 192.168.0.92 on BVI1 stopped from outter wheel
.Aug 26 19:15:38.838: ARP TMR: start timer of 14280000 msec on 192.168.0.92 on BVI1, with jitter (total delay of 14708017 msec)
.Aug 26 19:15:38.838: ARP TMR: entry 192.168.0.92 on BVI1 with delay 14708017 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:38.838: ARP TMR: start timer of 14280000 msec on 192.168.0.92 on BVI1, with jitter (total delay of 15725247 msec)with jitter (total delay of 15088638 msec)
.Aug 26 19:15:39.358: ARP TMR: entry 192.168.0.50 on BVI1 with delay 15088638 msec plus 1007616 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:39.358: ARP DB: ARP entry of key 192.168.0.82 found
.Aug 26 19:15:39.902: ARP DB: ARP entry of key 192.168.0.17 found
.Aug 26 19:15:39.914: IP ARP: rcvd req src 192.168.0.90 740a.bc03.379f, dst 192.168.0.100 BVI1
.Aug 26 19:15:39.914: ARP DB: ARP entry of key 192.168.0.90 found
.Aug 26 19:15:39.914: ARP TABLE: modifying entry 192.168.0.90/740a.bc03.379f on BV1 for Dynamic
.Aug 26 19:15:40.326: Duplex Full
.Aug 26 19:15:40.326: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:15:40.326: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:15:40.530: IP ARP: rcvd req src 192.168.0.43 000c.29b8.a259, dst 192.168.0.35 BVI1
.Aug 26 19:15:40.530: ARP DB: ARP entry of key 192.168.0.43 found
.Aug 26 19:15:40.530: ARP TABLE: modifying entry 192.168.0.43/000c.29b8.a259 on BV1 for Dynamic
.Aug 26 19:15:40.530: ARP TMR: entry 192.168.0.43 on BVI1 stopped from outter wheel
.Aug 26 19:15:40.530: ARP TMR: start timer of 14280000 msec on 192.168.0.43 on BVI1, with jitter (total delay of 15318001 msec)
.Aug 26 19:15:40.530: ARP TMR: entry 192.168.0.43 on BVI1 with delay 15318001 msec plus 1008640 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:15:40.530: ARP DB: ARP entry of key 192.168.0.35 not found
.Aug 26 19:15:40.746: IP ARP: rcvd req src 192.168.0.41 000c.2972.bceb, dst 192.168.0.35 BVI1
.Aug 26 19:15:40.746: ARP DB: ARP entry of key 192.168.0.41 not found
.Aug 26 19:15:40.746: ARP DB: ARP entry of key 192.168.0.35 not found
.Aug 26 19:15:40.778: ARP DB: ARP entry of key 192.168.0.50 found
.Aug 26 19:15:40.918: IP ARP: rcvd req src 192.168.0.90 740a.bc03.379f, dst 192.168.0.100 BVI1
.Aug 26 19:15:40.918: ARP DB: ARP entry of key 192.168.0.90 found
.Aug 26 19:15:40.918: ARP TABLE: modifying entry 192.168.0.90/740a.bc03.379f on BV1 for Dynamic
.Aug 26 19:15:40.918: ARP TMR: entry 192.168.0.90 on BVI1 stopped from outter wheel
.Aug 26 19:15:40.918: ARP TMR: start timer of 14280000 msec on 192.168.0.90 on BVI1, with jitter (total delay of 15352652 msec)
.Aug 26 19:15:40.918: ARP TMR: entry 192.168.0.90 on BVI1 with delay 15352652 msec plus 1009664 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:15:40.918: ARP DB: ARP entry of key 192.168.0.100 found
.Aug 26 19:15:40.918: IP ARP: sent rep src 192.168.0.100 a44c.11bb.a640,
dst 192.168.0.90 740a.bc03.379f BVI1
.Aug 26 19:15:41.022: (Ethernet0/0/0): Null atm_db
.Aug 26 19:15:41.022: (atm_vc_is_bridged_dot1q)ATM: VC with handle 0x0 not found
.Aug 26 19:15:41.306: ARP DB: ARP entry of key 192.168.0.17 found
.Aug 26 19:15:41.326: mrvl_get_port_status, spec_reg:0x8040
.Aug 26 19:15:41.326: mrvl_get_port_status, spec_reg:0xFFFF
.Aug 26 19:15:41.326: mrvl_mode_read, mode:0x18018F0
.Aug 26 19:15:41.326: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:15:41.326: Duplex Full
.Aug 26 19:15:41.326: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:15:41.326: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:15:41.546: IP ARP: rcvd req src 192.168.0.43 000c.29b8.a259, dst 192.168.0.35 BVI1
.Aug 26 19:15:41.546: ARP DB: ARP entry of key 192.168.0.43 found
.Aug 26 19:15:41.546: ARP TABLE: modifying entry 192.168.0.43/000c.29b8.a259 on BV1 for Dynamic
.Aug 26 19:15:41.546: ARP TMR: entry 192.168.0.43 on BVI1 stopped from outter wheel
.Aug 26 19:15:41.546: ARP TMR: start timer of 14280000 msec on 192.168.0.43 on BVI1, with jitter (total delay of 14576948 msec)
.Aug 26 19:15:41.546: ARP TMR: entry 192.168.0.43 on BVI1 with delay 14576948 msec plus 1009664 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:41.546: ARP DB: ARP entry of key 192.168.0.35 not found
.Aug 26 19:15:41.862: IP ARP STATIC: periodic adj update #4, attempt to update 0 entries
.Aug 26 19:15:41.918: IP ARP: rcvd req src 192.168.0.90 740a.bc03.379f, dst 192.168.0.100 BVI1
.Aug 26 19:15:41.918: ARP DB: ARP entry of key 192.168.0.90 found
.Aug 26 19:15:42.326: Duplex Full
.Aug 26 19:15:42.326: mrvl_get_port_status, spec_reg:0xFFFF
.Aug 26 19:15:42.326: mrvl_mode_read, mode:0x18018F0
.Aug 26 19:15:42.326: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:15:42.326: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:15:42.326: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:15:43.326: mrvl_mode_read, mode:0x18018F0
.Aug 26 19:15:43.326: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:15:43.326: Duplex Full
.Aug 26 19:15:43.326: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:15:43.326: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:15:43.438: ARP DB: ARP entry of key 192.168.0.17 found
.Aug 26 19:15:43.922: IP ARP: rcvd req src 192.168.0.90 740a.bc03.379f, dst 192.168.0.100 BVI1
.Aug 26 19:15:43.922: ARP DB: ARP entry of key 192.168.0.90 found
.Aug 26 19:15:43.922: ARP TABLE: modifying entry 192.168.0.90/740a.bc03.379f on BV1 for Dynamic
.Aug 26 19:15:43.922: ARP TMR: entry 192.168.0.90 on BVI1 stopped from outter wheel
.Aug 26 19:15:43.922: ARP TMR: start timer of 14280000 msec on 192.168.0.90 on BVI1, with jitter (total delay of 15719282 msec)
.Aug 26 19:15:43.922: ARP TMR: entry 192.168.0.90 on BVI1 with delay 15719282 msec plus 1012736 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:15:43.922: ARP DB: ARP entry of key 192.168.0.100 found
.Aug 26 19:15:43.922: IP ARP: sent rep src 192.168.0.100 a44c.11bb.a640,
.Aug 26 19:15:43.970: ARP DB: ARP entry of key 192.168.0.92 found
.Aug 26 19:15:44.326: mrvl_get_port_status, spec_reg:0x8000
.Aug 26 19:15:44.326: MII READ PHY 0 Read reg = 0 val = 1140
.Aug 26 19:15:44.326: mrvl_get_port_status, spec_reg:0xAD48
.Aug 26 19:15:44.326: MII READ PHY 1 Read reg = 0 val = 1140
.Aug 26 19:15:44.326: mrvl_get_port_status, spec_reg:0xFFFF
.Aug 26 19:15:44.326: mrvl_mode_read, mode:0x18018F0
.Aug 26 19:15:44.326: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:15:44.326: Duplex Full
.Aug 26 19:15:44.326: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:15:44.326: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:15:44.906: ARP DB: ARP entry of key 192.168.0.17 found
.Aug 26 19:15:44.922: IP ARP: rcvd req src 192.168.0.90 740a.bc03.379f, dst 192.168.0.100 BVI1
.Aug 26 19:15:44.922: ARP DB: ARP entry of key 192.168.0.90 found
.Aug 26 19:15:44.926: ARP TABLE: modifying entry 192.168.0.90/740a.bc03.379f on BV1 for Dynamic
.Aug 26 19:15:44.926: ARP TMR: entry 192.168.0.90 on BVI1 stopped from outter wheel
.Aug 26 19:15:44.926: ARP TMR: start timer of 14280000 msec on 192.168.0.90 on BVI1, with jitter (total delay of 15435250 msec)
.Aug 26 19:15:44.926: ARP TMR: entry 192.168.0.90 on BVI1 with delay 15435250 msec plus 1013760 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:15:44.926: ARP DB: ARP entry of key 192.168.0.100 found
.Aug 26 19:15:44.926: IP ARP: sent rep src 192.168.0.100 a44c.11bb.a640,
.Aug 26 19:15:45.327: mrvl_get_port_status, spec_reg:0x8000
.Aug 26 19:15:45.327: MII READ PHY 0 Read reg = 0 val = 1140
.Aug 26 19:15:45.327: mrvl_get_port_status, spec_reg:0xAD48
.Aug 26 19:15:45.327: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:15:45.327: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:15:45.443: ARP DB: ARP entry of key 192.168.0.17 found
.Aug 26 19:15:45.559: IP ARP: rcvd req src 192.168.0.43 000c.29b8.a259, dst 192.168.0.35 BVI1
.Aug 26 19:15:45.559: ARP DB: ARP entry of key 192.168.0.43 found
.Aug 26 19:15:45.559: ARP TABLE: modifying entry 192.168.0.43/000c.29b8.a259 on BV1 for Dynamic
.Aug 26 19:15:45.559: ARP TMR: entry 192.168.0.43 on BVI1 stopped from outter wheel
.Aug 26 19:15:45.559: ARP TMR: start timer of 14280000 msec on 192.168.0.43 on BVI1, with jitter (total delay of 14560271 msec)
.Aug 26 19:15:46.327: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:15:46.603: IP ARP: rcvd req src 192.168.0.43 000c.29b8.a259, dst 192.168.0.35 BVI1
.Aug 26 19:15:46.603: ARP DB: ARP entry of key 192.168.0.43 found
.Aug 26 19:15:46.603: ARP TABLE: modifying entry 192.168.0.43/000c.29b8.a259 on BV1 for Dynamic
.Aug 26 19:15:46.603: ARP TMR: entry 192.168.0.43 on BVI1 stopped from outter wheel
.Aug 26 19:15:46.603: ARP TMR: start timer of 14280000 msec on 192.168.0.43 on BVI1, with jitter (total delay of 14835890 msec)
.Aug 26 19:15:46.603: ARP TMR: entry 192.168.0.43 on BVI1 with delay 14835890 msec plus 1014784 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:15:46.603: ARP DB: ARP entry of key 192.168.0.35 not found
.Aug 26 19:15:46.863: SPOLICY: [pid=280(QoS stats process)]: 10: Start stats polling
.Aug 26 19:15:46.863: -Traceback= 5CE6AB4z 73D2214z 73AB5D4z 73AB834z 4F95B60z 4F7CA80z
.Aug 26 19:15:46.863: SPOLICY: [pid=280(QoS stats process)]: Update show totals (periodic).
.Aug 26 19:15:46.863: -Traceback= 5CE6AB4z 73D2214z 73AB1ECz 73AB5DCz 73AB834z 4F95B60z 4F7CA80z
.Aug 26 19:15:47.327: mrvl_get_port_status, spec_reg:0xFFFF
.Aug 26 19:15:47.327: mrvl_mode_read, mode:0x18018F0
.Aug 26 19:15:47.327: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:15:47.327: Duplex Full
.Aug 26 19:15:47.327: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:15:47.327: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:15:47.627: IP ARP: rcvd req src 192.168.0.43 000c.29b8.a259, dst 192.168.0.35 BVI1
.Aug 26 19:15:48.327: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:15:48.327: Duplex Full
.Aug 26 19:15:48.327: mrvl_get_port_status, spec_reg:0xFFFF
.Aug 26 19:15:48.327: mrvl_mode_read, mode:0x18018F0
.Aug 26 19:15:48.327: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:15:48.327: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:15:48.459: ARP DB: ARP entry of key 192.168.0.50 found
.Aug 26 19:15:48.787: special_oce_change_vectors: select debug vectors
.Aug 26 19:15:48.787: fib_loadinfo_change_vectors: select debug vectors
.Aug 26 19:15:48.787: qos_oce_change_vectors: select debug vectors
.Aug 26 19:15:48.787: OCE_frr: Select debug OCE vectors
.Aug 26 19:15:48.787: lookup_ipv4_oce_change_vectors: select debug vectors
.Aug 26 19:15:48.787: lookup_ipv6_oce_change_vectors: select debug vectors
.Aug 26 19:15:48.787: push_counter_oce_change_vectors: select debug vectors
.Aug 26 19:15:48.787: IPv6-Feat: Add "debug packet" (Input) on all
.Aug 26 19:15:48.787: IPv6-Feat[Embedded-Service-Engine0/0]: Add "debug packet" (Input)
.Aug 26 19:15:48.787: IPv6-Feat[Embedded-Service-Engine0/0]: SWSB Create
.Aug 26 19:15:48.787: IPv6-Feat[Embedded-Service-Engine0/0]: Change Add "debug packet" (Input)
.Aug 26 19:15:49.395: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:15:49.523: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:15:49.523: CEF-Debug: Packet from 192.168.0.50 (BV1) to 8.8.8.8
.Aug 26 19:15:49.523: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:8.8.8.8, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:15:49.523: CFT Engine: NAT failed to find a translation
.Aug 26 19:15:49.523: CFT L4: Error: fid[3254] invalid state in state bi-established
.Aug 26 19:15:49.523: CFT Ager: set flow 3254 aging to 360000 ms
.Aug 26 19:15:49.523: No route, drop
.Aug 26 19:15:49.523: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:15:49.743: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:15:49.743: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:15:49.935: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:15:49.935: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2 Control Plane:marking in pak exception [non cef linktype ARP]
.Aug 26 19:15:50.471: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:15:50.623: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:15:50.623: CEF-Debug: Packet from 192.168.0.17 (BV1) to 193.36.79.100
.Aug 26 19:15:50.623: NAT: API parameters passed: src_addr:192.168.0.17, src_port:0 dest_addr:193.36.79.100, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:15:50.623: CFT Engine: NAT failed to find a translation
.Aug 26 19:15:50.623: CFT Ager: set flow 362 aging to 360000 ms
.Aug 26 19:15:50.623: No route, drop
.Aug 26 19:15:50.623: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:15:51.327: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:15:51.327: Duplex Full
.Aug 26 19:15:51.327: mrvl_get_port_status, spec_reg:0xFFFF
.Aug 26 19:15:51.327: mrvl_mode_read, mode:0x18018F0
.Aug 26 19:15:51.327: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:15:51.327: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:15:51.327: ethsw_ilp: Sending ILP Recovery Req to Service Module GigabitEthernet2/0
.Aug 26 19:15:51.871: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:15:51.871: CEF-Debug: Packet from 192.168.0.82 (BV1) to 52.214.212.75
.Aug 26 19:15:51.871: NAT: API parameters passed: src_addr:192.168.0.82, src_port:0 dest_addr:52.214.212.75, dest_port:0, proto:6 if_input:BVI1 pak:149AE218 get_translated:1
.Aug 26 19:15:51.871: CFT Engine: NAT failed to find a translation
.Aug 26 19:15:51.871: CFT Ager: set flow 2725 aging to 360000 ms
.Aug 26 19:15:51.875: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:15:51.875: TCPADJMSS: punt_feature
.Aug 26 19:15:51.875: IRB-CEF: LE vector failed on BVI1, enqueued to IP queue, len 153, input feature, Virtual Fragment Reassembly After IPSec Decryption(57), rtype 0, forus FALSE, sendself F
.Aug 26 19:15:52.327: IP: s=192.168.0.17 (BVI1), d=239.255.255.250, len 153, input feature, MCI Check(109), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:15:52.327: IP(0): s=192.168.0.17 (BVI1) d=239.255.255.250 id=3524, ttl=1, prot=17, len=181(153), inconsistent tableid
.Aug 26 19:15:52.511:
.Aug 26 19:15:52.511: Rudpv1 Sent: Pkts 0, Data Bytes 0, Data Pkts 0
.Aug 26 19:15:52.511: Rudpv1 Rcvd: Pkts 0, Data Bytes 0, Data Pkts 0
.Aug 26 19:15:52.511: Rudpv1 Discarded: 0, Retransmitted 0
.Aug 26 19:15:52.511: , len 56, sending full packet
.Aug 26 19:15:53.339: IP: s=192.168.0.17 (BVI1), d=8.8.4.4, len 60, dispose ip.noroute
.Aug 26 19:15:53.343: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:15:53.343: CEF-Debug: Packet from 192.168.0.17 (BV1) to 193.36.79.100
.Aug 26 19:15:53.343: CFT L4: Error: fid[2091] retrans seg in state opening
.Aug 26 19:15:53.343: No route, drop
.Aug 26 19:15:53.343: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:15:53.563: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:15:53.563: CEF-Debug: Packet from 192.168.0.91 (BV1) to 8.8.8.8
.Aug 26 19:15:53.563: NAT: API parameters passed: src_addr:192.168.0.91, src_port:0 dest_addr:8.8.8.8, dest_port:0, proto:17 if_input:BVI1 pak:149AE218 get_translated:1
.Aug 26 19:15:53.563: CFT Engine: NAT failed to find a translation
.Aug 26 19:15:53.563: CFT L4: Error: fid[4027] invalid state in state bi-established
.Aug 26 19:15:53.563: CFT Ager: set flow 4027 aging to 360000 ms
.Aug 26 19:15:53.563: No route, drop
.Aug 26 19:15:53.563: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:15:54.455: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:15:54.455: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:15:54.527: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:15:54.527: CEF-Debug: Packet from 192.168.0.50 (BV1) to 8.8.4.4
.Aug 26 19:15:54.527: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:8.8.4.4, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:15:54.527: CFT Engine: NAT failed to find a translation
.Aug 26 19:15:55.327: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:15:55.327: Duplex Full
.Aug 26 19:15:55.327: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:15:55.327: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:15:55.327: ethsw_ilp: Sending ILP Recovery Req to Service Module GigabitEthernet2/0
.Aug 26 19:15:55.831: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:15:55.831: CEF-Debug: Packet from 192.168.0.92 (BV1) to 8.8.8.8
.Aug 26 19:15:55.831: NAT: API parameters passed: src_addr:192.168.0.92, src_port:0 dest_addr:8.8.8.8, dest_port:0, proto:17 if_input:BVI1 pak:149AE218 get_translated:1
.Aug 26 19:15:55.831: CFT Engine: NAT failed to find a translation
.Aug 26 19:15:55.831: CFT L4: Error: fid[2806] invalid state in state bi-established
.Aug 26 19:15:55.831: CFT Ager: set flow 2806 aging to 360000 ms
.Aug 26 19:15:55.831: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:15:55.831: TCPADJMSS: punt_feature
.Aug 26 19:15:55.831: IRB-CEF: LE vector failed on BVI1, enqueued to IP queue
.Aug 26 19:15:55.831: IPpacketQ deq s=192.168.0.92 (BVI1), d=8.8.8.8, flags=0xA80, tos=0x0, frag_offset=0
.Aug 26 19:15:55.831: UDP src=55679, dst=53
.Aug 26 19:15:55.831: IP: s=192.168.0.92 (BVI1), d=8.8.8.8
.Aug 26 19:15:56.328: ethsw_ilp: Sending ILP Recovery Req to Service Module GigabitEthernet2/0
.Aug 26 19:15:56.860: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:15:56.860: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2 Control Plane:marking in pak exception [non cef linktype ARP]
.Aug 26 19:15:56.860: IP ARP: rcvd req src 192.168.0.41 000c.2972.bceb, dst 192.168.0.35 BVI1
.Aug 26 19:15:56.860: ARP DB: ARP entry of key 192.168.0.41 not found
.Aug 26 19:15:57.328: ethsw_ilp: Sending ILP Recovery Req to Service Module GigabitEthernet2/0
.Aug 26 19:15:57.704: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:15:57.704: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:15:57.704: IPpacketQ deq s=192.168.0.17 (BVI1), d=239.255.255.250, flags=0xA00, tos=0x0, frag_offset=0
.Aug 26 19:15:57.704: UDP src=48981, dst=1900
.Aug 26 19:15:57.704: IP: s=192.168.0.17 (BVI1), d=239.255.255.250, len 153, input feature, debug packet(1), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:15:57.704: IP: s=192.168.0.17 (BVI1), d=239.255.255.250, len 153, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:15:57.704: IP: s=192.168.0.17 (BVI1), d=239.255.255.250, len 153, input feature, Stateful Inspection(8), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:15:57.704: IP: s=192.168.0.17 (BVI1), d=239.255.255.250, len 153, input feature, Virtual Fragment Reassembly(39), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:15:58.328: ethsw_ilp: Sending ILP Recovery Req to Service Module GigabitEthernet2/0
.Aug 26 19:15:58.540: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:15:58.540: CEF-Debug: Packet from 192.168.0.17 (BV1) to 193.36.79.100
.Aug 26 19:15:58.540: NAT: API parameters passed: src_addr:192.168.0.17, src_port:0 dest_addr:193.36.79.100, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:15:58.540: CFT Engine: NAT failed to find a translation
.Aug 26 19:15:58.540: CFT L4: Error: fid[3668] invalid state in state bi-established
.Aug 26 19:15:59.436: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:15:59.444: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:15:59.444: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:15:59.540: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:15:59.548: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:15:59.548: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:15:59.892: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:15:59.892: CEF-Debug: Packet from 192.168.0.82 (BV1) to 193.36.79.101
.Aug 26 19:15:59.892: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:15:59.892: TCPADJMSS: punt_feature
.Aug 26 19:15:59.892: IRB-CEF: LE vector failed on BVI1, enqueued to IP queue
.Aug 26 19:15:59.892: IPpacketQ deq s=192.168.0.82 (BVI1), d=193.36.79.101, flags=0xA80, tos=0x0, frag_offset=0
.Aug 26 19:16:00.328: ethsw_ilp: Sending ILP Recovery Req to Service Module GigabitEthernet2/0
.Aug 26 19:16:00.448: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:00.448: CEF-Debug: Packet from 192.168.0.17 (BV1) to 193.36.79.100
.Aug 26 19:16:00.448: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:16:00.448: TCPADJMSS: punt_feature
.Aug 26 19:16:00.448: IRB-CEF: LE vector failed on BVI1, enqueued to IP queue
.Aug 26 19:16:00.448: NAT: API parameters passed: src_addr:192.168.0.17, src_port:0 dest_addr:193.36.79.100, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:16:00.448: CFT Engine: NAT failed to find a translation
.Aug 26 19:16:00.448: CFT L4: Error: fid[871] invalid state in state bi-established
.Aug 26 19:16:00.448: CFT Ager: set flow 871 aging to 360000 ms
.Aug 26 19:16:00.448: No route, drop
.Aug 26 19:16:00.448: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:16:01.488: IP: s=192.168.0.17 (BVI1), d=239.255.255.250, len 153, input feature, MCI Check(109), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:16:01.488: IP(0): s=192.168.0.17 (BVI1) d=239.255.255.250 id=3785, ttl=1, prot=17, len=181(153), inconsistent tableid
