Use Network Default
Jmccandles
Community Member
What does " Use Network Default " refer to while configuring group policy.
Brash
Meraki Community All-Star
Use Network Default means that it will use the settings configured in the VLAN, SSID or security appliance policies rather than overriding them.
Brash
Jmccandles
Community Member
Thank you Brash.
ww^
Then it keeps using the configuration settings from your global network config.
For example if the GP has Bandwidth set to " Use Network Default "
It will use the setting of
sdwan& Traffic shaping > Global bandwidth limits
Per-client limit.
