1721 router supports ip flow-export commnad
jitendra.kansal
Hi, We have to configure ip flow-export commands(Mentioned below) on 1721 platform. current DRAM/Flash is 32/16
Please let me know-
1- is these commands are supported on 1721 platform?
2- if it is, please suggest suitable IOS with feature set.
3- do we need to uprade DRAM/Flash for the same?
ip flow-export source <interface>
ip flow-export version 5
ip flow-export destination <IP address> <port>
thanks in advance---JEET
Richard Burts
Jeet
I have looked in the Feature Navigator on the Cisco web site and find that NetFlow is supported on the 1721 in an IOS image that requires only 32/8. There are several that fit your criteria and here is one of them:
c1700-y-mz.123-26.bin
which is the IP feature set of 12.3(26).
Rick
Rick