.Aug 26 19:16:01.640: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:01.640: CEF-Debug: Packet from 192.168.0.50 (BV1) to 8.8.8.8
.Aug 26 19:16:01.640: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:8.8.8.8, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:16:02.328: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:16:02.328: Duplex Full
.Aug 26 19:16:02.328: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:16:02.328: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:16:02.328: ethsw_ilp: Sending ILP Recovery Req to Service Module GigabitEthernet2/0
.Aug 26 19:16:02.636:
.Aug 26 19:16:02.636: Rudpv1 Sent: Pkts 0, Data Bytes 0, Data Pkts 0
.Aug 26 19:16:02.636: Rudpv1 Rcvd: Pkts 0, Data Bytes 0, Data Pkts 0
.Aug 26 19:16:02.636: Rudpv1 Discarded: 0, Retransmitted 0
.Aug 26 19:16:02.820: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:16:02.820: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:02.820: IPpacketQ deq s=192.168.0.17 (BVI1), d=239.255.255.250, flags=0xA00, tos=0x0, frag_offset=0
.Aug 26 19:16:02.820: UDP src=48981, dst=1900
.Aug 26 19:16:02.820: IP: s=192.168.0.17 (BVI1), d=239.255.255.250, len 153, input feature, debug packet(1), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:16:03.612: IP: s=192.168.0.100 (local), d=192.168.0.91 (BVI1), len 56, output feature, NAT ALG proxy(63), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:16:03.612: IP: s=192.168.0.100 (local), d=192.168.0.91 (BVI1), len 56, output feature, debug packet(101), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:16:03.616: ARP DB: ARP entry of key 192.168.0.91 found
.Aug 26 19:16:03.616: IP: s=192.168.0.100 (local), d=192.168.0.91 (BVI1), len 56, sending full packet
.Aug 26 19:16:03.616: IP: s=192.168.0.91 (BVI1), d=8.8.8.8, len 50, dispose ip.noroute
.Aug 26 19:16:04.488: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:04.520: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:16:04.524: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:16:04.540: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:04.544: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:16:04.640: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:16:04.648: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:04.648: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:16:04.908: STP: opt: Bridge group 1: get ports: no free chunk available
.Aug 26 19:16:04.908: STP: opt: Bridge group 10: get ports: no free chunk available
.Aug 26 19:16:04.908: STP: opt: Bridge group 20: get ports: no free chunk available
.Aug 26 19:16:05.444: CEF-Debug: Packet from 192.168.0.17 (BV1) to 193.36.79.100
.Aug 26 19:16:05.444: NAT: API parameters passed: src_addr:192.168.0.17, src_port:0 dest_addr:193.36.79.100, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:16:05.444: CFT Engine: NAT failed to find a translation
.Aug 26 19:16:05.444: CFT L4: Error: fid[153] invalid state in state bi-established
.Aug 26 19:16:05.444: CFT Ager: set flow 153 aging to 360000 ms
.Aug 26 19:16:05.444: No route, drop
.Aug 26 19:16:05.444: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:16:05.472: //-1/xxxxxxxxxxxx/CRM/crm_send_periodic_update:
.Aug 26 19:16:05.652: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:05.652: CEF-Debug: Packet from 192.168.0.50 (BV1) to 8.8.4.4
.Aug 26 19:16:05.652: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:8.8.4.4, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:16:05.652: CFT Engine: NAT failed to find a translation
.Aug 26 19:16:05.652: CFT L4: Error: fid[2548] invalid state in state bi-established
.Aug 26 19:16:05.652: CFT Ager: set flow 2548 aging to 360000 ms
.Aug 26 19:16:05.652: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:16:06.636: IP: s=192.168.0.100 (local), d=192.168.0.50 (BVI1), len 56, output feature, NAT ALG proxy(63), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:16:06.636: IP: s=192.168.0.100 (local), d=192.168.0.50 (BVI1), len 56, output feature, debug packet(101), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:16:06.636: ARP DB: ARP entry of key 192.168.0.50 found
.Aug 26 19:16:06.636: IP: s=192.168.0.100 (local), d=192.168.0.50 (BVI1), len 56, sending full packet
.Aug 26 19:16:06.636: IP: s=192.168.0.50 (BVI1), d=8.8.4.4, len 76, dispose ip.noroute
.Aug 26 19:16:07.329: ethsw_ilp: Sending ILP Recovery Req to Service Module GigabitEthernet2/0
.Aug 26 19:16:07.645: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:16:07.645: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:07.645: IPpacketQ deq s=192.168.0.17 (BVI1), d=239.255.255.250, flags=0xA00, tos=0x0, frag_offset=0
.Aug 26 19:16:07.645: UDP src=48981, dst=1900
.Aug 26 19:16:07.645: IP: s=192.168.0.17 (BVI1), d=239.255.255.250, len 153, input feature, debug packet(1), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:16:07.645: IP: s=192.168.0.17 (BVI1), d=239.255.255.250, len 153, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:16:07.645: IP: s=192.168.0.17 (BVI1), d=239.255.255.250, len 153, input feature, Stateful Inspection(8), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:16:07.645: IP: s=192.168.0.17 (BVI1), d=239.255.255.250, len 153, input feature, Virtual Fragment Reassembly(39), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:16:08.625: CFT Engine: NAT failed to find a translation
.Aug 26 19:16:08.625: CFT L4: Error: fid[2344] invalid state in state bi-established
.Aug 26 19:16:08.625: CFT Ager: set flow 2344 aging to 360000 ms
.Aug 26 19:16:08.625: No route, drop
.Aug 26 19:16:08.625: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:16:08.641: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:08.641: CEF-Debug: Packet from 192.168.0.50 (BV1) to 193.36.79.101
.Aug 26 19:16:08.641: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:193.36.79.101, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C
.Aug 26 19:16:09.581: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:09.613: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:16:09.617: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:16:09.621: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:09.621: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:16:09.733: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:16:09.737: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:09.737: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:16:09.765: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:09.765: CEF-Debug: Packet from 192.168.0.47 (BV1) to 8.8.4.4
.Aug 26 19:16:09.765: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:16:10.629: NAT: API parameters passed: src_addr:192.168.0.17, src_port:0 dest_addr:8.8.8.8, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:16:10.629: CFT Engine: NAT failed to find a translation
.Aug 26 19:16:10.629: CFT L4: Error: fid[1748] invalid state in state bi-established
.Aug 26 19:16:10.629: CFT Ager: set flow 1748 aging to 360000 ms
.Aug 26 19:16:10.629: No route, drop
.Aug 26 19:16:10.629: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:16:10.717: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2 len=181(153), inconsistent tableid
.Aug 26 19:16:11.733: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:16:11.749: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:16:11.749: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernket VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:58.045: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:58.397: No route, drop
.Aug 26 19:16:58.397: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:16:58.621: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:58.625: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:16:58.725: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:16:58.725: CEF-Debug: Packet from 192.168.0.92 (BV1) to 8.8.8.8
.Aug 26 19:16:58.725: NAT: API parameters passed: src_addr:192.168.0.92, src_port:0 dest_addr:8.8.8.8, dest_port:0, proto:17 if_input:BVI1 get_translated:1
.Aug 26 19:16:59.521: CFT Engine: NAT failed to find a translation
.Aug 26 19:16:59.521: CFT L4: Error: fid[1501] invalid state in state bi-established
.Aug 26 19:16:59.521: CFT Ager: set flow 1501 aging to 360000 ms
.Aug 26 19:16:59.521: No route, drop
.Aug 26 19:16:59.521: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:16:59.709: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:16:59.709: CEF-Debug: Packet from 192.168.0.17 (BV1) to 8.8.4.4
.Aug 26 19:16:59.709: NAT: API parameters passed: src_addr:192.168.0.17, src_port:0 dest_addr:8.8.4.4, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:16:59.709: CFT Engine: NAT failed to find a translation
.Aug 26 19:16:59.709: CFT L4: Error: fid[1370] invalid state in state bi-established
.Aug 26 19:16:59.709: CFT Ager: set flow 1370 aging to 360000 ms
.Aug 26 19:16:59.709: No route, drop
.Aug 26 19:16:59.709: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:00.661: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:00.661: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:00.709: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:00.709: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2 Control Plane:marking in pak exception [non cef linktype ARP]
.Aug 26 19:17:00.709: IP ARP: rcvd req src 192.168.0.41 000c.2972.bceb, dst 192.168.0.35 BVI1
.Aug 26 19:17:01.542: IP: s=192.168.0.100 (local), d=192.168.0.17 (BVI1), len 56, output feature, debug packet(101), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:01.542: ARP DB: ARP entry of key 192.168.0.17 found
.Aug 26 19:17:01.542: IP: s=192.168.0.100 (local), d=192.168.0.17 (BVI1), len 56, sending full packet
.Aug 26 19:17:01.542: IP: s=192.168.0.17 (BVI1), d=193.36.79.101, len 75, dispose ip.norouteCFT deleting flow 131 <192.168.0.91:43582,8.8.8.8:53,17,0,0>1
.Aug 26 19:17:01.606: CFT Ager: aged out flow 131CFT deleting flow 1421 <192.168.0.42:41044,91.203.145.114:443,6,0,0>1
.Aug 26 19:17:01.606: CFT Ager: aged out flow 1421
.Aug 26 19:17:01.730: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:01.730: CEF-Debug: Packet from 192.168.0.17 (BV1) to 193.36.79.101
.Aug 26 19:17:01.730: NAT: API parameters passed: src_addr:192.168.0.17, src_port:0 dest_addr:193.36.79.101, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:01.730: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:01.730: CFT L4: Error: fid[1904] invalid state in state bi-established
.Aug 26 19:17:01.730: CFT Ager: set flow 1904 aging to 360000 ms
.Aug 26 19:17:01.730: No route, drop
.Aug 26 19:17:02.334: Duplex Full
.Aug 26 19:17:02.334: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:17:02.334: ATM0/0/0: atm_if_get_restart_timer 300CFT deleting flow 1831 <192.168.0.17:42589,31.13.90.36:443,6,0,0>1
.Aug 26 19:17:02.630: CFT Ager: aged out flow 1831
.Aug 26 19:17:02.702:
.Aug 26 19:17:02.702: Rudpv1 Sent: Pkts 0, Data Bytes 0, Data Pkts 0
.Aug 26 19:17:02.702: Rudpv1 Rcvd: Pkts 0, Data Bytes 0, Data Pkts 0
.Aug 26 19:17:02.702: Rudpv1 Discarded: 0, Retransmitted 0
.Aug 26 19:17:02.874: Ingress pack
.Aug 26 19:17:03.730: CFT Ager: set flow 1669 aging to 360000 ms
.Aug 26 19:17:03.730: No route, drop
.Aug 26 19:17:03.730: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:04.010: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1 get_translated:1
.Aug 26 19:17:04.474: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:04.474: CFT L4: Error: fid[1502] invalid state in state bi-established
.Aug 26 19:17:04.474: CFT Ager: set flow 1502 aging to 360000 ms
.Aug 26 19:17:04.474: No route, drop
.Aug 26 19:17:04.474: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:04.946: STP: opt: Bridge group 1: get ports: no free chunk available
.Aug 26 19:17:04.946: STP: opt: Bridge group 10: get ports: no free chunk available
.Aug 26 19:17:04.946: STP: opt: Bridge group 20: get ports: no free chunk available
.Aug 26 19:17:04.946: STP: opt: Bridge group 30: get ports: no free chunk available, NAT ALG proxy(63), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:05.698: IP: s=192.168.0.100 (local), d=192.168.0.1 (BVI1), len 56, output feature, debug packet(101), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:05.698: ARP DB: ARP entry of key 192.168.0.1 found
.Aug 26 19:17:05.698: IP: s=192.168.0.100 (local), d=192.168.0.1 (BVI1), len 56, sending full packet
.Aug 26 19:17:05.698: IP: s=192.168.0.1 (BVI1), d=185.16.207.50, len 114, dispose ip.noroute
.Aug 26 19:17:05.746: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:05.750: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:05.754: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:05.758: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:05.758: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:05.758: IPpacketQ deq s=192.168.0.42 (BVI1), d=224.0.0.251, flags=0xA00, tos=0x0, frag_offset=0
.Aug 26 19:17:05.758: UDP src=5353, dst=5353, len 60, dispose ip.noroute
.Aug 26 19:17:06.718: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:06.718: CEF-Debug: Packet from 192.168.0.17 (BV1) to 193.36.79.100
.Aug 26 19:17:06.718: NAT: API parameters passed: src_addr:192.168.0.17, src_port:0 dest_addr:193.36.79.100, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:06.718: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:06.718: CFT L4: Error: fid[2979] invalid state in state bi-established
.Aug 26 19:17:06.718: CFT Ager: set flow 2979 aging to 360000 ms
.Aug 26 19:17:06.718: No route, drop
.Aug 26 19:17:07.334: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:17:07.334: Duplex Full
.Aug 26 19:17:07.334: mrvl_get_port_status, spec_reg:0xFFFF
.Aug 26 19:17:07.334: mrvl_mode_read, mode:0x18018F0
.Aug 26 19:17:07.334: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:17:07.334: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:17:07.710: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:07.710: CEF-Debug: Packet from 192.168.0.50 (BV1) to 8.8.8.8
.Aug 26 19:17:07.710: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:8.8.8.8, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:07.710: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:07.710: CFT Ager: set flow 3400 aging to 360000 ms
.Aug 26 19:17:07.710: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:17:07.710: TCPADJMSS: punt_feature
.Aug 26 19:17:08.634: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:08.746: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:08.746: CEF-Debug: Packet from 192.168.0.92 (BV1) to 193.36.79.100
.Aug 26 19:17:08.746: NAT: API parameters passed: src_addr:192.168.0.92, src_port:0 dest_addr:193.36.79.100, dest_port:0, proto:17 if_input:BVI1 pak:149AE218 get_translated:1
.Aug 26 19:17:08.746: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:08.746: CFT L4: Error: fid[2533] invalid state in state bi-established
.Aug 26 19:17:08.746: CFT Ager: set flow 2533 aging to 360000 ms
.Aug 26 19:17:08.746: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:17:08.746: TCPADJMSS: punt_feature
.Aug 26 19:17:08.746: IRB-CEF: LE vector failed on BVI1, enqueued to IP queue
.Aug 26 19:17:08.746: IPpacketQ deq s=192.168.0.92 (BVI1), d=193.36.79.100, flags=0xA80, tos=0x0, frag_offset=0
.Aug 26 19:17:08.746: UDP src=53836, dst=53
.Aug 26 19:17:08.746: IP: s=192.168.0.92 (BVI1), d=193.36.79.100, len 50, input feature, debug packet(1), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:08.746: CFT Engine: fid[2533]: Updated responder keys for NAT
.Aug 26 19:17:09.534: CEF-Debug: Packet from 192.168.0.17 (BV1) to 8.8.8.8
.Aug 26 19:17:09.534: No route, drop
.Aug 26 19:17:09.534: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:10.086: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:10.086: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2 Control Plane:marking in pak exception [non cef linktype ARP]
.Aug 26 19:17:10.086: IP ARP: rcvd req src 192.168.0.90 740a.bc03.379f, dst 192.168.0.100 BVI1
.Aug 26 19:17:10.086: ARP DB: ARP entry of key 192.168.0.90 found
.Aug 26 19:17:10.698: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:10.706: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:10.706: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:10.726: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:10.846: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:10.850: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:10.854: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:10.934: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:10.934: CEF-Debug: Packet from 192.168.0.50 (BV1) to 8.8.4.4
.Aug 26 19:17:10.934: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:8.8.4.4, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:10.934: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:11.334: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:17:11.334: Duplex Full
.Aug 26 19:17:11.334: mrvl_get_port_status, spec_reg:0xFFFF
.Aug 26 19:17:11.334: mrvl_mode_read, mode:0x18018F0
.Aug 26 19:17:11.334: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:17:11.334: ATM0/0/0: atm_if_get_restart_timer 300CFT deleting flow 1217
.Aug 26 19:17:12.703: Rudpv1 Rcvd: Pkts 0, Data Bytes 0, Data Pkts 0
.Aug 26 19:17:12.703: Rudpv1 Discarded: 0, Retransmitted 0
.Aug 26 19:17:12.715: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:12.715: CEF-Debug: Packet from 192.168.0.50 (BV1) to 8.8.4.4
.Aug 26 19:17:12.715: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:8.8.4.4, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:12.719: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:12.719: CFT Ager: set flow 644 aging to 360000 ms
.Aug 26 19:17:12.719: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:17:12.719: TCPADJMSS: punt_feature
.Aug 26 19:17:12.719: IRB-CEF: LE vector failed on BVI1, enqueued to IP queue
.Aug 26 19:17:12.719: IPpacketQ deq s=192.168.0.50 (BVI1), d=8.8.4.4, flags=0xA80, tos=0x0, frag_offset=0
.Aug 26 19:17:12.719: UDP src=54252, dst=53
.Aug 26 19:17:12.719: IP: s=192.168.0.50 (BVI1), d=8.8.4.4, len 76, input feature, debug packet(1), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:12.719: CFT Engine: fid[644]: Updated responder keys for NAT
.Aug 26 19:17:13.615: FIBbg: Timer 'FIB checkers: IPv4 scan-ios-rib scanner' expired, calling 0x05F80DB8, context 0x00010004)
.Aug 26 19:17:13.615: FIBchck: [scan-ios-rib:v4] Invoking timer callback
.Aug 26 19:17:13.615: FIBbg: Restarting timer 'FIB checkers: IPv4 scan-ios-rib scanner' with delay 60000
.Aug 26 19:17:13.615: FIBbg: Timer 'FIB checkers: IPv4 scan-rib-ios scanner' expired, calling 0x05F80DB8, context 0x00010003)
.Aug 26 19:17:13.615: FIBchck: [scan-rib-ios:v4] Invoking timer callback
.Aug 26 19:17:13.615: FIBbg: Restarting timer 'FIB checkers: IPv4 scan-rib-ios scanner' with delay 60000
.Aug 26 19:17:14.535: No route, drop
.Aug 26 19:17:14.535: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:14.719: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:14.719: CEF-Debug: Packet from 192.168.0.50 (BV1) to 193.36.79.101
.Aug 26 19:17:14.719: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:193.36.79.101, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:14.719: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:14.719: CFT L4: Error: fid[2407] invalid state in state bi-established
.Aug 26 19:17:14.719: CFT Ager: set flow 2407 aging to 360000 ms
.Aug 26 19:17:14.719: No route, drop
.Aug 26 19:17:14.719: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:14.947: STP: opt: Bridge group 1: get ports: no free chunk available
.Aug 26 19:17:14.947: STP: opt: Bridge group 10: get ports: no free chunk available
.Aug 26 19:17:14.947: STP: opt: Bridge group 20: get ports: no free chunk available
.Aug 26 19:17:14.947: STP: opt: Bridge group 30: get ports: no free chunk available
.Aug 26 19:17:14.947: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:15.631: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:15.635: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:15.671: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:15.771: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:16.551: IP: s=192.168.0.100 (local), d=192.168.0.17 (BVI1), len 56, output feature, debug packet(101), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:16.551: ARP DB: ARP entry of key 192.168.0.17 found
.Aug 26 19:17:16.551: IP: s=192.168.0.100 (local), d=192.168.0.17 (BVI1), len 56, sending full packet
.Aug 26 19:17:16.551: IP: s=192.168.0.17 (BVI1), d=193.36.79.101, len 68, dispose ip.noroute
.Aug 26 19:17:16.731: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:16.731: CEF-Debug: Packet from 192.168.0.17 (BV1) to 8.8.8.8
.Aug 26 19:17:16.731: No route, drop
.Aug 26 19:17:16.731: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:16.943: 339: Bulkstat: bs_resource_usage_check: 240: 0: Resource usage percentage for local[0] is 30.
