2801 IPSec
rzenzerovic
Does 2801 and 2811 supports IPSec VPN with Base IOS only, like 1812? From comparing tables it is not clear. Should I take Advanced image even for simple VPN, or it is intended for really advanced VPN - SSL, Enterprise etc.?
Richard Burts
Robert
As far as I know any kind of VPN needs encryption. And encryption is not supported in teh Base image. You would need something like the Advanced Services or the Advanced Security feature set to get support for VPN.
Rick
Rick
Danilo Dy
Rick is right, VPN is available only in "Advanced" packaging.
Here is the link on IOS Feature Set Hierarchy http://www.cisco.com/application/pdf/en/us/guest/products/ps5460/c1037/ccmigration_09186a00801ace76.pdf
Dandy
