waas inline problem
draganskundric
Level 2
Level 2
I cannot get inline adapter to work, on wae-512. lan port of inline groups is admin down
was#sh int inlineport 1/0/lan
Device name        : eth5. Bypass slave interface.
Packets Received   : 0
Packets Intercepted: 0
Packets Bridged    : 0
Packets Forwarded  : 0
Packets Dropped    : 0
Packets Received on native      : 0
Active flows for this interface : 0
Ethernet Driver Status
Type:Ethernet
Ethernet address:00:E0:ED:10:D0:B7
Maximum Transfer Unit Size:1500
Metric:1
Packets Received: 0
Input Errors: 0
Input Packets Dropped: 0
Input Packets Overruns: 0
Input Packets Frames: 0
Packet Sent: 0
Output Errors: 0
Output Packets Dropped: 0
Output Packets Overruns: 0
Output Packets Carrier: 0
Output Queue Length:1000
Collisions: 0
Base address:0x40c0
Flags:BROADCAST MULTICAST
Link State: Interface is administratively down, line protocol down
Mode: autoselect
was#
johutchins
Level 5
Level 5
I have this same problem... where you able to solve this issue?  My interface is on a trunked interface.
you must have connected and alive both ports in grou
p, wan and lan. In my case error was that I connected only wan port.
bye