.Aug 26 19:17:16.943: 339: Bulkstat: bs_resource_usage_check_and_handle: 325: 0: Memory resource check is within limits.
.Aug 26 19:17:17.335: mrvl_get_port_status, spec_reg:0xFFFF
.Aug 26 19:17:17.335: mrvl_mode_read, mode:0x18018F0
.Aug 26 19:17:17.335: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:17:17.335: Duplex Full
.Aug 26 19:17:17.335: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:17:17.335: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:17:17.935: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:17.935: CEF-Debug: Packet from 192.168.0.50 (BV1) to 8.8.4.4
.Aug 26 19:17:17.935: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:8.8.4.4, dest_port:0, proto:17 if_input:BVI1
.Aug 26 19:17:18.387: CFT Ager: set flow 3289 aging to 360000 ms
.Aug 26 19:17:18.387: No route, drop
.Aug 26 19:17:18.387: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:18.635: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:18.635: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:18.751: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1 Control Plane:marking in pak exception [non cef linktype ARP]
.Aug 26 19:17:18.751: IP ARP: rcvd req src 192.168.0.91 7cdd.9071.0c88, dst 192.168.0.100 BVI1
.Aug 26 19:17:18.751: ARP DB: ARP entry of key 192.168.0.91 found
.Aug 26 19:17:18.751: ARP TABLE: modifying entry 192.168.0.91/7cdd.9071.0c88 on BV1 for Dynamic
.Aug 26 19:17:18.751: ARP TMR: entry 192.168.0.91 on BVI1 stopped from outter wheel
.Aug 26 19:17:18.751: ARP TMR: start timer of 14280000 msec on 192.168.0.91 on BVI1, with jitter (total delay of 15175745 msec)
.Aug 26 19:17:18.751: ARP TMR: entry 192.168.0.91 on BVI1 with delay 15175745 msec plus 1106944 msec of inner wheel cnt inserted to outer wheel, bin 176 (current bin 167)
.Aug 26 19:17:19.335: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:17:19.335: Duplex Full
.Aug 26 19:17:19.335: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:17:19.335: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:17:19.491: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:19.491: CEF-Debug: Packet from 192.168.0.17 (BV1) to 8.8.4.4
.Aug 26 19:17:19.491: No route, drop
.Aug 26 19:17:19.491: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:19.727: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:20.427: CFT L4: Error: fid[549] invalid state in state bi-established
.Aug 26 19:17:20.427: CFT Ager: set flow 549 aging to 360000 ms
.Aug 26 19:17:20.427: No route, drop
.Aug 26 19:17:20.427: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:20.479: //-1/xxxxxxxxxxxx/CRM/crm_send_periodic_update:
.Aug 26 19:17:20.567: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:20.567: CEF-Debug: Packet from 192.168.0.1 (BV1) to 185.16.207.50
.Aug 26 19:17:20.567: No route, drop
.Aug 26 19:17:20.567: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:20.715: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:20.715: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:21.543: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:21.547: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:21.547: CEF-Debug: Packet from 192.168.0.17 (BV1) to 8.8.4.4
.Aug 26 19:17:21.547: No route, drop
.Aug 26 19:17:21.547: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:21.743: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:21.743: CEF-Debug: Packet from 192.168.0.17 (BV1) to 8.8.4.4
.Aug 26 19:17:21.743: No route, drop
.Aug 26 19:17:21.743: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:22.335: mrvl_mode_read, mode:0x18018F0
.Aug 26 19:17:22.335: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:17:22.335: Duplex Full
.Aug 26 19:17:22.335: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:17:22.335: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:17:22.703:
.Aug 26 19:17:22.703: Rudpv1 Sent: Pkts 0, Data Bytes 0, Data Pkts 0
.Aug 26 19:17:22.703: Rudpv1 Rcvd: Pkts 0, Data Bytes 0, Data Pkts 0
.Aug 26 19:17:22.703: Rudpv1 Discarded: 0, Retransmitted 0
.Aug 26 19:17:22.939: FIBbg: Timer 'fibidb queue' expired, calling 0x0608B600, context 0x00000000), NAT ALG proxy(63), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:23.568: IP: s=192.168.0.100 (local), d=192.168.0.17 (BVI1), len 56, output feature, debug packet(101), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:23.568: ARP DB: ARP entry of key 192.168.0.17 found
.Aug 26 19:17:23.568: IP: s=192.168.0.100 (local), d=192.168.0.17 (BVI1), len 56, sending full packet
.Aug 26 19:17:23.568: IP: s=192.168.0.17 (BVI1), d=193.36.79.101, len 75, dispose ip.noroute
.Aug 26 19:17:23.748: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:23.748: CEF-Debug: Packet from 192.168.0.17 (BV1) to 193.36.79.101
.Aug 26 19:17:23.748: No route, drop
.Aug 26 19:17:23.748: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:23.776: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:24.424: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:24.948: STP: opt: Bridge group 1: get ports: no free chunk available
.Aug 26 19:17:24.948: STP: opt: Bridge group 10: get ports: no free chunk available
.Aug 26 19:17:24.948: STP: opt: Bridge group 20: get ports: no free chunk available
.Aug 26 19:17:24.948: STP: opt: Bridge group 30: get ports: no free chunk available
.Aug 26 19:17:24.952: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:25.064: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:25.336: mrvl_get_port_status, spec_reg:0xFFFF
.Aug 26 19:17:25.336: mrvl_mode_read, mode:0x18018F0
.Aug 26 19:17:25.336: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:17:25.336: Duplex Full
.Aug 26 19:17:25.336: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:17:25.336: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:17:25.748: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:25.748: CEF-Debug: Packet from 192.168.0.1 (BV1) to 185.16.207.50
.Aug 26 19:17:25.748: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:17:25.748: TCPADJMSS: punt_feature
.Aug 26 19:17:25.748: IRB-CEF: LE vector failed on BVI1, enqueued to IP queue
.Aug 26 19:17:25.748: IPpacketQ deq s=192.168.0.1 (BVI1), d=185.16.207.50, flags=0xA80, tos=0x0, frag_offset=0
.Aug 26 19:17:25.748: UDP src=52377, dst=1194
.Aug 26 19:17:25.748: IP: s=192.168.0.1 (BVI1), d=185.16.207.50, len 114, input feature, debug packet(1), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:26.384: CFT Ager: set flow 1948 aging to 360000 ms
.Aug 26 19:17:26.384: No route, drop
.Aug 26 19:17:26.384: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:26.504: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:26.504: CEF-Debug: Packet from 192.168.0.17 (BV1) to 193.36.79.100
.Aug 26 19:17:26.504: No route, drop
.Aug 26 19:17:26.504: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:26.944: 339: Bulkstat: bs_resource_usage_check: 240: 0: Resource usage percentage for local[0] is 30.
.Aug 26 19:17:27.336: mrvl_mode_read, mode:0x18018F0
.Aug 26 19:17:27.336: mrvl_get_port_status, fiber spec_reg:0xFFFF
.Aug 26 19:17:27.336: Duplex Full
.Aug 26 19:17:27.336: mrvl_get_port_status, spec_reg:0xFFFF
.Aug 26 19:17:27.336: MII READ PHY 3 Read reg = 0 val = FFFF
.Aug 26 19:17:27.336: ATM0/0/0: atm_if_get_restart_timer 300
.Aug 26 19:17:27.948: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:27.948: CEF-Debug: Packet from 192.168.0.50 (BV1) to 8.8.8.8
.Aug 26 19:17:27.948: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:8.8.8.8, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:27.948: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:27.948: CFT L4: Error: fid[3377] invalid state in state bi-established
.Aug 26 19:17:27.948: CFT Ager: set flow 3377 aging to 360000 ms
.Aug 26 19:17:27.948: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:17:27.948: TCPADJMSS: punt_feature
.Aug 26 19:17:27.948: IRB-CEF: LE vector failed on BVI1, enqueued to IP queue
.Aug 26 19:17:28.576: IP: s=192.168.0.100 (local), d=192.168.0.17 (BVI1), len 56, output feature, debug packet(101), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:28.576: ARP DB: ARP entry of key 192.168.0.17 found
.Aug 26 19:17:28.576: IP: s=192.168.0.100 (local), d=192.168.0.17 (BVI1), len 56, sending full packet
.Aug 26 19:17:28.576: IP: s=192.168.0.17 (BVI1), d=193.36.79.100, len 75, dispose ip.noroute
.Aug 26 19:17:28.632: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:28.636: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:29.536: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:29.536: No route, drop
.Aug 26 19:17:29.536: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:30.124: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:30.124: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2 Control Plane:marking in pak exception [non cef linktype ARP]
.Aug 26 19:17:30.128: IP ARP: rcvd req src 192.168.0.90 740a.bc03.379f, dst 192.168.0.100 BVI1
.Aug 26 19:17:30.128: ARP DB: ARP entry of key 192.168.0.90 found
.Aug 26 19:17:30.128: ARP TABLE: modifying entry 192.168.0.90/740a.bc03.379f on BV1 for Dynamic
.Aug 26 19:17:30.128: ARP TMR: entry 192.168.0.90 on BVI1 stopped from outter wheel
.Aug 26 19:17:30.128: ARP TMR: start timer of 14280000 msec on 192.168.0.90 on BVI1, with jitter (total delay of 14720387 msec)
.Aug 26 19:17:30.128: ARP TMR: entry 192.168.0.90 on BVI1 with delay 14720387 msec plus 1118208 msec of inner wheel cnt inserted to outer wheel, bin 175 (current bin 167)
.Aug 26 19:17:30.128: ARP DB: ARP entry of key 192.168.0.100 found
.Aug 26 19:17:30.128: VRRSv4 Callback - Address to MAC: 192.168.0.100 is not a VRRS address
.Aug 26 19:17:30.368: No route, drop
.Aug 26 19:17:30.368: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:30.800: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:30.800: CEF-Debug: Packet from 192.168.0.1 (BV1) to 185.16.207.50
.Aug 26 19:17:30.800: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:17:30.800: TCPADJMSS: punt_feature
.Aug 26 19:17:30.800: IRB-CEF: LE vector failed on BVI1, enqueued to IP queue
.Aug 26 19:17:30.800: IPpacketQ deq s=192.168.0.1 (BVI1), d=185.16.207.50, flags=0xA80, tos=0x0, frag_offset=0
.Aug 26 19:17:30.800: UDP src=58053, dst=1194
.Aug 26 19:17:31.568: CEF-Debug: Packet from 192.168.0.17 (BV1) to 8.8.8.8
.Aug 26 19:17:31.568: NAT: API parameters passed: src_addr:192.168.0.17, src_port:0 dest_addr:8.8.8.8, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:31.568: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:31.568: CFT L4: Error: fid[3179] invalid state in state bi-established
.Aug 26 19:17:31.568: CFT Ager: set flow 3179 aging to 360000 ms
.Aug 26 19:17:31.568: No route, drop
.Aug 26 19:17:31.568: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:32.128: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:32.128: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2 Control Plane:marking in pak exception [non cef linktype ARP]
.Aug 26 19:17:32.128: IP ARP: rcvd req src 192.168.0.90 740a.bc03.379f, dst 192.168.0.100 BVI1
.Aug 26 19:17:32.128: ARP DB: ARP entry of key 192.168.0.90 found
.Aug 26 19:17:32.128: ARP TABLE: modifying entry 192.168.0.90/740a.bc03.379f on BV1 for Dynamic
.Aug 26 19:17:32.128: ARP TMR: entry 192.168.0.90 on BVI1 stopped from outter wheel
.Aug 26 19:17:32.640: IP: s=192.168.0.41 (BVI1), d=224.0.0.251, len 183, unroutable
.Aug 26 19:17:32.640: IP: s=192.168.0.41 (BVI1), d=224.0.0.251, len 183, dispose ip.baddest
.Aug 26 19:17:32.732:
.Aug 26 19:17:32.732: Rudpv1 Sent: Pkts 0, Data Bytes 0, Data Pkts 0
.Aug 26 19:17:32.732: Rudpv1 Rcvd: Pkts 0, Data Bytes 0, Data Pkts 0
.Aug 26 19:17:32.732: Rudpv1 Discarded: 0, Retransmitted 0
.Aug 26 19:17:32.948: STP: opt: Bridge group 1: get ports: no free chunk available
.Aug 26 19:17:32.948: STP: opt: Bridge group 10: get ports: no free chunk available
.Aug 26 19:17:32.948: STP: opt: Bridge group 20: get ports: no free chunk available
.Aug 26 19:17:33.733: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:33.821: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:33.821: CEF-Debug: Packet from 192.168.0.91 (BV1) to 8.8.8.8
.Aug 26 19:17:33.821: NAT: API parameters passed: src_addr:192.168.0.91, src_port:0 dest_addr:8.8.8.8, dest_port:0, proto:17 if_input:BVI1 pak:149AE218 get_translated:1
.Aug 26 19:17:33.821: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:33.821: CFT L4: Error: fid[3516] invalid state in state bi-established
.Aug 26 19:17:33.821: CFT Ager: set flow 3516 aging to 360000 ms
.Aug 26 19:17:33.821: No route, drop
.Aug 26 19:17:33.821: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:33.821: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:33.821: CEF-Debug: Packet from 192.168.0.1 (BV1) to 185.16.207.50
.Aug 26 19:17:33.821: NAT: API parameters passed: src_addr:192.168.0.1, src_port:0 dest_addr:185.16.207.50, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:33.821: CFT Ager: set flow 714 aging to 360000 ms
.Aug 26 19:17:33.821: No route, drop, debug packet(101), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:34.709: ARP DB: ARP entry of key 192.168.0.50 found
.Aug 26 19:17:34.709: IP: s=192.168.0.100 (local), d=192.168.0.50 (BVI1), len 56, sending full packet
.Aug 26 19:17:34.709: IP: s=192.168.0.50 (BVI1), d=8.8.4.4, len 68, dispose ip.noroute
.Aug 26 19:17:34.729: [Cellular0/3/0]:CNM: Modem up message received
.Aug 26 19:17:34.949: STP: opt: Bridge group 1: get ports: no free chunk available
.Aug 26 19:17:34.949: STP: opt: Bridge group 10: get ports: no free chunk available
.Aug 26 19:17:34.949: STP: opt: Bridge group 20: get ports: no free chunk available<192.168.0.50:57418,149.154.167.92:443,6,0,0>1
.Aug 26 19:17:35.405: CFT Ager: aged out flow 3507
.Aug 26 19:17:35.749: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:35.749: CEF-Debug: Packet from 192.168.0.1 (BV1) to 185.16.207.50
.Aug 26 19:17:35.749: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:17:35.749: TCPADJMSS: punt_feature
.Aug 26 19:17:35.749: IRB-CEF: LE vector failed on BVI1, enqueued to IP queue
.Aug 26 19:17:35.749: IPpacketQ deq s=192.168.0.1 (BVI1), d=185.16.207.50, flags=0xA80, tos=0x0, frag_offset=0
.Aug 26 19:17:35.749: UDP src=55047, dst=1194
.Aug 26 19:17:35.749: IP: s=192.168.0.1 (BVI1), d=185.16.207.50, len 114, input feature, debug packet(1), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:35.749: IP: s=192.168.0.1 (BVI1), d=185.16.207.50, len 114, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:35.749: IP: s=192.168.0.1 (BVI1), d=185.16.207.50, len 114, input feature, Stateful Inspection(8), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:36.577: CEF-Debug: Packet from 192.168.0.17 (BV1) to 8.8.4.4
.Aug 26 19:17:36.577: NAT: API parameters passed: src_addr:192.168.0.17, src_port:0 dest_addr:8.8.4.4, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:36.577: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:36.577: CFT L4: Error: fid[2681] invalid state in state bi-established
.Aug 26 19:17:36.577: CFT Ager: set flow 2681 aging to 360000 ms
.Aug 26 19:17:36.577: No route, drop
.Aug 26 19:17:36.577: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:36.945: 339: Bulkstat: bs_resource_usage_check: 240: 0: Resource usage percentage for local[0] is 30.
