2620 question
jpvelaz764
I have a 2620 and I am trying to add a 2FW/2W card to add a couple WICS. When I boot the power light shows on the card but when IOS loads they do not show up in the running config.
Any suggestions?
scottmac
Level 10
Level 10
Check your version of IOS in the configuration matrix on the main Cisco site.
Usually when hardware is not discovered, it's either: 1) the hardware is not properly seated (reseat the modules and make sure the screws are tightened) or 2) the version of IOS does not support the hardware (hence: it can't identify it).
Good Luck
Scott
gary
NM-2FE2W is 100% compatilbe with Cisco2620 see http://www.cisco.com/warp/public/471/wics.html
Steven Mazabow
www.iptrading.com.au
You are wrong steven,
NM-2FE2W is NOT compatible with cisco2620. It clarely states it in the link you provided.Apart from that, i have personally tried it before.
femmy
