unnumbered interface bahaviour
daniel ng
in IOS XE, when you configure an unnumbered interface to borrow address from another interface other than loopback, it will not show up in RIB thus is not able to return the traffic. a static route needs to be configured to point to the unnumbered interface as egress.
however, in IOS XR, no static route is needed despite the unnumbered interface does not show up in RIB and FIB.
in Junos, it also does not show up in RIB but does in FIB.
what is the difference between them that causes such behaviour?
24 Replies 24
Hi @Cristian Matei ,
No need to go in the specifics of RFC6724. This would only create more confusion.
I think I have already made it clear how "ipv6 unnumbered" overrides the SAS in the following way:
If the "ipv6 unnumbered" is configured, the SAS prefers the ipv6 address of the interface specified on that command (If considered valid by the SAS process).
If the "ipv6 unnumbered" is not configured, the SAS considers the ipv6 addresses from all the interfaces on the local node and picks the one it considers to be the best (refer to RFC6724 for the details of the selection process)
example without ipv6 unnumbered:
int lo0
ipv6 address 2001:db8:12ff::2/128
int gi1
ipv6 address 2001:db8:12ff:12::2/64
it gi2
ipv6 address fe80::2 link-local
Traffic to 2001:db8:12ff::3 going through interface gi2 will use source address 2001:db8:12ff::2
example with ipv6 unnumbered:
int lo0
int gi1
int gi2
ipv6 unnumbered gi1
Traffic to 2001:db8:12ff::3 going through interface gi2 will use source address 2001:db8:12ff:12::2
This is just a simple demonstration of how the "ipv6 unnumbered" overrides the SAS process.
@Harold Ritter Appreciate the details, it is clear now. The IPv6 unnumbered (which, my wrong opinion, I don't see why you would ever use that, but moving on), overrides / influences the SAS process as outlined in RFC6724. At the same time, there's no mention of IPv6 unnumbered in RFC6724, which is where my confusion was.
Cristian.
I agree that this command is not as useful for ipv6 as it it for ipv4.
I understand the confusion. It is not something RFC6724 mentions, but more of a implementation knob to influence the SAS outcome.
Hi @daniel ng ,
Let me start by saying that the meaning of "unnumbered interfaces" can be a little bit different in the ipv6 context. With IPv6, It is common to deploy core networks without configuring GUA or ULA on the interfaces connecting the different nodes. These interfaces are sometimes referred to as unnumbered interfaces, although they are not really as they at least need a link local address (LLA) to be functioning as ipv6 interfaces.
in my test, there was only the one address in the unnumbered interface.
Bear in mind that the source address selection (SAS) works at the node level, not at the interface level. In your scenario, you have at least the ipv6 LLA on the interface where you configured the "ipv6 unnumbered" command and the non LLA address (either GUA or ULA) on the other interface.
If you ping a GUA address sitting on the other side of the unnumbered interface from the local node, the SAS behave in one of the following ways.
If the "ipv6 unnumbered" is configured, the SAS prefers the ipv6 address of the interface specified on that command.
 > so in other words, it is normal behaviour that no address is borrowed?
I am not to clear on what you mean by borrowed other than the concept of the ipv6 address of another interface being used as the source address for packets originated by the local node and going through the unnumbered interface.
> ps: retested on Junos version 21.4 or later where it can borrow GUA while generates its own LLA.
The JunOS implementation can be different or it might be another feature. Can you please refer to the link of the feature you are using on JunOS.
One last point, can you please explain in more details what it is that you are trying to achieve. It will definitely help the community to suggest an appropriate solution.
very information illustration from Harold.
so 'ipv6 unnumbered' serves merely as SAS override rather than address borrowing.
although i'm not too sure what use cases this override serves other than things like fixing the source address for netflow etc.
the only official document i could find from Juniper on unnumbered interface is:
https://www.juniper.net/documentation/us/en/software/junos/interfaces-fundamentals/topics/topic-map/protocol-family-interface-address-properties.html#id-configuring-an-unnumbered-interface
from what it says and what i found, unnumbered seems to work the same for IPv4 and 6.
what i was trying to do was to make use of part of the lender interface's segment without modifying the config wherefrom.
that works fine on IPv4 with the help of static route pointing to the unnumbered interface as egress. then i found IPv6 to be the special kid in the class.
it could be achieved by bridging but that would require modifying the lender interface.
