2800 Inventory on Modules
snarayanaraju
Level 4
Level 4
Hello - I am having 2821 Router. I am trying to find out the WAN Interface modules (WIC) installed in the Router. I am using commands "show version" and "show inventory"
"show version" gives output
1 Serial interface
2 Channelized T1/PRI ports
"show inventory" gives output
NAME: "Two port T1 voice interface daughtercard with Drop and Insert", DESCR: "Two port T1 voice interface daughtercard with Drop and Insert" PID: VWIC-2MFT-T1-DI=  , VID: 1.0, SN: 32051306
NAME: "PVDMII DSP SIMM with Two DSPs", DESCR: "PVDMII DSP SIMM with Two DSPs"
PID: PVDM2-32          , VID: V01 , SN: FOC14044JEQ
The difference i am seeing, "show version" showing 1 serail Interface and 2 Channelised T1 Ports.. I am 100% sure 2821 does not come with on-board Serial Cards. Then why "show version is showing " 1 serail Interface card along with 2 Channelised T1 Ports"
How many WIC Card does my Router has?
Thanks in advance
regards,
SAIRAM
Terry Cheema
You router has a 1 vwic card. Its a multi flexed 2 port T1 card. That means you can connect two T1 lines and it can be used for both data and voice.
Serial interface is a logical port that gets generated when you configure the controller. if you run the below command, you will see the configuration on your controller:
sh run | s controll
-Terry
Please rate all helpful posts and mark the thread as answered if you have no other queries.
Terry Cheema
sh run | s controll
-Terry
Thank you Terry
Not a prob mate - if you have no other queries please mark the thread as answered.
-Terry
