2800 Router with multiple frame-relay links
alonzo-garza
Does anyone know if I can assign the same ip-unnumbered LAN address for seperate Serial links on a 2800 series router?
Thanks,-zo
Richard Burts
If I understand your question correctly you are asking if several different serial links can all use ip unnumbered to the same LAN address. The answer to that question is yes. There is no limit to the number of serial links that can be unnumbered to the same LAN address.
If I did not understand the question correctly then please clarify.
Rick
Rick
Richard Burts
Rick
Rick
Thanks Rick, as I get deeper into this configuration I may post more questions. If you don't mind keep a lookout for any of my new posts, I really appreciate it. The 2800 series router is new to me and I just want to make sure everything runs smooth with the multi T-1 configurations.
-Alonzo
