1x DS3 and 1x FastEthernet Port
sorin721maria
What will be a cheap solution for that?
Thank'x!
olorunloba
Level 5
Level 5
It also depends on whether you want the full E3 or suvstrate. Check the following link
http://www.cisco.com/en/US/partner/products/hw/modules/ps2797/products_data_sheet09186a008010fba2.html
If you want full, NM-1T3/E3 sitting on the 3825 should be the cheapest. Can go for lower routers like the 2800 if you do not require full E3.
Thank you for your promt anser.
I will use 2 modules (NM-1T3/E3 and FastEthernet) together with a old 3640.
