1841 Router IOS selection
arjun.e343
Dear All
On which IOS of 1841 router, i will get all the following features:
URL Filtering, Stateful Firewall and Inline Intrusion Preventoion system.
-Need exact IOS Part Code-
Arjun
As i said in my previous post, these features are supported in Advance security software or advance enterprise software.
Latest available code is
c1841-adventerprisek9-mz.12.4-13c.bin
c1841-advsecurityk9-mz.124-16.bin
you might have to look at the flash/Ram requirements though
HTH, rate if it does
Narayan
6 Replies 6
royalblues
Level 10
Level 10
Any latest advance enterprise image should support the above features
The firewall & IPS features are there in the enterprise image. i could not see the URL filtering feature set listed though. The latest one available is
use cisco feature navigator to know the features supported by a particular IOS
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Narayan
Hi Narayan
i could find URL filtering in the 1841 datasheet. But i cant find the Part code for that particulr IOS.
Arjun
Hi NArayan
i am looking these features for CISCO 1841 Router. Pl let me know the IOS/model to be selected for getting these features.
URL filtering, stateful firewall...
Arjun
Narayan
