2 ISP Link query
cisco.plus
Level 3
Level 3
HI
Out current infrastructure is simple
Layer3-switch....................Internet-Reuter..............ISP.modem
we got second ISP link which we terminate on another Router, how to send some trafic on ISP link 1 and some traffic on ISP link 2
Second router also connects to Layer3-switch
On L3 switch I have default route pointing to Router 1 only
thanks
CP
Pawan Sharma
Level 4
Level 4
There multiple ways to do it but I would recommend to keep it as simple as possible. You have two easy options to achieve this -
1. GLBP (Gateway Load Balancing Protocol - For more info on this Plz visit this link
2. PfR (Performance Routing) - Config of this one is bit tricky but this could be the best option to Load balance traffic on multiple WAN links. You can read more about this here
Please let me know if you need any configuration related assistance.
Pawan S
http://www.ebrahma.com
Pawan Sharma
https://itgears.io
Hi Pawan
so kind to reply.
we plan to route internet traffic on isp link 1 and data vpn traffic on isp link 2
on link 1 down all traffic goto isp link 2
donno if this doable automatically
You can achieve this with IP SLA for your VPN routes.
Pawan S
Pawan Sharma
https://itgears.io
Hi Pwan
PfR is owsom technology,thanks for ur link
thanks
jamil
