1841 interface routing
jordanmfarmer
I am trying to get traffic from fa0/1 to fa0/0 for my wan. I have a comcast modem attached to fa0/0 and then I have a cisco 3750 attached to fa0/1 with a couple PC's attached to it. Currently the switch can ping 10.10.10.1 (1841 router) and 10.0.0.135(comcast modem fa0/0 interface) however it can't ping 10.0.0.1(comcast modem)
1841r1#show running-config
Building configuration...
Current configuration : 1553 bytes
! Last configuration change at 04:58:43 UTC Mon Jul 2 2018
version 15.1
hostname 1841r1
boot-start-marker
boot-end-marker
enable secret 5 $1$hB1U$LV3y9.vgMLl.**bleep**nSOWMV/
no aaa new-model
dot11 syslog
ip source-route
ip dhcp pool default-pool
network 10.10.10.0 255.255.255.0
dns-server 8.8.8.8
default-router 10.10.10.1
ip cef
no ipv6 cef
license udi pid CISCO1841 sn FTX1036W2HR
redundancy
interface FastEthernet0/0
description comcast modem
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
description lan
ip address 10.10.10.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.0.0.1
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 101 permit ip 10.10.10.0 0.0.0.255 host 10.0.0.1
access-list 101 deny ip 10.10.10.0 0.0.0.255 10.0.0.0 0.0.0.255
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
control-plane
line con 0
exec-timeout 30 0
password admin
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 30 0
password admin
logging synchronous
login
transport input all
scheduler allocate 20000 1000
end
6 Replies 6
add the two lines marked in bold to your configuration:
version 15.1
hostname 1841r1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 10.10.10.1
dns-server 8.8.8.8
ip cef
no ipv6 cef
redundancy
ip address dhcp
ip nat outside
duplex auto
speed auto
description lan
ip nat inside
duplex auto
speed auto
no ip address
shutdown
no ip http server
ip nat inside source list 1 interface FastEthernet0/0 overload
control-plane
line con 0
exec-timeout 30 0
password admin
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 30 0
password admin
logging synchronous
login
transport input all
end
That fixed it, thank you!
May I ask what ip nat inside source list 1 interface FastEthernet0/0 overload
does?
basically, it tells the router which inside IP addresses (the ones specified in access list 1) are going to be translated (NATted) by the outside interface. Without that line, neither inside nor outside interface know what to NAT...
Does that make sense  ? You will see a similar line in every single NAT configuration...
That makes total sense, thanks for getting me all setup and taking the time to answer.
Good luck !
Georg,
With this setup how would I tell 10.10.10.5 to port forward port 3443 out the public interface?
