Third WAN
Oscar Barrera
Community Member
Hi felow companions.
Can I enable a third wan port on a MX 250?
HEEELP!
6 Replies 6
MerakiGnome
Meraki Community All-Star
Hi @Oscar Barrera
This isn’t possible. You can only have two active WAN ports. The third would be a GSM/cellular failover option.
Darren OConnor
https://www.linkedin.com/in/darrenoconnor
And Meraki support can enable it fron the backend?
The new MX75 has hardware support for 3 WAN interfaces and the MX85, MX95 and MX105 have hardware support for 4 WAN interfaces. Software support for more than two WAN interfaces on these models is not expected until MX 18 firmware. Considering that MX 17 firmware only became available in Public Beta two days ago, it's going to be a while before this feature is supported.
I don't know if the MX250 and MX450 even have the hardware to support more than two WAN interfaces.
MerakiGnome
Both models don’t support a third WAN and this isn’t available on the newer models currently
Darren OConnor
@Oscar Barrera : Corrected said by @DarrenOC . Only 2 WANs !
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
Techie2000
This is now possible through the MultiWAN backup feature implemented in firmware build 18.2 and higher.
Documentation: https://documentation.meraki.com/MX/MultiWAN_Backup_Uplink
