1841 router ios upgrade from Version 12.4(1c) to c1841-ipbase-mz.151-4.M5?suggest the right memory for this?
vasanth77
hi here my router configuration with memory details,i need to upgrade to 15.1 but i uploaded the 15.1 os by using TFTP server but not upgraded.server returned error?
Router#show version
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(1c), RELEASE SO
FTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 25-Oct-05 17:10 by evmiller
ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
Router uptime is 0 minutes
System image file is "flash:c1841-ipbase-mz.124-1c.bin"
Cisco 1841 (revision 6.0) with 114688K/16384K bytes of memory.
Processor board ID FHK10411A72
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Router#show flash:
-#- --length-- -----date/time------ path
1     13937472 Oct 15 2006 06:32:34 +00:00 c1841-ipbase-mz.124-1c.bin
2         1821 Oct 15 2006 06:46:38 +00:00 sdmconfig-18xx.cfg
3      4734464 Oct 15 2006 06:47:28 +00:00 sdm.tar
4       833024 Oct 15 2006 06:48:00 +00:00 es.tar
5      1052160 Oct 15 2006 06:48:34 +00:00 common.tar
6         1038 Oct 15 2006 06:48:58 +00:00 home.shtml
7       102400 Oct 15 2006 06:49:24 +00:00 home.tar
8       491213 Oct 15 2006 06:49:50 +00:00 128MB.sdf
9      1684577 Oct 15 2006 06:50:30 +00:00 securedesktop-ios-3.1.1.27-k9.pkg
10      398305 Oct 15 2006 06:51:06 +00:00 sslclient-win-1.1.0.154.pkg
8679424 bytes available (23252992 bytes used)
Router#dir flash:
Directory of flash:/
    1  -rw-    13937472  Oct 15 2006 06:32:34 +00:00  c1841-ipbase-mz.124-1c.bin
    2  -rw-        1821  Oct 15 2006 06:46:38 +00:00  sdmconfig-18xx.cfg
    3  -rw-     4734464  Oct 15 2006 06:47:28 +00:00  sdm.tar
    4  -rw-      833024  Oct 15 2006 06:48:00 +00:00  es.tar
    5  -rw-     1052160  Oct 15 2006 06:48:34 +00:00  common.tar
    6  -rw-        1038  Oct 15 2006 06:48:58 +00:00  home.shtml
    7  -rw-      102400  Oct 15 2006 06:49:24 +00:00  home.tar
    8  -rw-      491213  Oct 15 2006 06:49:50 +00:00  128MB.sdf
    9  -rw-     1684577  Oct 15 2006 06:50:30 +00:00  securedesktop-ios-3.1.1.27
-k9.pkg
   10  -rw-      398305  Oct 15 2006 06:51:06 +00:00  sslclient-win-1.1.0.154.pk
g
31932416 bytes total (8679424 bytes free)
Router#dir nvram:
Directory of nvram:/
  190  -rw-         633                    <no date>  startup-config
  191  ----           5                    <no date>  private-config
  192  -rw-         633                    <no date>  underlying-config
    1  -rw-           0                    <no date>  ifIndex-table
    2  ----          12                    <no date>  persistent-data
196600 bytes total (193862 bytes free)
16 Replies 16
The Advanced IP Services image has even more features then the Advanced Security. So, yes, you can build VPNs with that image.
tiansiyu511
I can help you,You can email me, I'll give you send IOS  I mail (lyusiyu@163.com)