.Aug 26 19:17:36.945: 339: Bulkstat: bs_resource_usage_check_and_handle: 325: 0: Memory resource check is within limits.
.Aug 26 19:17:36.945: 339: Bulkstat: bs_resource_timer_start: 440: 0: Resource timer successfully started
.Aug 26 19:17:36.945: SPOLICY: [pid=280(QoS stats process)]: 10: Start stats polling
.Aug 26 19:17:36.945: -Traceback= 5CE6AB4z 73D2214z 73AB5D4z 73AB834z 4F95B60z 4F7CA80z
.Aug 26 19:17:36.945: SPOLICY: [pid=280(QoS stats process)]: Update show totals (periodic).
.Aug 26 19:17:37.561: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:37.561: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:37.941: FIBbg: Timer 'fibidb queue' expired, calling 0x0608B600, context 0x00000000)
.Aug 26 19:17:37.941: FIBif: Processing queued interface events
.Aug 26 19:17:37.941: FIBif: [sw:RG1(12) 01DEB450] Coming up
.Aug 26 19:17:37.941: FIBif: [sw:RG1(12) 01DEB450] Failed: Interface not really up
.Aug 26 19:17:37.941: FIBif: [sw:<unknown>(13) 02103340] Coming up
.Aug 26 19:17:38.585: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:38.641: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:38.641: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:38.761: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:38.761: CEF-Debug: Packet from 192.168.0.17 (BV1) to 8.8.8.8
.Aug 26 19:17:38.761: NAT: API parameters passed: src_addr:192.168.0.17, src_port:0 dest_addr:8.8.8.8, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:38.761: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:38.761: CFT L4: Error: fid[1799] invalid state in state bi-established
.Aug 26 19:17:38.761: CFT Ager: set flow 1799 aging to 360000 ms
.Aug 26 19:17:38.761: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:17:38.761: TCPADJMSS: punt_feature
.Aug 26 19:17:38.761: IRB-CEF: LE vector failed on BVI1, enqueued to IP queue
.Aug 26 19:17:38.761: CEF-Debug: Packet from 192.168.0.17 (BV1) to 8.8.8.8, len 78, rcvd 3
.Aug 26 19:17:39.525: IP: s=192.168.0.41 (BVI1), d=192.168.0.255, len 78, stop process pak for forus packet
.Aug 26 19:17:39.525: TCPADJMSS: process_enqueue_feature
.Aug 26 19:17:39.525: IP: s=192.168.0.41 (BVI1), d=192.168.0.255, len 78, enqueue feature, TCP Adjust MSS(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:39.525: UDP: rcvd src=192.168.0.41(137), dst=192.168.0.255(137), length=58
.Aug 26 19:17:39.525: IP: s=192.168.0.41 (BVI1), d=192.168.0.255, len 78, dispose udp.noport
.Aug 26 19:17:40.057: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:40.409: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:40.409: CEF-Debug: Packet from 192.168.0.82 (BV1) to 8.8.4.4
.Aug 26 19:17:40.409: No route, drop
.Aug 26 19:17:40.409: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:40.461: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:40.465: CEF-Debug: Packet from 192.168.0.1 (BV1) to 185.16.207.50
.Aug 26 19:17:40.465: No route, drop
.Aug 26 19:17:40.465: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:40.949: STP: opt: Bridge group 1: get ports: no free chunk available
.Aug 26 19:17:40.949: STP: opt: Bridge group 10: get ports: no free chunk available
.Aug 26 19:17:40.949: STP: opt: Bridge group 20: get ports: no free chunk available
.Aug 26 19:17:40.949: STP: opt: Bridge group 30: get ports: no free chunk available
.Aug 26 19:17:40.949: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:41.073: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:41.409: CEF-Debug: Packet from 192.168.0.82 (BV1) to 193.36.79.101
.Aug 26 19:17:41.409: No route, drop
.Aug 26 19:17:41.409: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:41.949: IP ARP STATIC: periodic adj update #4, attempt to update 0 entries
.Aug 26 19:17:42.149: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:42.149: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2 Control Plane:marking in pak exception [non cef linktype ARP]
.Aug 26 19:17:42.149: IP ARP: rcvd req src 192.168.0.90 740a.bc03.379f, dst 192.168.0.100 BVI1
.Aug 26 19:17:42.629: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:42.701: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:42.733:
.Aug 26 19:17:42.733: Rudpv1 Sent: Pkts 0, Data Bytes 0, Data Pkts 0
.Aug 26 19:17:42.733: Rudpv1 Rcvd: Pkts 0, Data Bytes 0, Data Pkts 0
.Aug 26 19:17:42.733: Rudpv1 Discarded: 0, Retransmitted 0
.Aug 26 19:17:42.949: STP: opt: Bridge group 1: get ports: no free chunk available
.Aug 26 19:17:42.949: STP: opt: Bridge group 10: get ports: no free chunk available
.Aug 26 19:17:42.949: STP: opt: Bridge group 20: get ports: no free chunk available
.Aug 26 19:17:42.949: STP: opt: Bridge group 30: get ports: no free chunk available
.Aug 26 19:17:42.949: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:43.149: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:43.149: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2 Control Plane:marking in pak exception [non cef linktype ARP]
.Aug 26 19:17:43.585: CFT L4: Error: fid[945] invalid state in state bi-established
.Aug 26 19:17:43.585: CFT Ager: set flow 945 aging to 360000 ms
.Aug 26 19:17:43.585: No route, drop
.Aug 26 19:17:43.585: IRB-CEF: (LE) switched from BVI1, (HE) not confCFT deleting flow 627 <192.168.0.91:60602,8.8.8.8:53,17,0,0>1
.Aug 26 19:17:43.597: CFT Ager: aged out flow 627
.Aug 26 19:17:43.765: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:43.765: CEF-Debug: Packet from 192.168.0.17 (BV1) to 8.8.4.4
.Aug 26 19:17:44.634: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:193.36.79.101, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:44.634: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:44.634: CFT L4: Error: fid[99] invalid state in state bi-established
.Aug 26 19:17:44.634: CFT Ager: set flow 99 aging to 360000 ms
.Aug 26 19:17:44.634: No route, drop
.Aug 26 19:17:44.634: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:44.950: STP: opt: Bridge group 1: get ports: no free chunk available
.Aug 26 19:17:44.950: STP: opt: Bridge group 10: get ports: no free chunk available
.Aug 26 19:17:44.950: STP: opt: Bridge group 20: get ports: no free chunk available
.Aug 26 19:17:44.950: STP: opt: Bridge group 30: get ports: no free chunk available
.Aug 26 19:17:44.954: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1
.Aug 26 19:17:44.970: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:44.970: CEF-Debug: Packet from 192.168.0.50 (BV1) to 8.8.4.4
.Aug 26 19:17:44.970: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:8.8.4.4, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:45.690: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:45.690: CEF-Debug: Packet from 192.168.0.50 (BV1) to 149.154.167.51
.Aug 26 19:17:45.690: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:149.154.167.51, dest_port:0, proto:6 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:45.690: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:45.690: No route, drop
.Aug 26 19:17:45.690: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:45.758: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet2/0 new - GigabitEthernet2/0.1, len 56, sending full packet
.Aug 26 19:17:46.690: IP: s=192.168.0.50 (BVI1), d=149.154.167.51, len 60, dispose ip.noroute
.Aug 26 19:17:46.830: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:46.830: CEF-Debug: Packet from 192.168.0.50 (BV1) to 149.154.167.51
.Aug 26 19:17:46.830: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:149.154.167.51, dest_port:0, proto:6 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:46.830: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:46.830: No route, drop
.Aug 26 19:17:46.830: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:46.946: 339: Bulkstat: bs_resource_usage_check: 240: 0: Resource usage percentage for local[0] is 30.
.Aug 26 19:17:46.946: 339: Bulkstat: bs_resource_usage_check_and_handle: 325: 0: Memory resource check is within limits.
.Aug 26 19:17:46.946: 339: Bulkstat: bs_resource_timer_start: 440: 0: Resource timer successfully started
.Aug 26 19:17:46.946: SPOLICY: [pid=280(QoS stats process)]: 10: Start stats polling
.Aug 26 19:17:46.946: -Traceback= 5CE6AB4z 73D2214z 73AB5D4z 73AB834z 4F95B60z 4F7CA80z
.Aug 26 19:17:46.946: SPOLICY: [pid=280(QoS stats process)]: Update show totals (periodic).
.Aug 26 19:17:47.546: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:47.546: CFT L4: Error: fid[2512] invalid state in streate bi-established
.Aug 26 19:17:47.546: CFT Ager: set flow 2512 aging to 360000 ms
.Aug 26 19:17:47.546: No route, drop
.Aug 26 19:17:47.546: IRB-CEF: (LE) switched from BVI1, (HE) not confCFT deleting flow 1998 <192.168.0.92:44158,8.8.8.8:53,17,0,0>1
.Aug 26 19:17:47.694: CFT Ager: aged out flow 1998
.Aug 26 19:17:47.798: Received CNS_GSM_SYSTEM_STATUS: status=2
.Aug 26 19:17:47.838: Received CNS_GSM_RETURN_SIM_STATUS: status=0
.Aug 26 19:17:47.930: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:47.930: CEF-Debug: Packet from 192.168.0.50 (BV1) to 149.154.167.51
.Aug 26 19:17:47.930: CFT L4: Error: fid[1410] retrans seg in state opening
.Aug 26 19:17:47.930: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:17:47.930: TCPADJMSS: punt_feature
.Aug 26 19:17:47.loasd930: IRB-CEF: LE vector failed on BVI1, enqueued to IP queue Control Plane:marking in pak exception [non cef linktype CDP]
.Aug 26 19:17:48.650: VRRSv4 Callback - Address to MAC: 192.168.0.100 is not a VRRS address
.Aug 26 19:17:48.650: IP ARP: sent rep src 192.168.0.100 a44c.11bb.a640,
dst 192.168.0.47 000c.296a.696a BVI1CFT deleting flow 1209 <192.168.0.91:57458,8.8.8.8:53,17,0,0>1
.Aug 26 19:17:48.718: CFT Ager: aged out flow 1209
.Aug 26 19:17:48.850: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:48.850: CEF-Debug: Packet from 192.168.0.92 (BV1) to 8.8.8.8
.Aug 26 19:17:48.850: NAT: API parameters passed: src_addr:192.168.0.92, src_port:0 dest_addr:8.8.8.8, dest_port:0, proto:17 if_input:BVI1 pak:149AE218
.Aug 26 19:17:49.642: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:149.154.167.92, dest_port:0, proto:6 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26
bifrost-cisco2951#:17:49.642: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:49.642: No route, drop
.Aug 26 19:17:49.642: IRB-CEF: (LE) switched from BVI1, (HE) not confCFT deleting flow 1871 <192.168.0.50:37794,8.8.8.8:53,17,0,0>1
.Aug 26 19:17:49.742: CFT Ager: aged out flow 1871CFT deleting flow 3189 <192.168.0.50:57420,149.154.167.92:443,6,0,0>1
.Aug 26 19:17:49.742: CFT Ager: aged out flow 3189
.Aug 26 19:17:49.886: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:49.886: CEF-Debug: Packet from 192.168.0.50 (BV1) to 149.154.167.92
.Aug 26 19:17:49.886: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:149.154.167.92, dest_port:0, proto:6 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:49.886: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:49.886: No route, drop
.Aug 26 19:17:49.886: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:50.062: Ingress packetreload VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:50.778: NAT: API parameters passed: src_addr:192.168.0.17, src_port:0 dest_addr:193.36.79.100, dest_port:0, proto:17 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:50.778: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:50.778: CFT L4: Error: fid[3760] invalid state in state bi-established
.Aug 26 19:17:50.778: CFT Ager: set flow 3760 aging to 360000 ms
.Aug 26 19:17:50.778: No route, drop
.Aug 26 19:17:50.778: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:50.870: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:51.694: CFT L4: Error: fid[969] invalid state in state bi-established
.Aug 26 19:17:51.694: CFT Ager: set flow 969 aging to 360000 ms
.Aug 26 19:17:51.694: No route, drop
.Aug 26 19:17:51.694: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:51.886: Ingress p
Proceed with reload? [confirm]acket VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:51.886: CEF-Debug: Packet from 192.168.0.50 (BV1) to 149.154.167.51
.Aug 26 19:17:51.886: CFT L4: Error: fid[1808] retrans seg in state opening
.Aug 26 19:17:51.886: No route, punt Control Plane: marking pak exception [cef reason 0]
.Aug 26 19:17:51.886: TCPADJMSS: punt_feature
.Aug 26 19:17:51.886: IRB-CEF: LE vector failed on BVI1, enqueued to IP queue
.Aug 26 19:17:51.886: IPpacketQ deq s=192.168.0.50 (BVI1), d=149.154.167.51, flags=0xA80, tos=0x0, frag_offset=0
.Aug 26 19:17:51.886: TCP src=37884, dst=5222, seq=468355822, ack=0, win=65535 SYN
.Aug 26 19:17:51.886: IP: s=192.168.0.50 (BVI1), d=149.154.167.51, len 60, input feature, debug packet(1), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
.Aug 26 19:17:51.886: IP: s=192.168.0.50 (BVI1), d=149.154.167.51, len 60, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk F
ALSE
.Aug 26 19:17:52.738: CEF-Debug: Packet from 192.168.0.50 (BV1) to 149.154.167.92
.Aug 26 19:17:52.738: NAT: API parameters passed: src_addr:192.168.0.50, src_port:0 dest_addr:149.154.167.92, dest_port:0, proto:6 if_input:BVI1 pak:147BA46C get_translated:1
.Aug 26 19:17:52.738: CFT Engine: NAT failed to find a translation
.Aug 26 19:17:52.738: No route, drop
.Aug 26 19:17:52.738: IRB-CEF: (LE) switched from BVI1, (HE) not confCFT deleting flow 3220 <192.168.0.91:33021,8.8.8.8:53,17,0,0>1
.Aug 26 19:17:52.818: CFT Ager: aged out flow 3220
.Aug 26 19:17:52.886: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/1 new - GigabitEthernet0/1
.Aug 26 19:17:53.598: CEF-Debug: Packet from 192.168.0.17 (BV1) to 8.8.8.8
.Aug 26 19:17:53.598: No route, drop
.Aug 26 19:17:53.598: IRB-CEF: (LE) switched from BVI1, (HE) not conf
.Aug 26 19:17:53.734: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:53.734: CEF-Debug: Packet from 192.168.0.50 (BV1) to 149.154.167.92
.Aug 26 19:17:53.734: CFT L4: Error: fid[1323] retrans seg in state opening
.Aug 26 19:17:53.734: No route, drop
.Aug 26 19:17:53.734: IRB-CEF: (LE) switched from BVI1, (HE) not confCFT deleting flow 1265 <54.171.75.153:27443,2.24.37.54:26794,17,0,0>1
.Aug 26 19:17:53.842: CFT Ager: aged out flow 1265CFT deleting flow 1214 <52.19.85.220:25398,2.24.37.54:26794,17,0,0>1
.Aug 26 19:17:53.842: CFT Ager: aged out flow 1214CFT deleting flow 3803 <54.76.23.179:52198,2.24.37.54:26794,17,0,0>1
.Aug 26 19:17:53.842: CFT Ager: aged out flow 3803CFT deleting flow 1009 <192.168.0.50:36415,8.8.8.8:53,17,0,0>1
.Aug 26 19:17:53.842: CFT Ager: aged out flow 1009
.Aug 26 19:17:53.846: Ingress packet VID: -1 priority: 0 if_input: old - GigabitEthernet0/2 new - GigabitEthernet0/2
.Aug 26 19:17:53.846: CEF-Debug: Packet from 192.168.0.1 (BV1) to 185.16.20PRST-VBL STD Sys reload - no flush necessary
PRST-VBL STD Process - timeout but no flush required
System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
Copyright (c) 2011 by cisco Systems, Inc.
Total memory size = 512 MB - DIMM0 = 512 MB, DIMM1 = 0 MB
CISCO2951/K9 platform with 524288 Kbytes of main memory
Main memory is configured to 72/0(dimm 0/1) bit mode with ECC enabled
Readonly ROMMON initialized
program load complete, entry point: 0x4000000, size: 0x18fa0
IOS Image Load Test
___________________
Digitally Signed Release Software
program load complete, entry point: 0x4000000, size: 0x6e1f1cc
Self decompressing the image : ########################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################### [OK]
*** No sreloc section
Smart Init is enabled
smart init is sizing iomem
TYPE MEMORY_REQ
HWIC Slot 0 0x00200000
HWIC Slot 3 0x00200000
SM Slot 2 0x00600000
Onboard devices &
buffer pools 0x0230F000
TOTAL: 0x02D0F000
Rounded IOMEM up to: 46MB.
