2610 Router with Multilink Frame
tony.hanson
I have a 2610 with 48 flash, 16 ram and I'm trying to configure it for Multilink Frame and I'm having a problem determining the IOS I need for it to support it. When I go into the Interface mode I don't see MFR, I was wondering if anyone knew if it was supported on the 2610 router and if so what IOS could I use?
tdrais
Level 7
Level 7
You need 12.3 with ipplus. You first will need 64m ram 16m flash.
Then you will need a special version of ipplus. There are 2 version that have different features removed.
