1841 Cannot read EEprom
i have a 1841 Router that hang up @ boot.
Output:
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0xcdc3e0
Self decompressing the image : ############################################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ         TYPE
Unable to read eeprom
                0X000F3BB0 public buffer pools
                0X00211000 public particle pools
                0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 8295928 bytes to IO Memory.
PMem allocated: 120586240 bytes; IOMem allocated: 13631488 bytes
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.3(8)YG4, RELEASE SOFTWARE (fc1)
Synched to technology version 12.3(10.3)T2
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Thu 04-May-06 00:15 by ealyon
Image text-base: 0x60075904, data-base: 0x61380000
After i look @ the cookie
Output
Readonly ROMMON initialized
rommon 1 >      cookie
cookie:
04 ff 09 86 ff ff ff ff ff ff ff ff ff ff ff ff
4f 43 31 32 35 32 35 47 46 46 40 04 1b 41 07 00
82 49 1f ff 08 42 45 30 c0 46 03 20 00 5b 8a 06
88 00 00 00 00 02 04 c6 8a 49 50 4d 37 57 30 30
43 52 41 03 00 81 00 00 00 00 04 00 cb 89 43 49
53 43 4f 31 38 34 31 89 56 30 35 20 d9 02 c1 40
09 86 c2 8b 46 43 5a 31 33 30 36 39 31 38 54 ff
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
I thik the eeprom is killed but is there a way to restore it ?
Philipp
paolo bevilacqua
If there is, is not publicily disclosed. Buy a support contract and have the unit replaced.