Using 8 percent iomem. [46MB/512MB]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.7(3)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Wed 01-Aug-18 22:52 by prod_rel_team
PRST-VBL Debug set from cache (0x3FF,3FF) to All
PRST-VBL API Get (,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Lock - ok
PRST-VBL DET Compare Next - YES > NTPv4_Drift=0.6C978
PRST-VBL DET Cache unlock - ok
PRST-VBL API Get - ok returning "NTPv4_Drift=0.6C978" of size 20
PRST-VBL API Get (NTPv4_Drift=0.6C978,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO NTPv4_Drift=0.6C978 <= NTPv4_Drift=0.6C978
PRST-VBL DET Compare Next - YES NTPv4_Drift=0.6C978 > ReloadReason=12ab34Reload Command
PRST-VBL API Get - ok returning "ReloadReason=12ab34Reload Command" of size 34
PRST-VBL STD Anti - keeping ReloadReason=12ab34Reload Command
PRST-VBL API Get (ReloadReason=12ab34Reload Command,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO ReloadReason=12ab34Reload Command <= NTPv4_Drift=0.6C978
PRST-VBL DET Compare Next - NO ReloadReason=12ab34Reload Command <= ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - YES ReloadReason=12ab34Reload Command > prst-dbg=0x3FF
PRST-VBL API Get - ok returning "prst-dbg=0x3FF" of size 15
PRST-VBL API Get (prst-dbg=0x3FF,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO prst-dbg=0x3FF <= NTPv4_Drift=0.6C978
PRST-VBL DET Compare Next - NO prst-dbg=0x3FF <= ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - NO prst-dbg=0x3FF <= prst-dbg=0x3FF
PRST-VBL DET Compare Next - YES prst-dbg=0x3FF > prst-fls=36
PRST-VBL API Get - ok returning "prst-fls=36" of size 12
PRST-VBL API Get (prst-fls=36,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO prst-fls=36 <= NTPv4_Drift=0.6C978
PRST-VBL DET Compare Next - NO prst-fls=36 <= ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - NO prst-fls=36 <= prst-dbg=0x3FF
PRST-VBL DET Compare Next - NO prst-fls=36 <= prst-fls=36
PRST-VBL DET Compare Next - YES prst-fls=36 > prst-ver=1
PRST-VBL API Get - ok returning "prst-ver=1" of size 11
PRST-VBL API Get (prst-ver=1,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO prst-ver=1 <= NTPv4_Drift=0.6C978
PRST-VBL DET Compare Next - NO prst-ver=1 <= ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - NO prst-ver=1 <= prst-dbg=0x3FF
PRST-VBL DET Compare Next - NO prst-ver=1 <= prst-fls=36
PRST-VBL DET Compare Next - NO prst-ver=1 <= prst-ver=1
PRST-VBL DET Compare Next - YES prst-ver=1 > rf_cold_starts=0
PRST-VBL API Get - ok returning "rf_cold_starts=0" of size 17
PRST-VBL API Get (rf_cold_starts=0,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= NTPv4_Drift=0.6C978
PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= prst-dbg=0x3FF
PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= prst-fls=36
PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= prst-ver=1
PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= rf_cold_starts=0
PRST-VBL DET Compare Next - YES rf_cold_starts=0 > rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
PRST-VBL API Get - ok returning "rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason" of size 63
PRST-VBL API Get (rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason <= NTPv4_Drift=0.6C978
PRST-VBL DET Compare Next - NO rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason <= ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - NO rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason <= prst-dbg=0x3FF
PRST-VBL DET Compare Next - NO rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason <= prst-fls=36
PRST-VBL DET Compare Next - NO rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason <= prst-ver=1
PRST-VBL DET Compare Next - NO rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason <= rf_cold_starts=0
PRST-VBL DET Compare Next - NO rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason <= rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - YES rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason > rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
PRST-VBL API Get - ok returning "rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason" of size 63
PRST-VBL API Get (rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= NTPv4_Drift=0.6C978
PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= prst-dbg=0x3FF
PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= prst-fls=36
PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= prst-ver=1
PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= rf_cold_starts=0
PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - YES rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason > rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
PRST-VBL API Get - ok returning "rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason" of size 63
PRST-VBL API Get (rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= NTPv4_Drift=0.6C978
PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= prst-dbg=0x3FF
PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= prst-fls=36
PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= prst-ver=1
PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= rf_cold_starts=0
PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - YES rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason > rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason
PRST-VBL API Get - ok returning "rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason" of size 63
PRST-VBL API Get (rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= NTPv4_Drift=0.6C978
PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= prst-dbg=0x3FF
PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= prst-fls=36
PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= prst-ver=1
PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= rf_cold_starts=0
PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - YES rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason > rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason
PRST-VBL API Get - ok returning "rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason" of size 63
PRST-VBL API Get (rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= NTPv4_Drift=0.6C978
PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= prst-dbg=0x3FF
PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= prst-fls=36
PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= prst-ver=1
PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= rf_cold_starts=0
PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - YES rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason > rf_reload_data_index=0
PRST-VBL API Get - ok returning "rf_reload_data_index=0" of size 23
PRST-VBL API Get (rf_reload_data_index=0,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= NTPv4_Drift=0.6C978
PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= prst-dbg=0x3FF
PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= prst-fls=36
PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= prst-ver=1
PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= rf_cold_starts=0
PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= rf_reload_data_index=0
PRST-VBL API Get - rf_reload_data_index=0 missing in the prst cache
PRST-VBL API Get (rf-debug,1410F5E0,64,0x0-DEFAULT)
PRST-VBL API Get - rf-debug missing in the prst cache
PRST-VBL STD Init cache - ok
PRST-VBL MED Init complete - filesys added: buffer_named
PRST-VBL MED Init complete - filesys added: tmpsys
PRST-VBL STD Process - starting
PRST-VBL STD Process - waiting on system init
PRST-VBL MED Init complete - filesys added: null
PRST-VBL MED Init complete - filesys added: tftp
PRST-VBL MED Init complete - filesys added: flash0
PRST-VBL MED Init complete - filesys added: flash1
PRST-VBL MED Init complete - filesys added: hidden-nvram
PRST-VBL MED Init complete - filesys added: nvram
PRST-VBL MED Init complete - filesys added: syslog
PRST-VBL MED Init complete - filesys added: xmodem
PRST-VBL MED Init complete - filesys added: ymodem
PRST-VBL MED Init complete - filesys added: rcp
PRST-VBL API Get (snmpboots,1410F698,11,0x0-DEFAULT)
PRST-VBL API Get - snmpboots missing in the prst cache
PRST-VBL MED Init complete - filesys added: http
PRST-VBL MED Init complete - filesys added: ftp
PRST-VBL MED Init complete - filesys added: scp
PRST-VBL MED Init complete - filesys added: tar
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
PRST-VBL MED Init complete - filesys added: https
PRST-VBL MED Init complete - filesys added: cns
PRST-VBL API Get (CTS_STARTUP_DEBUG_FILENAME,1410F174,693,0x0-DEFAULT)
PRST-VBL API Get - CTS_STARTUP_DEBUG_FILENAME missing in the prst cache
PRST-VBL API Get (CTS_STARTUP_TEST_FILENAME,1410F42C,693,0x0-DEFAULT)
PRST-VBL API Get - CTS_STARTUP_TEST_FILENAME missing in the prst cache
cellwan_cwmp_init
PRST-VBL API Get (ReloadReason,1410F5F8,281,0x0-DEFAULT)
PRST-VBL API Get - ok returning "12ab34Reload Command" of size 21
Cisco CISCO2951/K9 (revision 1.1) with 477184K/47104K bytes of memory.
Processor board ID FCZ1622202F
1 DSL controller
1 Ethernet interface
5 Gigabit Ethernet interfaces
1 ATM interface
3 terminal lines
1 Cellular interface
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
If the interface doesn't support baby giant frames
maximum mtu of the interface has to be reduced by 4
bytes on both sides of the connection to properly
transmit or receive large packets. Please refer to
documentation on configuring IEEE 802.1Q vLANs.
PRST-VBL API Get (NTPv4_Drift,1410E5F4,31,0x0-DEFAULT)
PRST-VBL API Get - ok returning "0.6C978" of size 8
Press RETURN to get started!
*Jan 2 00:00:02.123: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jan 2 00:00:02.331: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2951 Next reboot level = ipbasek9 and License = ipbasek9
*Jan 2 00:00:05.007: PRST-VBL Debug set from cache (0x3FF,3FF) to All
*Jan 2 00:00:05.015: PRST-VBL API Get (,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:05.019: PRST-VBL DET Lock - ok
*Jan 2 00:00:05.031: PRST-VBL DET Compare Next - YES > NTPv4_Drift=0.6C978
*Jan 2 00:00:05.035: PRST-VBL DET Cache unlock - ok
*Jan 2 00:00:05.047: PRST-VBL API Get - ok returning "NTPv4_Drift=0.6C978" of size 20
*Jan 2 00:00:05.059: PRST-VBL API Get (NTPv4_Drift=0.6C978,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:05.063: PRST-VBL DET Lock - ok
*Jan 2 00:00:05.079: PRST-VBL DET Compare Next - NO NTPv4_Drift=0.6C978 <= NTPv4_Drift=0.6C978
*Jan 2 00:00:05.095: PRST-VBL DET Compare Next - YES NTPv4_Drift=0.6C978 > ReloadReason=12ab34Reload Command
*Jan 2 00:00:05.103: PRST-VBL DET Cache unlock - ok
*Jan 2 00:00:05.119: PRST-VBL API Get - ok returning "ReloadReason=12ab34Reload Command" of size 34
*Jan 2 00:00:05.131: PRST-VBL STD Anti - keeping ReloadReason=12ab34Reload Command
*Jan 2 00:00:05.143: PRST-VBL API Get (ReloadReason=12ab34Reload Command,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:05.151: PRST-VBL DET Lock - ok
*Jan 2 00:00:05.167: PRST-VBL DET Compare Next - NO ReloadReason=12ab34Reload Command <= NTPv4_Drift=0.6C978
*Jan 2 00:00:05.187: PRST-VBL DET Compare Next - NO ReloadReason=12ab34Reload Command <= ReloadReason=12ab34Reload Command
*Jan 2 00:00:05.203: PRST-VBL DET Compare Next - YES ReloadReason=12ab34Reload Command > prst-dbg=0x3FF
*Jan 2 00:00:05.207: PRST-VBL DET Cache unlock - ok
*Jan 2 00:00:05.219: PRST-VBL API Get - ok returning "prst-dbg=0x3FF" of size 15
*Jan 2 00:00:05.231: PRST-VBL API Get (prst-dbg=0x3FF,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:05.235: PRST-VBL DET Lock - ok
*Jan 2 00:00:05.247: PRST-VBL DET Compare Next - NO prst-dbg=0x3FF <= NTPv4_Drift=0.6C978
*Jan 2 00:00:05.263: PRST-VBL DET Compare Next - NO prst-dbg=0x3FF <= ReloadReason=12ab34Reload Command
*Jan 2 00:00:05.279: PRST-VBL DET Compare Next - NO prst-dbg=0x3FF <= prst-dbg=0x3FF
*Jan 2 00:00:05.291: PRST-VBL DET Compare Next - YES prst-dbg=0x3FF > prst-fls=36
*Jan 2 00:00:05.295: PRST-VBL DET Cache unlock - ok
*Jan 2 00:00:05.307: PRST-VBL API Get - ok returning "prst-fls=36" of size 12
*Jan 2 00:00:05.315: PRST-VBL API Get (prst-fls=36,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:05.323: PRST-VBL DET Lock - ok
*Jan 2 00:00:05.335: PRST-VBL DET Compare Next - NO prst-fls=36 <= NTPv4_Drift=0.6C978
*Jan 2 00:00:05.351: PRST-VBL DET Compare Next - NO prst-fls=36 <= ReloadReason=12ab34Reload Command
*Jan 2 00:00:05.363: PRST-VBL DET Compare Next - NO prst-fls=36 <= prst-dbg=0x3FF
*Jan 2 00:00:05.371: PRST-VBL DET Compare Next - NO prst-fls=36 <= prst-fls=36
*Jan 2 00:00:05.383: PRST-VBL DET Compare Next - YES prst-fls=36 > prst-ver=1
*Jan 2 00:00:05.391: PRST-VBL DET Cache unlock - ok
*Jan 2 00:00:05.399: PRST-VBL API Get - ok returning "prst-ver=1" of size 11
*Jan 2 00:00:05.411: PRST-VBL API Get (prst-ver=1,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:05.415: PRST-VBL DET Lock - ok
*Jan 2 00:00:05.427: PRST-VBL DET Compare Next - NO prst-ver=1 <= NTPv4_Drift=0.6C978
*Jan 2 00:00:05.443: PRST-VBL DET Compare Next - NO prst-ver=1 <= ReloadReason=12ab34Reload Command
*Jan 2 00:00:05.455: PRST-VBL DET Compare Next - NO prst-ver=1 <= prst-dbg=0x3FF
*Jan 2 00:00:05.467: PRST-VBL DET Compare Next - NO prst-ver=1 <= prst-fls=36
*Jan 2 00:00:05.479: PRST-VBL DET Compare Next - NO prst-ver=1 <= prst-ver=1
*Jan 2 00:00:05.491: PRST-VBL DET Compare Next - YES prst-ver=1 > rf_cold_starts=0
*Jan 2 00:00:05.495: PRST-VBL DET Cache unlock - ok
*Jan 2 00:00:05.507: PRST-VBL API Get - ok returning "rf_cold_starts=0" of size 17
*Jan 2 00:00:05.519: PRST-VBL API Get (rf_cold_starts=0,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:05.523: PRST-VBL DET Lock - ok
*Jan 2 00:00:05.539: PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= NTPv4_Drift=0.6C978
*Jan 2 00:00:05.555: PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= ReloadReason=12ab34Reload Command
*Jan 2 00:00:05.567: PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= prst-dbg=0x3FF
*Jan 2 00:00:05.579: PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= prst-fls=36
*Jan 2 00:00:05.591: PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= prst-ver=1
*Jan 2 00:00:05.603: PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= rf_cold_starts=0
*Jan 2 00:00:05.627: PRST-VBL DET Compare Next - YES rf_cold_starts=0 > rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
*Jan 2 00:00:05.631: PRST-VBL DET Cache unlock - ok
*Jan 2 00:00:05.655: PRST-VBL API Get - ok returning "rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason" of size 63
*Jan 2 00:00:05.675: PRST-VBL API Get (rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:05.679: PRST-VBL DET Lock - ok
*Jan 2 00:00:05.699: PRST-VBL DET Compare Next - NO rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason <= NTPv4_Drift=0.6C978
*Jan 2 00:00:05.727: PRST-VBL DET Compare Next - NO rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason <= ReloadReason=12ab34Reload Command
*Jan 2 00:00:05.747: PRST-VBL DET Compare Next - NO rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason <= prst-dbg=0x3FF
*Jan 2 00:00:05.767: PRST-VBL DET Compare Next - NO rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason <= prst-fls=36
*Jan 2 00:00:05.791: PRST-VBL DET Compare Next - NO rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason <= prst-ver=1
*Jan 2 00:00:05.811: PRST-VBL DET Compare Next - NO rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason <= rf_cold_starts=0
*Jan 2 00:00:05.843: PRST-VBL DET Compare Next - NO rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason <= rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
*Jan 2 00:00:05.871: PRST-VBL DET Compare Next - YES rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason > rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
*Jan 2 00:00:05.879: PRST-VBL DET Cache unlock - ok
*Jan 2 00:00:05.899: PRST-VBL API Get - ok returning "rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason" of size 63
*Jan 2 00:00:05.919: PRST-VBL API Get (rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:05.923: PRST-VBL DET Lock - ok
*Jan 2 00:00:05.947: PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= NTPv4_Drift=0.6C978
*Jan 2 00:00:05.971: PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= ReloadReason=12ab34Reload Command
*Jan 2 00:00:05.995: PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= prst-dbg=0x3FF
*Jan 2 00:00:06.015: PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= prst-fls=36
*Jan 2 00:00:06.035: PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= prst-ver=1
*Jan 2 00:00:06.059: PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= rf_cold_starts=0
*Jan 2 00:00:06.087: PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
*Jan 2 00:00:06.119: PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
*Jan 2 00:00:06.151: PRST-VBL DET Compare Next - YES rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason > rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
*Jan 2 00:00:06.155: PRST-VBL DET Cache unlock - ok
*Jan 2 00:00:06.175: PRST-VBL API Get - ok returning "rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason" of size 63
*Jan 2 00:00:06.199: PRST-VBL API Get (rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:06.203: PRST-VBL DET Lock - ok
*Jan 2 00:00:06.223: PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= NTPv4_Drift=0.6C978
*Jan 2 00:00:06.251: PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= ReloadReason=12ab34Reload Command
*Jan 2 00:00:06.271: PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= prst-dbg=0x3FF
*Jan 2 00:00:06.291: PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= prst-fls=36
*Jan 2 00:00:06.311: PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= prst-ver=1
*Jan 2 00:00:06.335: PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= rf_cold_starts=0
*Jan 2 00:00:06.367: PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
*Jan 2 00:00:06.395: PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
*Jan 2 00:00:06.427: PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
*Jan 2 00:00:06.459: PRST-VBL DET Compare Next - YES rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason > rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason
*Jan 2 00:00:06.463: PRST-VBL DET Cache unlock - ok
*Jan 2 00:00:06.483: PRST-VBL API Get - ok returning "rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason" of size 63
*Jan 2 00:00:06.507: PRST-VBL API Get (rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:06.511: PRST-VBL DET Lock - ok
*Jan 2 00:00:06.531: PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= NTPv4_Drift=0.6C978
*Jan 2 00:00:06.559: PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= ReloadReason=12ab34Reload Command
*Jan 2 00:00:06.579: PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= prst-dbg=0x3FF
*Jan 2 00:00:06.599: PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= prst-fls=36
*Jan 2 00:00:06.619: PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= prst-ver=1
