07-08-2008 05:36 AM - edited 03-03-2019 10:38 PM
Can anyone please point or direct me regarding installing a new IOS using tftp on Rommon mode. Also is this done using console cable or the crossover cable. I tried using xmodem, but it keeps giving me errors. Thanks in advance.
07-08-2008 05:37 AM
07-08-2008 06:21 AM
I keep getting the following error messages
ARP: address resolution for 10.1.1.1 timed out.
ARP failed with failure code 1. TFTP transfer aborted.
TFTP: Operation terminated prematurely.
not sure what the errors are.
07-08-2008 10:36 AM
what settings are you using?
I would guess
computer derectly connected via cross-over (or an auto sensing nic)
rommon 3 > set
PS1=rommon ! >
IP_ADDRESS=10.1.1.1
IP_SUBNET_MASK=255.255.255.0
DEFAULT_GATEWAY=10.1.1.2
TFTP_SERVER=10.1.1.2
then set your computer to 10.1.1.2/24
Rommon can be a little glitchy (from my experience) so since its in rommon I'd try to get it to just the router and my computer
07-08-2008 11:49 AM
I just fixed it a few moments before your message was sent. The method was exactly the same that you had suggested. thanks very much!!!
