2800 router does not have tclsh, but 2801 does with same IOS
vcomcisco
I have 5 routers. Four routers are: c2801-IPBASEK9-m v 12.4(24)T2. One router is a C2800-IPBASEK9-M v 12.4(24)T3. so, it appears that the IOS on all 5 routers is very similar, the only difference is the T3 at the end of the version and that 4 are 2801s and one is a 2800. What is very wierd is the 4 2801 have the embedded scripting language "tclsh". The 2800 does not have tclsh. If I issue the command: tclsh on the 2800, I get:
Center-GW#tclsh
Translating "tclsh"
% Bad IP address or host name
% Unknown command or computer name, or unable to find computer address
Center-GW#
Would the adventerprisek9 or advservicesk9 IOS have tclsh on the 2800?
paolo bevilacqua
They are not running the same IOS.
And, there is no "2800" router. The model is indicated doing "show version".