*Jan 2 00:00:06.643: PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= rf_cold_starts=0
*Jan 2 00:00:06.675: PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
*Jan 2 00:00:06.703: PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
*Jan 2 00:00:06.735: PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
*Jan 2 00:00:06.767: PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason
*Jan 2 00:00:06.795: PRST-VBL DET Compare Next - YES rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason > rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason
*Jan 2 00:00:06.803: PRST-VBL DET Cache unlock - ok
*Jan 2 00:00:06.823: PRST-VBL API Get - ok returning "rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason" of size 63
*Jan 2 00:00:06.843: PRST-VBL API Get (rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:06.847: PRST-VBL DET Lock - ok
*Jan 2 00:00:06.871: PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= NTPv4_Drift=0.6C978
*Jan 2 00:00:06.895: PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= ReloadReason=12ab34Reload Command
*Jan 2 00:00:06.919: PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= prst-dbg=0x3FF
*Jan 2 00:00:06.939: PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= prst-fls=36
*Jan 2 00:00:06.959: PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= prst-ver=1
*Jan 2 00:00:06.983: PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= rf_cold_starts=0
*Jan 2 00:00:07.011: PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
*Jan 2 00:00:07.043: PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
*Jan 2 00:00:07.075: PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
*Jan 2 00:00:07.103: PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason
*Jan 2 00:00:07.135: PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason
*Jan 2 00:00:07.159: PRST-VBL DET Compare Next - YES rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason > rf_reload_data_index=0
*Jan 2 00:00:07.163: PRST-VBL DET Cache unlock - ok
*Jan 2 00:00:07.179: PRST-VBL API Get - ok returning "rf_reload_data_index=0" of size 23
*Jan 2 00:00:07.191: PRST-VBL API Get (rf_reload_data_index=0,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:07.195: PRST-VBL DET Lock - ok
*Jan 2 00:00:07.211: PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= NTPv4_Drift=0.6C978
*Jan 2 00:00:07.227: PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= ReloadReason=12ab34Reload Command
*Jan 2 00:00:07.243: PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= prst-dbg=0x3FF
*Jan 2 00:00:07.255: PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= prst-fls=36
*Jan 2 00:00:07.267: PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= prst-ver=1
*Jan 2 00:00:07.283: PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= rf_cold_starts=0
*Jan 2 00:00:07.307: PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
*Jan 2 00:00:07.327: PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
*Jan 2 00:00:07.351: PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
*Jan 2 00:00:07.375: PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason
*Jan 2 00:00:07.399: PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason
*Jan 2 00:00:07.415: PRST-VBL DET Compare Next - NO rf_reload_data_index=0 <= rf_reload_data_index=0
*Jan 2 00:00:07.419: PRST-VBL DET Cache unlock - ok
*Jan 2 00:00:07.431: PRST-VBL API Get - rf_reload_data_index=0 missing in the prst cache
*Jan 2 00:00:07.443: PRST-VBL API Get (rf-debug,1410F5E0,64,0x0-DEFAULT)
*Jan 2 00:00:07.447: PRST-VBL DET Lock - ok
*Jan 2 00:00:07.455: PRST-VBL DET Cache unlock - ok
*Jan 2 00:00:07.463: PRST-VBL API Get - rf-debug missing in the prst cache
*Jan 2 00:00:07.471: PRST-VBL STD Init cache - ok
*Aug 26 20:30:28.011: PRST-VBL MED Init complete - filesys added: buffer_named
*Aug 26 20:30:28.019: PRST-VBL MED Init complete - filesys added: tmpsys
*Aug 26 20:30:28.615: PRST-VBL STD Process - starting
*Aug 26 20:30:28.623: PRST-VBL STD Process - waiting on system init
*Aug 26 20:30:31.703: c3600_scp_set_dstaddr2_idb(185)add = 80 name is Embedded-Service-Engine0/0
*Aug 26 20:30:32.899: PRST-VBL MED Init complete - filesys added: null
*Aug 26 20:30:32.907: PRST-VBL MED Init complete - filesys added: tftp
*Aug 26 20:30:32.923: PRST-VBL MED Init complete - filesys added: flash0
*Aug 26 20:30:32.943: PRST-VBL MED Init complete - filesys added: flash1
*Aug 26 20:30:33.023: PRST-VBL MED Init complete - filesys added: hidden-nvram
*Aug 26 20:30:33.035: PRST-VBL MED Init complete - filesys added: nvram
*Aug 26 20:30:33.043: PRST-VBL MED Init complete - filesys added: syslog
*Aug 26 20:30:58.219: c3600_scp_set_dstaddr2_idb(185)add = 2 name is GigabitEthernet2/0
*Aug 26 20:30:58.283: PRST-VBL MED Init complete - filesys added: flash
*Aug 26 20:30:59.139: PRST-VBL MED Init complete - filesys added: xmodem
*Aug 26 20:30:59.151: PRST-VBL MED Init complete - filesys added: ymodem
*Aug 26 20:30:59.187: PRST-VBL MED Init complete - filesys added: rcp
*Aug 26 20:30:59.451: PRST-VBL API Get (snmpboots,1410F698,11,0x0-DEFAULT)
*Aug 26 20:30:59.455: PRST-VBL DET Lock - ok
*Aug 26 20:30:59.463: PRST-VBL DET Cache unlock - ok
*Aug 26 20:30:59.475: PRST-VBL API Get - snmpboots missing in the prst cache
*Aug 26 20:30:59.487: PRST-VBL MED Init complete - filesys added: http
*Aug 26 20:31:00.319: PRST-VBL MED Init complete - filesys added: ftp
*Aug 26 20:31:00.415: PRST-VBL MED Init complete - filesys added: scp
*Aug 26 20:31:00.491: PRST-VBL MED Init complete - filesys added: tar
*Aug 26 20:31:00.831: PRST-VBL MED Init complete - filesys added: https
*Aug 26 20:31:01.219: PRST-VBL MED Init complete - filesys added: cns
*Aug 26 20:31:02.743: PRST-VBL API Get (CTS_STARTUP_DEBUG_FILENAME,1410F174,693,0x0-DEFAULT)
*Aug 26 20:31:02.747: PRST-VBL DET Lock - ok
*Aug 26 20:31:02.755: PRST-VBL DET Cache unlock - ok
*Aug 26 20:31:02.771: PRST-VBL API Get - CTS_STARTUP_DEBUG_FILENAME missing in the prst cache
*Aug 26 20:31:02.783: PRST-VBL API Get (CTS_STARTUP_TEST_FILENAME,1410F42C,693,0x0-DEFAULT)
*Aug 26 20:31:02.787: PRST-VBL DET Lock - ok
*Aug 26 20:31:02.795: PRST-VBL DET Cache unlock - ok
*Aug 26 20:31:02.807: PRST-VBL API Get - CTS_STARTUP_TEST_FILENAME missing in the prst cache
*Aug 26 20:31:02.855: PRST-VBL API Get (ReloadReason,1410F5F8,281,0x0-DEFAULT)
*Aug 26 20:31:02.859: PRST-VBL DET Lock - ok
*Aug 26 20:31:02.867: PRST-VBL DET Cache unlock - ok
*Aug 26 20:31:02.879: PRST-VBL API Get - ok returning "12ab34Reload Command" of size 21
*Aug 26 20:31:03.151: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
*Aug 26 20:31:03.151: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Aug 26 20:31:03.151: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to up
*Aug 26 20:31:03.255: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0/0, changed state to down
*Aug 26 20:31:03.255: %LINK-3-UPDOWN: Interface GigabitEthernet2/0, changed state to up
*Aug 26 20:31:03.811: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Aug 26 20:31:04.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Aug 26 20:31:04.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Aug 26 20:31:04.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to up
*Aug 26 20:31:04.255: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0, changed state to up
*Aug 26 20:31:04.695: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level informational, xml disabled, filtering disabled, size (51200)
*Aug 26 20:31:04.699: %SYS-6-CLOCKUPDATE: System clock has been updated from 20:31:04 UTC Mon Aug 26 2019 to 20:31:04 GMT Mon Aug 26 2019, configured from console by vty0.
*Aug 26 20:31:05.191: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
*Aug 26 20:31:05.191: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
*Aug 26 20:31:05.399: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
*Aug 26 20:31:05.491:
Note: A random mac address of 0000.0cc9.b818
has been chosen for BVI in bridge group 20 since the selected mac address
is already being used by Bridge Group 10.
Ensure that this address is unique.
*Aug 26 20:31:05.495:
Note: A random mac address of 0000.0cc9.b81c
has been chosen for BVI in bridge group 30 since the selected mac address
*Aug 26 20:31:05.543:
Note: A random Spanning Tree Bridge Identifier address of 0000.0cf0.b84c
has been chosen for Bridge Group 20 since the selected mac address
*Aug 26 20:31:05.547:
Note: A random Spanning Tree Bridge Identifier address of 0000.0cf0.b850
has been chosen for Bridge Group 30 since the selected mac address
*Aug 26 20:31:05.583: PRST-VBL API Get (NTPv4_Drift,1410E5F4,31,0x0-DEFAULT)
*Aug 26 20:31:05.587: PRST-VBL DET Lock - ok
*Aug 26 20:31:05.595: PRST-VBL DET Cache unlock - ok
*Aug 26 20:31:05.603: PRST-VBL API Get - ok returning "0.6C978" of size 8
*Aug 26 20:31:05.607: %SYS-5-CONFIG_I: Configured from memory by console
*Aug 26 20:31:06.015: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
*Aug 26 20:31:06.015: %SYS-5-RESTART: System restarted --
*Aug 26 20:31:06.027: %SYS-6-BOOTTIME: Time taken to reboot after reload = 203 seconds
*Aug 26 20:31:06.027: PRST-VBL API Set (ReloadReason=12ab34Unknown reason,0x0-DEFAULT)
*Aug 26 20:31:06.027: PRST-VBL DET Lock - ok
*Aug 26 20:31:06.027: PRST-VBL DET - Util Set - nameval=ReloadReason=12ab34Unknown reason and node->nameval=ReloadReason=12ab34Reload Command.
*Aug 26 20:31:06.027: PRST-VBL STD Util Set - straight copy of ReloadReason=12ab34Unknown reason
*Aug 26 20:31:06.027: PRST-VBL STD Flush condition - delayed until process running
*Aug 26 20:31:06.027: PRST-VBL DET Cache unlock - ok
*Aug 26 20:31:06.027: PRST-VBL API Set - ok return 33
*Aug 26 20:31:06.031: PRST-VBL API Get (sum_new_imgname,12E81C48,693,0x0-DEFAULT)
*Aug 26 20:31:06.031: PRST-VBL DET Lock - ok
*Aug 26 20:31:06.031: PRST-VBL DET Cache unlock - ok
*Aug 26 20:31:06.031: PRST-VBL API Get - sum_new_imgname missing in the prst cache
*Aug 26 20:31:06.031: PRST-VBL STD Process - running and timer started
*Aug 26 20:31:06.035: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Aug 26 20:31:06.127: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
*Aug 26 20:31:06.127: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Aug 26 20:31:06.191: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Aug 26 20:31:06.331: %ETHSW_SM-3-ILP_RECOVERY_COMPLETE: Time taken for recovery after reload = 0 seconds.
*Aug 26 20:31:06.399: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
*Aug 26 20:31:06.451: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan10, changed state to down
*Aug 26 20:31:06.455: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan20, changed state to down
*Aug 26 20:31:06.459: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan30, changed state to down
*Aug 26 20:31:06.483: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Aug 26 20:31:06.487: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI10, changed state to up
*Aug 26 20:31:06.491: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI20, changed state to up
*Aug 26 20:31:06.495: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI30, changed state to up
*Aug 26 20:31:06.735: %LINK-5-CHANGED: Interface Embedded-Service-Engine0/0, changed state to administratively down
*Aug 26 20:31:07.443: %LINK-5-CHANGED: Interface ATM0/0/0, changed state to administratively down
*Aug 26 20:31:07.443: %LINK-5-CHANGED: Interface GigabitEthernet2/0, changed state to administratively down
*Aug 26 20:31:07.443: %LINK-5-CHANGED: Interface GigabitEthernet2/1, changed state to administratively down
*Aug 26 20:31:11.032: PRST-VBL STD Process - flushing
*Aug 26 20:31:11.032: PRST-VBL DET Lock - ok
*Aug 26 20:31:11.032: PRST-VBL DET - Util Set - nameval=prst-fls=37 and node->nameval=prst-fls=36.
*Aug 26 20:31:11.032: PRST-VBL STD Util Set - straight copy of prst-fls=37
*Aug 26 20:31:11.032: PRST-VBL MED Open Write - opening nvram:persistent-data
*Aug 26 20:31:11.032: PRST-VBL MED Open Write - got buf of size 2048 in 0 ms
*Aug 26 20:31:11.032: PRST-VBL MDET Write - NTPv4_Drift=0.6C978
*Aug 26 20:31:11.032: PRST-VBL DET Write Nameval - ok put of NTPv4_Drift=0.6C978
*Aug 26 20:31:11.032: PRST-VBL MDET Write - ReloadReason=12ab34Unknown reason
*Aug 26 20:31:11.032: PRST-VBL DET Write Nameval - ok put of ReloadReason=12ab34Unknown reason
*Aug 26 20:31:11.032: PRST-VBL MDET Write - prst-dbg=0x3FF
*Aug 26 20:31:11.032: PRST-VBL DET Write Nameval - ok put of prst-dbg=0x3FF
*Aug 26 20:31:11.032: PRST-VBL MDET Write - prst-fls=37
*Aug 26 20:31:11.032: PRST-VBL DET Write Nameval - ok put of prst-fls=37
*Aug 26 20:31:11.032: PRST-VBL MDET Write - prst-ver=1
*Aug 26 20:31:11.032: PRST-VBL DET Write Nameval - ok put of prst-ver=1
*Aug 26 20:31:11.032: PRST-VBL MDET Write - rf_cold_starts=0
*Aug 26 20:31:11.032: PRST-VBL DET Write Nameval - ok put of rf_cold_starts=0
*Aug 26 20:31:11.032: PRST-VBL MDET Write - rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
*Aug 26 20:31:11.032: PRST-VBL DET Write Nameval - ok put of rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
*Aug 26 20:31:11.032: PRST-VBL MDET Write - rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
*Aug 26 20:31:11.032: PRST-VBL DET Write Nameval - ok put of rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
*Aug 26 20:31:11.032: PRST-VBL MDET Write - rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
*Aug 26 20:31:13.080: PRST-VBL MED Close Write - wrote table size 448 in 2048 ms
*Aug 26 20:31:13.080: PRST-VBL STD Flush to media - okCCCC
* Unauthorized access prohibited
* You are connected to CISCO 2951 Router
* at ip 192.168.0.100
bifrost-cisco2951>
*Aug 26 20:31:50.412: %CELLWAN-2-MODEM_UP: Modem in HWIC slot 0/3 is now UP
11 Replies 11
Georg Pauwen
I don't see the '%SYS-2-GETBUFFFAIL' in your debug output, but post the output of:
show buffers
Mark Elsen
- As stated by other you may want to cut your output to relevant errors and keep it short and informative; that being said have a look at the current software version on your platform. Consider upgrading if it would be old (e.g.).
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
bifrost-cisco2951#show buffers
Buffer elements:
625 in free list
710513 hits, 0 misses, 1242 created
Public buffer pools:
Small buffers, 104 bytes (total 51, permanent 50, peak 95 @ 1d01h):
46 in free list (20 min, 150 max allowed)
202719 hits, 15 misses, 44 trims, 45 created
0 failures (0 no memory)
Middle buffers, 600 bytes (total 25, permanent 25, peak 88 @ 1d01h):
25 in free list (10 min, 150 max allowed)
104508 hits, 21 misses, 63 trims, 63 created
Big buffers, 1536 bytes (total 50, permanent 50, peak 51 @ 1d01h):
50 in free list (5 min, 150 max allowed)
3181 hits, 0 misses, 1 trims, 1 created
VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 11 @ 1d01h):
10 in free list (0 min, 100 max allowed)
0 hits, 0 misses, 1 trims, 1 created
Large buffers, 5024 bytes (total 1, permanent 0, peak 1 @ 1d01h):
1 in free list (0 min, 10 max allowed)
0 hits, 0 misses, 9 trims, 10 created
Huge buffers, 18024 bytes (total 5, permanent 0, peak 5 @ 1d01h):
5 in free list (4 min, 10 max allowed)
0 hits, 0 misses, 17 trims, 22 created
Interface buffer pools:
CF Small buffers, 104 bytes (total 101, permanent 100, peak 101 @ 1d01h):
101 in free list (100 min, 200 max allowed)
Generic ED Pool buffers, 512 bytes (total 101, permanent 100, peak 101 @ 1d01h):
101 in free list (100 min, 100 max allowed)
0 hits, 0 misses
CF Middle buffers, 600 bytes (total 101, permanent 100, peak 101 @ 1d01h):
Syslog ED Pool buffers, 600 bytes (total 133, permanent 132, peak 133 @ 1d01h):
101 in free list (132 min, 132 max allowed)
116 hits, 0 misses
CF Big buffers, 1536 bytes (total 26, permanent 25, peak 26 @ 1d01h):
26 in free list (25 min, 50 max allowed)
pak coalesce engine buffers, 1536 bytes (total 512, permanent 256, peak 512 @ 1d01h):
0 in free list (0 min, 512 max allowed)
384 hits, 128 misses, 0 trims, 256 created
512 max cache size, 512 in cache
303465 hits in cache, 0 misses in cache
Cellular data buffer pool buffers, 1548 bytes (total 1016, permanent 1016):
0 in free list (0 min, 1016 max allowed)
1016 hits, 0 fallbacks
1016 max cache size, 951 in cache
160 hits in cache, 0 misses in cache
Cellular Mgmt pak pool buffers, 3072 bytes (total 320, permanent 320):
0 in free list (0 min, 320 max allowed)
320 hits, 0 misses
320 max cache size, 256 in cache
13170 hits in cache, 0 misses in cache
IPC buffers, 4096 bytes (total 2, permanent 2):
1 in free list (1 min, 8 max allowed)
1 hits, 0 fallbacks, 0 trims, 0 created
CF VeryBig buffers, 4520 bytes (total 3, permanent 2, peak 3 @ 1d01h):
3 in free list (2 min, 4 max allowed)
CF Large buffers, 5024 bytes (total 2, permanent 1, peak 2 @ 1d01h):
2 in free list (1 min, 2 max allowed)
IPC Medium buffers, 16384 bytes (total 2, permanent 2):
2 in free list (1 min, 8 max allowed)
0 hits, 0 fallbacks, 0 trims, 0 created
IPC Large buffers, 65535 bytes (total 17, permanent 16, peak 17 @ 1d01h):
17 in free list (16 min, 16 max allowed)
0 hits, 0 misses, 1505 trims, 1506 created
Header pools:
Header buffers, 0 bytes (total 768, permanent 768):
256 in free list (128 min, 1024 max allowed)
512 hits, 0 misses, 0 trims, 0 created
56426 hits in cache, 0 misses in cache
Particle Clones:
1024 clones, 67276 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 768, permanent 768):
67276 hits in cache, 0 misses in cache
Normal buffers, 1548 bytes (total 3840, permanent 3840):
3456 in free list (128 min, 4096 max allowed)
1251 hits, 0 misses, 0 trims, 0 created
Private particle pools:
HQF Particle buffers, 0 bytes (total 2000, permanent 2000):
2000 in free list (500 min, 2000 max allowed)
0 hits, 0 misses, 0 trims, 0 created
IDS SM buffers, 240 bytes (total 128, permanent 128):
0 in free list (0 min, 128 max allowed)
128 hits, 0 fallbacks
128 max cache size, 128 in cache
PSE2-2/0 buffers, 1536 bytes (total 768, permanent 768):
0 in free list (0 min, 768 max allowed)
768 hits, 0 fallbacks
768 max cache size, 512 in cache
317319 hits in cache, 0 misses in cache
Ethernet0/0/0 buffers, 1548 bytes (total 128, permanent 128):
128 hits, 355 fallbacks
128 max cache size, 64 in cache
5686659 hits in cache, 291 misses in cache
GigabitEthernet0/0 buffers, 1664 bytes (total 768, permanent 768):
768 max cache size, 768 in cache
GigabitEthernet0/1 buffers, 1664 bytes (total 768, permanent 768):
752455 hits in cache, 0 misses in cache
GigabitEthernet0/2 buffers, 1664 bytes (total 768, permanent 768):
3322106 hits in cache, 0 misses in cache
bifrost-cisco2951#
Please see top post again, there was a bit missing. it now has GETBUFFFAIL.
make the adjustments below and see if that makes a difference:
2951(config)#buffers middle permanent 100
2951(config)#buffers middle initial 75
2951(config)#buffers middle min-free 150
2951(config)#buffers middle max-free 300
thanks for that, i seem to have lost network again this morning, although it came back shortly after, no idea why its saying a card inserted 😞 i do not have anything in slot 1, only 0 and 3 working from right.
