2612 Router and h323 protocol
robertcook1
Hi I have a 2612 router and am trying to get my IP phones up and working, but i have ran into a issue. For some reason I cannot get the set protocol h.323 command to work. I have tried every IOS 12.3. The one i currently have on is the IP/h323 one.  Does anyone have an idea on how to get this protocol to work. or even make a custom protocol?
Current Version:
IOS (tm) C2600 Software (C2600-IS3X-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 15:23 by dchih
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
WNrouter uptime is 6 days, 55 minutes
System image file is "flash:2610.bin"
cisco 2612 (MPC860) processor (revision 0x102) with 61440K/4096K bytes of memory
Processor board ID JAB04130B5C (864598034)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Token Ring/IEEE 802.5 interface(s)
1 Serial network interface(s)
6 Low-speed serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Configuration register is 0x2142
**** conf
Using 7576 out of 29688 bytes
version 12.3
service password-encryption
hostname WNrouter
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no logging console
enable secret 5 $1$1/iD$seni/4XyulJzibvGqqSra.
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip domain name driveprestige.com
username Administrator privilege 15 secret 5 $1$LvF7$pJ1vJvXlIA4emgF0TNWQ61
username bcook privilege 15 password 7 101D5148171211535C
username admin privilege 15 password 7 02240B59091F5F77
class-map match-any SDMTrans-Serial1/3
  match protocol citrix
  match protocol finger
  match protocol notes
  match protocol novadigm
  match protocol pcanywhere
  match protocol secure-telnet
  match protocol sqlnet
  match protocol sqlserver
  match protocol ssh
  match protocol telnet
  match protocol xwindows
class-map match-any SDM-Transactional-2
  match  dscp af21
  match  dscp af22
  match  dscp af23
  match protocol ssh
class-map match-any SDM-Transactional-1
  match  dscp af21
  match  dscp af22
  match  dscp af23
  match protocol ssh
class-map match-any SDMScave-Ethernet0/0
  match protocol napster
  match protocol fasttrack
  match protocol gnutella
class-map match-any SDMVoice-Serial1/3
  match protocol rtp audio
class-map match-any SDMTrans-Ethernet0/0
  match protocol ssh
class-map match-any SDM-Routing-2
  match  dscp cs6
  match protocol bgp
  match protocol egp
  match protocol eigrp
  match protocol rip
  match protocol rsvp
class-map match-any SDM-Signaling-1
  match  dscp cs3
  match  dscp af31
class-map match-any SDM-Signaling-2
  match  dscp cs3
  match  dscp af31
class-map match-any SDM-Routing-1
  match  dscp cs6
  match protocol bgp
  match protocol egp
  match protocol rip
  match protocol rsvp
class-map match-any SDMScave-Serial1/3
class-map match-any SDM-Voice-1
  match  dscp ef
class-map match-any SDM-Voice-2
  match  dscp ef
class-map match-any SDMVoice-Ethernet0/0
class-map match-any SDMSignal-Serial1/3
class-map match-any SDMRout-Serial1/3
  match protocol bgp
  match protocol egp
  match protocol rip
  match protocol rsvp
class-map match-any SDMManage-Ethernet0/0
  match protocol dhcp
  match protocol dns
  match protocol imap
  match protocol kerberos
  match protocol ldap
  match protocol secure-imap
  match protocol secure-ldap
  match protocol snmp
  match protocol socks
  match protocol syslog
class-map match-any SDMBulk-Serial1/3
  match protocol exchange
  match protocol ftp
  match protocol irc
  match protocol nntp
  match protocol pop3
  match protocol printer
  match protocol secure-ftp
  match protocol secure-irc
  match protocol secure-nntp
  match protocol secure-pop3
  match protocol smtp
  match protocol tftp
class-map match-any SDMRout-Ethernet0/0
  match protocol bgp
  match protocol egp
  match protocol rip
  match protocol rsvp
class-map match-any SDMSignal-Ethernet0/0
class-map match-any SDM-Management-1
  match  dscp cs2
  match protocol dhcp
  match protocol dns
  match protocol imap
  match protocol ldap
  match protocol snmp
class-map match-any SDMBulk-Ethernet0/0
  match protocol ftp
  match protocol irc
  match protocol nntp
  match protocol pop3
  match protocol smtp
  match protocol tftp
class-map match-any SDM-Management-2
  match  dscp cs2
  match protocol dhcp
  match protocol dns
  match protocol imap
  match protocol ldap
  match protocol snmp
class-map match-any SDMManage-Serial1/3
  match protocol dhcp
  match protocol dns
  match protocol imap
  match protocol ldap
  match protocol snmp
class-map match-any SDMIVideo-Serial1/3
  match protocol rtp video
class-map match-any SDMSVideo-Ethernet0/0
  match protocol cuseeme
  match protocol netshow
  match protocol rtspplayer
  match protocol streamwork
  match protocol vdolive
class-map match-any SDMIVideo-Ethernet0/0
class-map match-any SDMSVideo-Serial1/3
policy-map SDM-Pol-Serial1/3
  class SDMTrans-Serial1/3
   bandwidth remaining percent 33
   set dscp af21
  class SDMSignal-Serial1/3
   bandwidth remaining percent 40
   set dscp cs3
  class SDMVoice-Serial1/3
   priority percent 70
   set dscp ef
  class SDMRout-Serial1/3
   set dscp cs6
  class SDMManage-Serial1/3
   set dscp cs2
policy-map SDM-QoS-Policy-2
  class class-default
   fair-queue
   random-detect
policy-map SDM-QoS-Policy-1
  class class-default
   fair-queue
   random-detect
policy-map SDM-Pol-Ethernet0/0
  class SDMVoice-Ethernet0/0
   priority percent 70
   set dscp ef
  class SDMRout-Ethernet0/0
   set dscp cs6
  class SDMTrans-Ethernet0/0
   set dscp af21
  class SDMSignal-Ethernet0/0
   set dscp cs3
interface Ethernet0/0
description LAN interface
ip address 10.127.236.254 255.255.255.0
ip nbar protocol-discovery
half-duplex
service-policy output SDM-Pol-Ethernet0/0
interface Serial0/0
no ip address
shutdown
interface TokenRing0/0
no ip address
shutdown
ring-speed 16
interface Serial0/1
no ip address
shutdown
interface Serial1/3
description <<Pt.to Pt.: To Lexus>>
ip address 1.1.1.34 255.255.255.252
encapsulation ppp
service-policy output SDM-Pol-Serial1/3
ip http server
ip http authentication local
ip classless
ip route 0.0.0.0 0.0.0.0 Serial1/3
ip route 10.127.234.0 255.255.255.0 10.127.234.242
gatekeeper
shutdown
line con 0
line aux 0
password 7 022B1149020303711B
line vty 0 4
login
end
WNrouter#
Jerry Ye
You are running IP/H323 Plus Basic on your 2600 with IOS 12.3, but in 12.4, that feature set doesn't exist. The minimum memory requirement for 12.4 H323 is 32MB flash and 128MB DRAM.
BTW, I don't think you can run 12.4 on the 2600, it only supports 2600XM.
jerry