Hi @daniel ng ,
Correct.
Well, I am not too sure what would be a good use case for this, but I am sure someone will. The regular SAS process is generally sufficient
Can you please explain the details of the ipv4 solution, so we might see if it is possible with ipv6 as well.
i needed to use several new addresses in an existing segment that was currently configured in a router's interface, however i didn't have logical or physical access to the switch that connects to this interface, or any other devices in the environment.
since provisioning a new segment needs to go through bureaucratic change management and the people who manage this environment have a fetish on static routes, i came up with the idea to make use of the unnumbered interface so as not having to modify the aforementioned interface which carries live traffic.
it simply works by using 'ip unnumbered' to borrow the IPv4 address from the lender interface plus configuring corresponding static routes pointing to the unnumbered interface as egress with the new addresses as destination. with the destination prefix longer than the lender interface, the traffic will be directed to the unnumbered interface accordingly.
the static route is only needed in IOS XE since unnumbered interface does not appear in RIB as discussed earlier. IOS XR and Junos both don't need it despite its absence in RIB and/or FIB.
this is relatively a niche use case stemmed entirely from environmental constraints.
Hi @daniel ng ,
Thanks for the detailed information. It is a pretty unusual, but clever way to use the unnumbered interface.
I ran a quick test with IOS-XE and it appears that the interface configured for "ipv6 unnumbered" does not respond to the neighbor sollicitation (NS) coming from the device connected to that same interface. I got it to work by adding a static neighbor entry (see example below) on the host and it works like a charm.
You can always talk to your Cisco account team to request the behavior to be changed to match the one you see with ipv4, but I doubt that they would implement it given the corner case nature of your use case. Consider the following to be a workaround and not a permanent solution
Static ipv6 neighbor configuration on the host connected to the unnumbered interface:
ipv6 neighbor <unnumbered interface address> GigabitEthernet1 xxxx.xxxx.xxxx
Note that I used another IOS-XE device as the host for testing purposes.
hi
i understand topic is quite aged. but just for better clarity ~unnumbered IPv4 on IOS-XE - it works w/ isis w/o any static routes.
LEAF2#sho run | sec 1/0/[12]
interface GigabitEthernet1/0/1
no switchport
ip unnumbered Loopback0
ip router isis
interface GigabitEthernet1/0/2
no switchport
ip router isis
LEAF2#sho ip route | be Gate
Gateway of last resort is not set
100.0.0.0/32 is subnetted, 4 subnets
i L2 100.64.0.0 [115/20] via 100.64.0.0, 00:07:35, GigabitEthernet1/0/2
i L2 100.64.0.1 [115/20] via 100.64.0.1, 00:07:35, GigabitEthernet1/0/1
i L2 100.64.0.2 [115/30] via 100.64.0.1, 00:07:29, GigabitEthernet1/0/1
[115/30] via 100.64.0.0, 00:07:29, GigabitEthernet1/0/2
C 100.64.0.3 is directly connected, Loopback0
LEAF2#sho ip inter brie | e unas
GigabitEthernet0/0 10.10.20.178 YES NVRAM up up
GigabitEthernet1/0/1 100.64.0.3 YES unset up up
GigabitEthernet1/0/2 100.64.0.3 YES unset up up
Loopback0 100.64.0.3 YES manual up up
LEAF2#ping 100.64.0.2
Sending 5, 100-byte ICMP Echos to 100.64.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 68/80/93 ms
LEAF2#
good discussion guys - enjoyed the read!
Kind Regards
Paul