Aug 28 07:48:04.280: %OIR-6-INSCARD: Card inserted in slot 1, interfaces administratively shut down
Aug 28 07:48:04.288: %SCHED-7-WATCH: Attempt to set uninitialized watched boolean (address 0). -Process= "<interrupt level>", ipl= 2
-Traceback= 5CE1848z 404F35Cz 449C1B4z 4A1DAFCz 44B1348z 4026134z 40AF280z 40AF280z 40261F0z 40AED88z 4808124z 83EF3BCz 5BF7E68z 4F7DAE0z 4F849B4z
Aug 28 07:48:56.874: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
.Aug 28 07:48:56.878: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
.Aug 28 07:48:56.882: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
.Aug 28 07:49:04.262: %CELLWAN-2-HEART_BEAT_TIMEOUT: No heart beat signal from Cellular0/3/0
.Aug 28 07:53:03.110: %VDSL_DAEMON-3-MODEMRESET: VDSL Modem reset. Reloading the modem.
.Aug 28 07:53:03.110: %CONTROLLER-5-UPDOWN: Controller VDSL 0/0/0, changed state to down
.Aug 28 07:53:04.110: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0/0, changed state to down
Translating "dc"...domain server (8.8.8.8)
.Aug 28 07:53:14.700: %OIR-6-REMCARD: Card removed from slot 1, interfaces disabled
.Aug 28 07:53:14.728: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/3 is DOWN (8.8.4.4) (193.36.79.101) (193.36.79.100) (87.237.17.166) (87.237.17.198)
.Aug 28 07:53:59.864: %CELLWAN-2-MODEM_UP: Modem in HWIC slot 0/3 is now UP
% Bad IP address or host name
.Aug 28 07:54:08.685: %CONTROLLER-5-UPDOWN: Controller VDSL 0/0/0, changed state to up
.Aug 28 07:54:09.685: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0/0, changed state to up (8.8.4.4) (193.36.79.101) (193.36.79.100)
.Aug 28 07:54:38.000: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
.Aug 28 07:54:38.004: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
.Aug 28 07:54:40.104: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
(8.8.8.8)
.Aug 28 07:54:42.312: %CELLWAN-2-MODEM_RADIO: Cellular0/3/0 Modem radio has been turned on
Did you adjust the buffers ? If so, and the problem just reoccurred, post the output of 'show buffers' again. I think the small buffers had misses, too...
i got the error just before making change,
so i will leave it for the moment and check to see if problem reoccurs,
thanks for  your assistance, really appreciated.
dave
i seem to have had issues this morning again
bifrost-cisco2951#
Aug 30 08:03:45.399: %OIR-6-INSCARD: Card inserted in slot 1, interfaces administratively shut down
Aug 30 08:03:45.407: %SCHED-7-WATCH: Attempt to set uninitialized watched boolean (address 0). -Process= "<interrupt level>", ipl= 2
-Traceback= 5CE1848z 404F35Cz 449C1B4z 4A1DAFCz 44B1348z 4026134z 40AF280z 40AF280z 40261F0z 5BF7E44z
Aug 30 08:04:44.017: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
.Aug 30 08:04:44.017: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
.Aug 30 08:04:44.021: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
.Aug 30 08:04:44.285: %CELLWAN-2-HEART_BEAT_TIMEOUT: No heart beat signal from Cellular0/3/0
.Aug 30 08:08:44.836: %VDSL_DAEMON-3-MODEMRESET: VDSL Modem reset. Reloading the modem.
.Aug 30 08:08:44.836: %CONTROLLER-5-UPDOWN: Controller VDSL 0/0/0, changed state to down
.Aug 30 08:08:45.836: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0/0, changed state to down
bifrost-cisco2951#reload
.Aug 30 08:09:38.865: PRST-VBL API Set (NTPv4_Drift=0.6CB83,0x0-DEFAULT)
.Aug 30 08:09:38.865: PRST-VBL DET Lock - ok
.Aug 30 08:09:38.865: PRST-VBL DET - Util Set - nameval=NTPv4_Drift=0.6CB83 and node->nameval=NTPv4_Drift=0.6C978.
.Aug 30 08:09:38.865: PRST-VBL STD Util Set - straight copy of NTPv4_Drift=0.6CB83
.Aug 30 08:09:38.865: PRST-VBL STD Flush condition - timer starting
.Aug 30 08:09:38.865: PRST-VBL DET Cache unlock - ok
.Aug 30 08:09:38.865: PRST-VBL API Set - ok return 19
.Aug 30 08:09:43.866: PRST-VBL STD Process - flushing
.Aug 30 08:09:43.866: PRST-VBL DET Lock - ok
.Aug 30 08:09:43.866: PRST-VBL DET - Util Set - nameval=prst-fls=38 and node->nameval=prst-fls=37.
.Aug 30 08:09:43.866: PRST-VBL STD Util Set - straight copy of prst-fls=38
.Aug 30 08:09:43.866: PRST-VBL MED Open Write - opening nvram:persistent-data
.Aug 30 08:09:43.866: PRST-VBL MED Open Write - got buf of size 2048 in 0 ms
.Aug 30 08:09:43.866: PRST-VBL MDET Write - NTPv4_Drift=0.6CB83
.Aug 30 08:09:43.866: PRST-VBL DET Write Nameval - ok put of NTPv4_Drift=0.6CB83
.Aug 30 08:09:43.866: PRST-VBL MDET Write - ReloadReason=12ab34Unknown reason
.Aug 30 08:09:43.866: PRST-VBL DET Write Nameval - ok put of ReloadReason=12ab34Unknown reason
.Aug 30 08:09:43.866: PRST-VBL MDET Write - prst-dbg=0x3FF
.Aug 30 08:09:43.866: PRST-VBL DET Write Nameval - ok put of prst-dbg=0x3FF
.Aug 30 08:09:43.866: PRST-VBL MDET Write - prst-fls=38
.Aug 30 08:09:43.866: PRST-VBL DET Write Nameval - ok put of prst-fls=38
.Aug 30 08:09:43.866: PRST-VBL MDET Write - prst-ver=1
.Aug 30 08:09:43.866: PRST-VBL DET Write Nameval - ok put of prst-ver=1
.Aug 30 08:09:43.866: PRST-VBL MDET Write - rf_cold_starts=0
.Aug 30 08:09:43.866: PRST-VBL DET Write Nameval - ok put of rf_cold_starts=0
.Aug 30 08:09:43.866: PRST-VBL MDET Write - rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
.Aug 30 08:09:43.866: PRST-VBL DET Write Nameval - ok put of rf_reload_data0=07-20-19 20:50:07 Unknown User: Unknown Reason
.Aug 30 08:09:43.866: PRST-VBL MDET Write - rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
.Aug 30 08:09:43.866: PRST-VBL DET Write Nameval - ok put of rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
.Aug 30 08:09:43.866: PRST-VBL MDET Write - rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
.Aug 30 08:09:43.866: PRST-VBL DET Write Nameval - ok put of rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
.A
ug 30 08:09:43.866: PRST-VBL MDET Write - rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason
.Aug 30 08:09:43.866: PRST-VBL DET Write Nameval - ok put of rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason
.Aug 30 08:09:43.866: PRST-VBL MDET Write - rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason
.Aug 30 08:09:43.866: PRST-VBL DET Write Nameval - ok put of rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason
.Aug 30 08:09:43.866: PRST-VBL MDET Write - rf_reload_data_index=0
.Aug 30 08:09:43.866: PRST-VBL DET Write Nameval - ok put of rf_reload_data_index=0
.Aug 30 08:09:43.866: PRST-VBL DET Cache unlock - ok
.Aug 30 08:09:43.866: PRST-VBL MED Close WritePRST-VBL STD Sys reload - no flush necessary
.Aug 30 08:09:45.934: PRST-VBL MED Close Write - wrote table size 448 in 2068 ms
.Aug 30 08:09:45.934: PRST-VBL STD Flush to media - ok
.Aug 30 08:09:46.750: PRST-VBL API Set (ReloadReason=12ab34Reload Command,0x0-DEFAULT)
.Aug 30 08:09:46.750: PRST-VBL DET Lock - ok
.Aug 30 08:09:46.750: PRST-VBL DET - Util Set - nameval=ReloadReason=12ab34Reload Command and node->nameval=ReloadReason=12ab34Unknown reason.
.Aug 30 08:09:46.750: PRST-VBL STD Util Set - straight copy of ReloadReason=12ab34Reload Command
.Aug 30 08:09:46.750: PRST-VBL STD Flush condition - timer starting
.Aug 30 08:09:46.750: PRST-VBL DET Cache unlock - ok
.Aug 30 08:09:46.750: PRST-VBL API Set - ok return 33
.Aug 30 08:09:46.762: PRST-VBL API Set (ReloadReason=12ab34Reload Command,0x0-DEFAULT)
.Aug 30 08:09:46.762: PRST-VBL DET Lock - ok
.Aug 30 08:09:46.762: PRST-VBL DET - Util Set - nameval=ReloadReason=12ab34Reload Command and node->nameval=ReloadReason=12ab34Reload Command.
.Aug 30 08:09:46.762: PRST-VBL STD Util Set - identical ReloadReason=12ab34Reload Command
.Aug 30 08:09:46.762: PRST-VBL STD Flush condition - timer already running
.Aug 30 08:09:46.762: PRST-VBL DET Cache unlock - ok
.Aug 30 08:09:46.762: PRST-VBL API Set - ok return 33
.Aug 30 08:09:46.762: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
.Aug 30 08:09:46.766: PRST-VBL API Get (rf_reload_data_index,2B37384,256,0x0-DEFAULT)
.Aug 30 08:09:46.766: PRST-VBL DET Lock - ok
.Aug 30 08:09:46.766: PRST-VBL DET Cache unlock - ok
.Aug 30 08:09:46.766: PRST-VBL API Get - ok returning "0" of size 2
.Aug 30 08:09:46.766: PRST-VBL API Set (rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason,0x0-DEFAULT)
.Aug 30 08:09:46.766: PRST-VBL DET - Util Set - nameval=rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason and node->nameval=rf_reload_data0=07-20-19 20:50:07 Unknown User: Unkno
.Aug 30 08:09:46.766: PRST-VBL STD Util Set - straight copy of rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
.Aug 30 08:09:46.766: PRST-VBL STD Flush condition - timer already running
.Aug 30 08:09:46.766: PRST-VBL API Set - ok return 62
.Aug 30 08:09:46.766: PRST-VBL API Set (rf_reload_data_index=1,0x0-DEFAULT)
.Aug 30 08:09:46.766: PRST-VBL DET - Util Set - nameval=rf_reload_data_index=1 and node->nameval=rf_reload_data_index=0.
.Aug 30 08:09:46.766: PRST-VBL STD Util Set - straight copy of rf_reload_data_index=1
.Aug 30 08:09:46.766: PRST-VBL API Set - ok return 22
.Aug 30 08:09:46.766: PRST-VBL API Flush (0x0-DEFAULT)
.Aug 30 08:09:46.766: PRST-VBL DET - Util Set - nameval=prst-fls=39 and node->nameval=prst-fls=38.
.Aug 30 0PRST-VBL STD Process - timeout but no flush required
8:09:46.766: PRST-VBL STD Util Set - straight copy of prst-fls=39
.Aug 30 08:09:46.766: PRST-VBL MED Open Write - opening nvram:persistent-data
.Aug 30 08:09:46.766: PRST-VBL MED Open Write - got buf of size 2048 in 0 ms
.Aug 30 08:09:46.766: PRST-VBL MDET Write - NTPv4_Drift=0.6CB83
.Aug 30 08:09:46.766: PRST-VBL DET Write Nameval - ok put of NTPv4_Drift=0.6CB83
.Aug 30 08:09:46.766: PRST-VBL MDET Write - ReloadReason=12ab34Reload Command
.Aug 30 08:09:46.766: PRST-VBL DET Write Nameval - ok put of ReloadReason=12ab34Reload Command
.Aug 30 08:09:46.766: PRST-VBL MDET Write - prst-dbg=0x3FF
.Aug 30 08:09:46.766: PRST-VBL DET Write Nameval - ok put of prst-dbg=0x3FF
.Aug 30 08:09:46.766: PRST-VBL MDET Write - prst-fls=39
.Aug 30 08:09:46.766: PRST-VBL DET Write Nameval - ok put of prst-fls=39
.Aug 30 08:09:46.766: PRST-VBL MDET Write - prst-ver=1
.Aug 30 08:09:46.766: PRST-VBL DET Write Nameval - ok put of prst-ver=1
.Aug 30 08:09:46.766: PRST-VBL MDET Write - rf_cold_sta
IOS Image Load Test
___________________
TYPE MEMORY_REQ
Onboard devices &
TOTAL: 0x02D0F000
cisco Systems, Inc.
PRST-VBL DET Compare Next - YES > NTPv4_Drift=0.6CB83
PRST-VBL API Get - ok returning "NTPv4_Drift=0.6CB83" of size 20
PRST-VBL API Get (NTPv4_Drift=0.6CB83,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO NTPv4_Drift=0.6CB83 <= NTPv4_Drift=0.6CB83
PRST-VBL DET Compare Next - YES NTPv4_Drift=0.6CB83 > ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - NO ReloadReason=12ab34Reload Command <= NTPv4_Drift=0.6CB83
PRST-VBL DET Compare Next - NO prst-dbg=0x3FF <= NTPv4_Drift=0.6CB83
PRST-VBL DET Compare Next - YES prst-dbg=0x3FF > prst-fls=39
PRST-VBL API Get - ok returning "prst-fls=39" of size 12
PRST-VBL API Get (prst-fls=39,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO prst-fls=39 <= NTPv4_Drift=0.6CB83
PRST-VBL DET Compare Next - NO prst-fls=39 <= ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - NO prst-fls=39 <= prst-dbg=0x3FF
PRST-VBL DET Compare Next - NO prst-fls=39 <= prst-fls=39
PRST-VBL DET Compare Next - YES prst-fls=39 > prst-ver=1
PRST-VBL DET Compare Next - NO prst-ver=1 <= NTPv4_Drift=0.6CB83
PRST-VBL DET Compare Next - NO prst-ver=1 <= prst-fls=39
PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= NTPv4_Drift=0.6CB83
PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= prst-fls=39
PRST-VBL DET Compare Next - YES rf_cold_starts=0 > rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
PRST-VBL API Get - ok returning "rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason" of size 63
PRST-VBL API Get (rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason <= NTPv4_Drift=0.6CB83
PRST-VBL DET Compare Next - NO rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason <= ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - NO rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason <= prst-dbg=0x3FF
PRST-VBL DET Compare Next - NO rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason <= prst-fls=39
PRST-VBL DET Compare Next - NO rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason <= prst-ver=1
PRST-VBL DET Compare Next - NO rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason <= rf_cold_starts=0
PRST-VBL DET Compare Next - NO rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason <= rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - YES rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason > rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= NTPv4_Drift=0.6CB83
PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= prst-fls=39
PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= NTPv4_Drift=0.6CB83
PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= prst-fls=39
PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= NTPv4_Drift=0.6CB83
PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= prst-fls=39
PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= NTPv4_Drift=0.6CB83
PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= prst-fls=39
PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - YES rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason > rf_reload_data_index=1
PRST-VBL API Get - ok returning "rf_reload_data_index=1" of size 23
PRST-VBL API Get (rf_reload_data_index=1,13148D08,280,0xC-NMVL-?)
PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= NTPv4_Drift=0.6CB83
PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= ReloadReason=12ab34Reload Command
PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= prst-dbg=0x3FF
PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= prst-fls=39
PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= prst-ver=1
PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= rf_cold_starts=0
PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason
PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= rf_reload_data_index=1
PRST-VBL API Get - rf_reload_data_index=1 missing in the prst cache
PRST-VBL API Get (rf-debug,1427B7B0,64,0x0-DEFAULT)
PRST-VBL API Get (snmpboots,1427B868,11,0x0-DEFAULT)
[email protected].
PRST-VBL API Get (CTS_STARTUP_DEBUG_FILENAME,1427B344,693,0x0-DEFAULT)
PRST-VBL API Get (CTS_STARTUP_TEST_FILENAME,1427B5FC,693,0x0-DEFAULT)
cellwan_cwmp_init
PRST-VBL API Get (ReloadReason,1427B7C8,281,0x0-DEFAULT)
1 DSL controller
1 ATM interface
3 terminal lines
PRST-VBL API Get (NTPv4_Drift,1427A7C4,31,0x0-DEFAULT)
PRST-VBL API Get - ok returning "0.6CB83" of size 8
*Jan 2 00:00:05.031: PRST-VBL DET Compare Next - YES > NTPv4_Drift=0.6CB83
*Jan 2 00:00:05.047: PRST-VBL API Get - ok returning "NTPv4_Drift=0.6CB83" of size 20
*Jan 2 00:00:05.059: PRST-VBL API Get (NTPv4_Drift=0.6CB83,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:05.079: PRST-VBL DET Compare Next - NO NTPv4_Drift=0.6CB83 <= NTPv4_Drift=0.6CB83
*Jan 2 00:00:05.095: PRST-VBL DET Compare Next - YES NTPv4_Drift=0.6CB83 > ReloadReason=12ab34Reload Command
*Jan 2 00:00:05.167: PRST-VBL DET Compare Next - NO ReloadReason=12ab34Reload Command <= NTPv4_Drift=0.6CB83
*Jan 2 00:00:05.247: PRST-VBL DET Compare Next - NO prst-dbg=0x3FF <= NTPv4_Drift=0.6CB83
*Jan 2 00:00:05.287: PRST-VBL DET Compare Next - YES prst-dbg=0x3FF > prst-fls=39
*Jan 2 00:00:05.307: PRST-VBL API Get - ok returning "prst-fls=39" of size 12
*Jan 2 00:00:05.315: PRST-VBL API Get (prst-fls=39,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:05.335: PRST-VBL DET Compare Next - NO prst-fls=39 <= NTPv4_Drift=0.6CB83
*Jan 2 00:00:05.351: PRST-VBL DET Compare Next - NO prst-fls=39 <= ReloadReason=12ab34Reload Command
*Jan 2 00:00:05.363: PRST-VBL DET Compare Next - NO prst-fls=39 <= prst-dbg=0x3FF
*Jan 2 00:00:05.371: PRST-VBL DET Compare Next - NO prst-fls=39 <= prst-fls=39
*Jan 2 00:00:05.383: PRST-VBL DET Compare Next - YES prst-fls=39 > prst-ver=1
*Jan 2 00:00:05.427: PRST-VBL DET Compare Next - NO prst-ver=1 <= NTPv4_Drift=0.6CB83
*Jan 2 00:00:05.467: PRST-VBL DET Compare Next - NO prst-ver=1 <= prst-fls=39
*Jan 2 00:00:05.539: PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= NTPv4_Drift=0.6CB83
*Jan 2 00:00:05.579: PRST-VBL DET Compare Next - NO rf_cold_starts=0 <= prst-fls=39
*Jan 2 00:00:05.627: PRST-VBL DET Compare Next - YES rf_cold_starts=0 > rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
*Jan 2 00:00:05.655: PRST-VBL API Get - ok returning "rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason" of size 63
*Jan 2 00:00:05.675: PRST-VBL API Get (rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:05.699: PRST-VBL DET Compare Next - NO rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason <= NTPv4_Drift=0.6CB83
*Jan 2 00:00:05.727: PRST-VBL DET Compare Next - NO rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason <= ReloadReason=12ab34Reload Command
*Jan 2 00:00:05.747: PRST-VBL DET Compare Next - NO rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason <= prst-dbg=0x3FF
*Jan 2 00:00:05.767: PRST-VBL DET Compare Next - NO rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason <= prst-fls=39
*Jan 2 00:00:05.791: PRST-VBL DET Compare Next - NO rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason <= prst-ver=1
*Jan 2 00:00:05.811: PRST-VBL DET Compare Next - NO rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason <= rf_cold_starts=0
*Jan 2 00:00:05.843: PRST-VBL DET Compare Next - NO rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason <= rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
*Jan 2 00:00:05.871: PRST-VBL DET Compare Next - YES rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason > rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
*Jan 2 00:00:05.947: PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= NTPv4_Drift=0.6CB83
*Jan 2 00:00:06.015: PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= prst-fls=39
*Jan 2 00:00:06.087: PRST-VBL DET Compare Next - NO rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason <= rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
*Jan 2 00:00:06.223: PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= NTPv4_Drift=0.6CB83
*Jan 2 00:00:06.291: PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= prst-fls=39
*Jan 2 00:00:06.367: PRST-VBL DET Compare Next - NO rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason <= rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
*Jan 2 00:00:06.531: PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= NTPv4_Drift=0.6CB83
*Jan 2 00:00:06.599: PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= prst-fls=39
*Jan 2 00:00:06.675: PRST-VBL DET Compare Next - NO rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason <= rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
*Jan 2 00:00:06.871: PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= NTPv4_Drift=0.6CB83
*Jan 2 00:00:06.939: PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= prst-fls=39
*Jan 2 00:00:07.011: PRST-VBL DET Compare Next - NO rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason <= rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
*Jan 2 00:00:07.159: PRST-VBL DET Compare Next - YES rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason > rf_reload_data_index=1
*Jan 2 00:00:07.179: PRST-VBL API Get - ok returning "rf_reload_data_index=1" of size 23
*Jan 2 00:00:07.191: PRST-VBL API Get (rf_reload_data_index=1,13148D08,280,0xC-NMVL-?)
*Jan 2 00:00:07.211: PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= NTPv4_Drift=0.6CB83
*Jan 2 00:00:07.227: PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= ReloadReason=12ab34Reload Command
*Jan 2 00:00:07.243: PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= prst-dbg=0x3FF
*Jan 2 00:00:07.255: PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= prst-fls=39
*Jan 2 00:00:07.267: PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= prst-ver=1
*Jan 2 00:00:07.283: PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= rf_cold_starts=0
*Jan 2 00:00:07.307: PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= rf_reload_data0=08-30-19 09:19:05 Unknown User: Unknown Reason
*Jan 2 00:00:07.327: PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= rf_reload_data1=08-04-19 22:19:19 Unknown User: Unknown Reason
*Jan 2 00:00:07.351: PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= rf_reload_data2=08-16-19 09:45:46 Unknown User: Unknown Reason
*Jan 2 00:00:07.375: PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= rf_reload_data3=08-23-19 08:33:44 Unknown User: Unknown Reason
*Jan 2 00:00:07.399: PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= rf_reload_data4=08-26-19 20:27:44 Unknown User: Unknown Reason
*Jan 2 00:00:07.415: PRST-VBL DET Compare Next - NO rf_reload_data_index=1 <= rf_reload_data_index=1
*Jan 2 00:00:07.431: PRST-VBL API Get - rf_reload_data_index=1 missing in the prst cache
*Jan 2 00:00:07.443: PRST-VBL API Get (rf-debug,1427B7B0,64,0x0-DEFAULT)
*Aug 30 09:21:48.011: PRST-VBL MED Init complete - filesys added: buffer_named
*Aug 30 09:21:48.019: PRST-VBL MED Init complete - filesys added: tmpsys
*Aug 30 09:21:48.615: PRST-VBL STD Process - starting
*Aug 30 09:21:48.623: PRST-VBL STD Process - waiting on system init
*Aug 30 09:21:51.703: c3600_scp_set_dstaddr2_idb(185)add = 80 name is Embedded-Service-Engine0/0
*Aug 30 09:21:52.899: PRST-VBL MED Init complete - filesys added: null
*Aug 30 09:21:52.907: PRST-VBL MED Init complete - filesys added: tftp
*Aug 30 09:21:52.923: PRST-VBL MED Init complete - filesys added: flash0
*Aug 30 09:21:52.943: PRST-VBL MED Init complete - filesys added: flash1
*Aug 30 09:21:53.023: PRST-VBL MED Init complete - filesys added: hidden-nvram
*Aug 30 09:21:53.035: PRST-VBL MED Init complete - filesys added: nvram
*Aug 30 09:21:53.043: PRST-VBL MED Init complete - filesys added: syslog
*Aug 30 09:22:18.215: c3600_scp_set_dstaddr2_idb(185)add = 2 name is GigabitEthernet2/0
*Aug 30 09:22:18.279: PRST-VBL MED Init complete - filesys added: flash
*Aug 30 09:22:19.139: PRST-VBL MED Init complete - filesys added: xmodem
*Aug 30 09:22:19.147: PRST-VBL MED Init complete - filesys added: ymodem
*Aug 30 09:22:19.187: PRST-VBL MED Init complete - filesys added: rcp
*Aug 30 09:22:19.451: PRST-VBL API Get (snmpboots,1427B868,11,0x0-DEFAULT)
*Aug 30 09:22:19.455: PRST-VBL DET Lock - ok
*Aug 30 09:22:19.459: PRST-VBL DET Cache unlock - ok
*Aug 30 09:22:19.471: PRST-VBL API Get - snmpboots missing in the prst cache
*Aug 30 09:22:19.487: PRST-VBL MED Init complete - filesys added: http
*Aug 30 09:22:20.319: PRST-VBL MED Init complete - filesys added: ftp
*Aug 30 09:22:20.415: PRST-VBL MED Init complete - filesys added: scp
*Aug 30 09:22:20.491: PRST-VBL MED Init complete - filesys added: tar
*Aug 30 09:22:20.835: PRST-VBL MED Init complete - filesys added: https
*Aug 30 09:22:21.223: PRST-VBL MED Init complete - filesys added: cns
*Aug 30 09:22:22.747: PRST-VBL API Get (CTS_STARTUP_DEBUG_FILENAME,1427B344,693,0x0-DEFAULT)
*Aug 30 09:22:22.751: PRST-VBL DET Lock - ok
*Aug 30 09:22:22.759: PRST-VBL DET Cache unlock - ok
*Aug 30 09:22:22.771: PRST-VBL API Get - CTS_STARTUP_DEBUG_FILENAME missing in the prst cache
*Aug 30 09:22:22.787: PRST-VBL API Get (CTS_STARTUP_TEST_FILENAME,1427B5FC,693,0x0-DEFAULT)
*Aug 30 09:22:22.791: PRST-VBL DET Lock - ok
*Aug 30 09:22:22.795: PRST-VBL DET Cache unlock - ok
*Aug 30 09:22:22.811: PRST-VBL API Get - CTS_STARTUP_TEST_FILENAME missing in the prst cache
*Aug 30 09:22:22.859: PRST-VBL API Get (ReloadReason,1427B7C8,281,0x0-DEFAULT)
*Aug 30 09:22:22.863: PRST-VBL DET Lock - ok
*Aug 30 09:22:22.871: PRST-VBL DET Cache unlock - ok
*Aug 30 09:22:22.883: PRST-VBL API Get - ok returning "12ab34Reload Command" of size 21
*Aug 30 09:22:23.155: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
*Aug 30 09:22:23.155: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Aug 30 09:22:23.155: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to up
*Aug 30 09:22:23.247: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0/0, changed state to down
*Aug 30 09:22:23.247: %LINK-3-UPDOWN: Interface GigabitEthernet2/0, changed state to up
*Aug 30 09:22:23.815: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Aug 30 09:22:24.155: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Aug 30 09:22:24.155: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Aug 30 09:22:24.155: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to up
*Aug 30 09:22:24.247: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0, changed state to up
*Aug 30 09:22:24.715: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level informational, xml disabled, filtering disabled, size (51200)
*Aug 30 09:22:24.719: %SYS-6-CLOCKUPDATE: System clock has been updated from 09:22:24 UTC Fri Aug 30 2019 to 09:22:24 GMT Fri Aug 30 2019, configured from console by vty0.
*Aug 30 09:22:25.219: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
*Aug 30 09:22:25.219: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
*Aug 30 09:22:25.515:
Note: A random mac address of 0000.0cec.b834
*Aug 30 09:22:25.519:
Note: A random mac address of 0000.0cec.b838
*Aug 30 09:22:25.571:
Note: A random Spanning Tree Bridge Identifier address of 0000.0c67.b86c
*Aug 30 09:22:25.575:
Note: A random Spanning Tree Bridge Identifier address of 0000.0c67.b870
*Aug 30 09:22:25.607: PRST-VBL API Get (NTPv4_Drift,1427A7C4,31,0x0-DEFAULT)
*Aug 30 09:22:25.611: PRST-VBL DET Lock - ok
*Aug 30 09:22:25.619: PRST-VBL DET Cache unlock - ok
*Aug 30 09:22:25.627: PRST-VBL API Get - ok returning "0.6CB83" of size 8
*Aug 30 09:22:25.631: %SYS-5-CONFIG_I: Configured from memory by console
*Aug 30 09:22:25.795: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
*Aug 30 09:22:26.039: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.7(3)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Wed 01-Aug-18 22:52 by prod_rel_team
*Aug 30 09:22:26.051: %SYS-6-BOOTTIME: Time taken to reboot after reload = 203 seconds
*Aug 30 09:22:26.051: PRST-VBL API Set (ReloadReason=12ab34Unknown reason,0x0-DEFAULT)
*Aug 30 09:22:26.051: PRST-VBL DET Lock - ok
*Aug 30 09:22:26.051: PRST-VBL DET - Util Set - nameval=ReloadReason=12ab34Unknown reason and node->nameval=ReloadReason=12ab34Reload Command.
*Aug 30 09:22:26.051: PRST-VBL STD Util Set - straight copy of ReloadReason=12ab34Unknown reason
*Aug 30 09:22:26.051: PRST-VBL STD Flush condition - delayed until process running
*Aug 30 09:22:26.051: PRST-VBL DET Cache unlock - ok
*Aug 30 09:22:26.051: PRST-VBL API Set - ok return 33
*Aug 30 09:22:26.055: PRST-VBL API Get (sum_new_imgname,12E81C48,693,0x0-DEFAULT)
*Aug 30 09:22:26.055: PRST-VBL DET Lock - ok
*Aug 30 09:22:26.055: PRST-VBL DET Cache unlock - ok
*Aug 30 09:22:26.055: PRST-VBL API Get - sum_new_imgname missing in the prst cache
*Aug 30 09:22:26.055: PRST-VBL STD Process - running and timer started
*Aug 30 09:22:26.063: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Aug 30 09:22:26.163: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
*Aug 30 09:22:26.163: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Aug 30 09:22:26.223: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Aug 30 09:22:26.223: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
*Aug 30 09:22:26.327: %ETHSW_SM-3-ILP_RECOVERY_COMPLETE: Time taken for recovery after reload = 0 seconds.
*Aug 30 09:22:26.475: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan10, changed state to down
*Aug 30 09:22:26.479: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan20, changed state to down
*Aug 30 09:22:26.483: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan30, changed state to down
*Aug 30 09:22:26.507: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Aug 30 09:22:26.511: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI10, changed state to up
*Aug 30 09:22:26.515: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI20, changed state to up
*Aug 30 09:22:26.519: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI30, changed state to up
*Aug 30 09:22:26.759: %LINK-5-CHANGED: Interface Embedded-Service-Engine0/0, changed state to administratively down
*Aug 30 09:22:30.472: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Aug 30 09:22:30.472: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to up
*Aug 30 09:22:31.056: PRST-VBL STD Process - flushing
*Aug 30 09:22:31.056: PRST-VBL DET Lock - ok
*Aug 30 09:22:31.056: PRST-VBL DET - Util Set - nameval=prst-fls=40 and node->nameval=prst-fls=39.
*Aug 30 09:22:31.056: PRST-VBL STD Util Set - straight copy of prst-fls=40
*Aug 30 09:22:31.056: PRST-VBL MED Open Write - opening nvram:persistent-data
*Aug 30 09:22:31.056: PRST-VBL MED Open Write - got buf of size 2048 in 0 ms
*Aug 30 09:22:31.056: PRST-VBL MDET Write - NTPv4_Drift=0.6CB83
*Aug 30 09:22:31.056: PRST-VBL DET Write Nameval - ok put of NTPv4_Drift=0.6CB83
*Aug 30 09:22:31.056: PRST-VBL MDET Write - ReloadReason=12ab34Unknown reason
*Aug 30 09:22:31.056: PRST-VBL DET Write Nameval - ok put of ReloadReason=12ab34Unknown reason
*Aug 30 09:22:31.056: PRST-VBL MDET Write - prst-dbg=0x3FF
*Aug 30 09:22:31.056: PRST-VBL DET Write Nameval - ok put of prst-dbg=0x3FF
*Aug 30 09:22:31.056: PRST-VBL MDET Write - prst-fls=40
*Aug 30 09:22:31.056: PRST-VBL DET Write Nameval - ok put of prst-fls=40
*Aug 30 09:22:31.056: PRST-VBL MDET Write - prst-ver=1
*Aug 30 09:22:31.056: PRST-VBL DET Write Nameval - ok put of prst-ver=1
*Aug 30 09:22:31.056: PRST-VBL MDET Write - rf_cold_starts=0
*Aug 30 09:22:31.056: PRST-VBL DET Write Nameval - ok put of rf_cold_starts=0
*Aug 30 09:22:33.100: PRST-VBL MED Close Write - wrote table size 448 in 2044 ms
*Aug 30 09:22:33.100: PRST-VBL STD Flush to media - ok
*Aug 30 09:23:10.400: %CELLWAN-2-MODEM_UP: Modem in HWIC slot 0/3 is now UP
*Aug 30 09:23:32.486: %CONTROLLER-5-UPDOWN: Controller VDSL 0/0/0, changed state to up
*Aug 30 09:23:33.486: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0/0, changed state to up
*Aug 30 09:23:52.932: %CELLWAN-2-MODEM_RADIO: Cellular0/3/0 Modem radio has been turned onCCCC
bifrost-cisco2951>
bifrost-cisco2951>
*Aug 30 09:24:01.937: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Aug 30 09:24:01.941: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Aug 30 09:24:02.057: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
bifrost-cisco2951>sh buf
Buffer elements:
625 in free list
2645 hits, 0 misses, 1242 created
Small buffers, 104 bytes (total 95, permanent 50, peak 95 @ 00:03:08):
91 in free list (20 min, 150 max allowed)
1053 hits, 15 misses, 0 trims, 45 created
Middle buffers, 600 bytes (total 229, permanent 100, peak 229 @ 00:03:08):
229 in free list (150 min, 300 max allowed)
589 hits, 18 misses, 0 trims, 129 created
Big buffers, 1536 bytes (total 51, permanent 50, peak 51 @ 00:03:14):
51 in free list (5 min, 150 max allowed)
125 hits, 0 misses, 0 trims, 1 created
VeryBig buffers, 4520 bytes (total 11, permanent 10, peak 11 @ 00:03:14):
11 in free list (0 min, 100 max allowed)
0 hits, 0 misses, 0 trims, 1 created
Large buffers, 5024 bytes (total 1, permanent 0, peak 1 @ 00:03:54):
Huge buffers, 18024 bytes (total 5, permanent 0, peak 5 @ 00:03:14):
0 hits, 0 misses, 0 trims, 5 created
CF Small buffers, 104 bytes (total 101, permanent 100, peak 101 @ 00:03:46):
Generic ED Pool buffers, 512 bytes (total 101, permanent 100, peak 101 @ 00:03:11):
0 hits, 0 misses
CF Middle buffers, 600 bytes (total 101, permanent 100, peak 101 @ 00:03:46):
Syslog ED Pool buffers, 600 bytes (total 133, permanent 132, peak 133 @ 00:03:11):
117 hits, 0 misses
CF Big buffers, 1536 bytes (total 26, permanent 25, peak 26 @ 00:03:46):
pak coalesce engine buffers, 1536 bytes (total 512, permanent 256, peak 512 @ 00:03:42):
1209 hits in cache, 0 misses in cache
320 hits, 0 misses
300 hits in cache, 0 misses in cache
CF VeryBig buffers, 4520 bytes (total 3, permanent 2, peak 3 @ 00:03:46):
CF Large buffers, 5024 bytes (total 2, permanent 1, peak 2 @ 00:03:46):
IPC Large buffers, 65535 bytes (total 17, permanent 16, peak 17 @ 00:03:50):
0 hits, 0 misses, 3 trims, 4 created
Header pools:
Particle Clones:
1024 clones, 245 hits, 0 misses
245 hits in cache, 0 misses in cache
960 hits, 0 misses, 0 trims, 0 created
1762 hits in cache, 0 misses in cache
128 hits, 64 fallbacks
16481 hits in cache, 0 misses in cache
1248 hits in cache, 0 misses in cache
13801 hits in cache, 0 misses in cache
bifrost-cisco2951>
you still have small and middle buffer misses. Increase the values as indicated below:
2951(config)#buffers small permanent 250
2951(config)#buffers small initial 150
2951(config)#buffers small min-free 300
2951(config)#buffers small max-free 600
2951(config)#buffers middle permanent 250
2951(config)#buffers middle initial 150
2951(config)#buffers middle min-free 300
2951(config)#buffers middle max-free 600
thanks again.
dave
